View Poll Results: Was your Equal-i-zer Brand hitch installed incorrectly?
Yes, it is installed incorrectly 18 54.55%
No, it is installed correctly 15 45.45%
Voters: 33. You may not vote on this poll
Old 06-16-2007, 08:32 PM   #1
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Equal-i-zer installed incorrectly?
Incase you missed it, there is an Equal-i-zer Question thread that raises a concern that many Airstream owners may have had their Equal-i-zer brand weight-distribution hitch improperly installed, even if it was done by an Airstream dealer!
Equal-i-zer’s Customer Support representative, Josh Jones, sent rgodfrey a detailed description of the problem along with the solution, which is found in post #17, page 2, of this thread:
http://www.airforums.com/forums/f464/equalizer-question-32805.html
(Copy & paste the entire quote from Josh onto Word to see all of the words).
My curbside Equal-i-zer Sway Bracket was installed incorrectly by my Airstream dealer just 6 months ago when I purchased my Safari. As you can see in my photo in post #24 of this same thread, the lower bolt went under the propane line and through the lowest hole on the bracket. According to Josh, the propane pipe should have been lowered enough for the bolt to pass through the holes just under the A-frame, enabling the bracket to hold more securely.
I’m not sure yet what I’ll do about it. Some say that by the time I get done writing about this, I could have fixed it myself. My cautious side tells me that moving the propane line might void my 2-year Airstream warranty!
Josh says there may be many people out there with incorrectly installed Equal-i-zer Hitches.
Is your Equal-i-zer brand weight-distribution hitch incorrectly installed, and if so, what do you plan to do about it?
SilverGate is offline   Reply With Quote
Old 06-16-2007, 11:05 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Right Now Nothing
Hi, SilverGate. My hitch was installed by the selling dealer exactly like yours. My trailer is close to three years old and has many thousands of miles on it with out any problems except that the left side "L" bracket came loose. I have cured that problem. I believe at this time I will just leave it as is.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-16-2007, 11:59 PM   #3
Pleasanton , California
Was faced with the same problem, I just gently worked the LP line until I had a nice curve that the bolt would fit through without touching, now the bracket is nice and snug with no problems to date.
______________________________________
Scott
2007 30' Classic - "The Silver Pearl"
2007 Lariat F-250 LB 4x4 Powerstroke Diesel
Yo ho, yo ho a Airstream life for me!
takeachance is offline   Reply With Quote
Old 06-17-2007, 06:13 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Mine is installed correctly....that is....UNDER the frame and ABOVE the LP line. It was installed by.......ME! IIRC, the install manual was very specific about NOT putting the bracked around the LP line, and common sense also dictates this.
Bending the LP line (it's copper) is not difficult. I added a small section of rubber hose to itto prevent additional chafing. The hitch works flawlessly!
Old 06-17-2007, 10:30 AM   #5
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Looks like mine has been installed incorrectly, with the bolt below the lp line on all three trailers, twice by the dealer and once by me. But no problems over 8 years and thousands of miles.
However, on the second trailer, the fittings on the trailer were installed too far aft. So during a tight turn the long rod slipped free of the "L" bracket. I had to move the brackets forward.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 06-17-2007, 12:25 PM   #6
Rollertoaster's Avatar
2007 25' Safari FB SE
Aptos , California
My Equalizer was installed by the dealer, but instead of trying to thread the bolt between the propane line and the frame they simply moved the brackets forward of the hose clamp, shortening the lever arm of the weight bars by about 10". The distance from the center of the hitch to the center of the brackets is supposed to be 32", which I moved it to after I got home.
There really isn't much space between the propane line and the bracket bolts. I check this all the time to see if there is any interference. So far so good.
Rollertoaster is offline   Reply With Quote
Old 06-17-2007, 08:47 PM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Wrong Installation Here
Yes mine is wrong too. Three rivets hold the LP line close to the frame, so the installer put the bolt through the bottom hole instead of re-routing the gas line. You can clearly see the plates are bowing, and I have been having problems with the square headed bolt that holds the L-bracket, loosening.
Since the trailer is still under warranty, right now my plan is to wait until I get to Jackson Center in October and have the factory fix it. I'll be checking that square bolt at every reststop until then.
Lewster: Please post a picture of your installation so we can all see how you did it with the pipe bend.
Randy
Randy and Pat Godfrey
Region 3 1st VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-17-2007, 09:09 PM   #8
TIMEMACHINE's Avatar
Huntington Beach , California
Another bone-head installation
Mine was done exactly the same way with the bracket bowing at the bottom. AS Dealer installed..of course. I always check and tighten all hitch hardware before each tow...so I never had a problem with the bracket or bolt loosening.
John
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 06-18-2007, 05:49 AM   #9
lewster's Avatar
Randy
Will do........as soon as I get a minute. I'm in the throws of last minute prep for the trip!
Old 06-18-2007, 11:04 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I just added a yes no option poll to this thread.
Mine was installed incorrectly by the dealer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-18-2007, 03:03 PM   #11
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
After reading the initial thread last week I noticed this weekend that mine was installed incorrectly by the dealer also. Although I haven't had any problems with the EQLZR, my L brackets do bow out very slightly from the frame.
I have had terrible service from my dealer so it didn't surprise me to find it done incorrectly. Just one more thing to be disappointed about lately.
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 06-18-2007, 08:05 PM   #12
lewster's Avatar
Your dealer's name wouldn't rhyme with 'GATES' would it now?
Old 06-18-2007, 09:11 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Lew -- Microsoft?
Or are you baiting us? My turn...
5 meter Langford Nahanni
Old 06-19-2007, 05:44 AM   #14
lewster's Avatar
Originally Posted by CanoeStream
Lew -- Microsoft?
Why.....I wouldn't THINK of such a thing!?!?!?!?!?
Generator installed in Airstream flyfisher Generators & Solar Power 14 01-22-2004 06:48 PM
New Axle Installed. Success! DanLyle Axles 0 04-24-2003 11:00 PM
replacement airconditioners installed free wb13798 Mechanics Corner - Engines, Transmission & More... 1 04-16-2003 06:44 PM
Fan-tastic vent - has anyone installed one? wayner1239 Electrical - Systems, Generators, Batteries & Solar 14 03-21-2003 04:46 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
