View Poll Results: Was your Equal-i-zer Brand hitch installed incorrectly?
Yes, it is installed incorrectly 18 54.55%
No, it is installed correctly 15 45.45%
Voters: 33. You may not vote on this poll
Old 06-19-2007, 08:49 AM   #15
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Ours was installed correctly because I watched the installation and I told the installer that I wanted the gas line to run over the bolt instead of between frame and bolt. Did not seem right.
I also added a thick piece of "hose" to the bolt to protect from possible rubbing. The only hard part was drilling a coulpe of rivetts out that hold the support brackets for the propane line, one I replaced.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 06-19-2007, 09:03 AM   #16
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
crazylev,
Post a picture of your installation, so we can see what your dealer did.
Randy
Randy and Pat Godfrey
Region 3 1st VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-19-2007, 10:06 AM   #17
1963 19' Globetrotter
Moline , Illinois
Mine is correct because I installed it, I was changing the regulator on my '63 so at the same time I moved the line and added a new rubber hose from the regulator to the line and solved the hitch bracket problem.
63air is offline   Reply With Quote
Old 06-19-2007, 03:39 PM   #18
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
Yes, lewster, I've received of late, from one whose name rhymes with gates, service that I'd generously rate as not so great.
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 06-19-2007, 03:41 PM   #19
2006 28' Safari SE
Hey, but it was worth all the hassle because by posting that reply I got my third Rivet! Well, actually, it wasnt' worth it at all ...
GO GATORS!!
Old 06-20-2007, 11:55 AM   #20
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Hi Randy,
I don't have a real good close up of my set-up and my AS is about 22 miles from me. The best I can do is this:
http://www.airforums.com/attachments...4/dsc_2044.jpg
You can see the small bracket on the under side of the frame that supports the gas line. That had to get repositioned slightly.
Jonathan
Old 07-02-2007, 09:44 PM   #21
OrangeKid
2013 23' Flying Cloud
Portland , Oregon
I just ran across the threads on the Equalizer installation. My dealer here in Vegas installed the Equalizer corrrectly on our 2007 23' Safari SE. In fact I was concerned when I first noticed that the propane line was bent so the lower bolt of the sway bracket could pass over it. Its a relief to know that the installation was correct. In 4000 miles of towing including many mountain grades we have had no problems with the the bolts losening or the sway brackets moving. The L brackets do rotate slightly as others have noted. I will check all the bolts before our next trip.
I have installed a bolt through the top hole of the L bracket so that if the square bolt was to loosen the L bracket would not fall out as one person has reported.
OrangeKid is offline   Reply With Quote
Old 07-02-2007, 10:07 PM   #22
2007 25' Safari FB SE
Blaine , Washington
Mine was installed incorrectly by the Airstream dealer/
Relentless is offline   Reply With Quote
Old 07-10-2007, 10:04 AM   #23
lewster's Avatar
Naples, FL , Hood River, OR
I'll be correctly installing an Equal-I-Zer over the week end and promise to take shots to document the procedure regarding the LP line! (now that my new camera has a smaller format that's Forum-friendly)
Old 07-11-2007, 08:24 AM   #24
Viera , Florida
Dealer Correction to Installation
I have posted a report of my Airstream dealer's correction to my incorrectly installed Equal-i-zer on the original discussion thread.
http://www.airforums.com/forums/f464...ion-32805.html
Randy
Old 07-11-2007, 10:20 AM   #25
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
My equalizer was installed incorrectly. This past Sunday while taking a right turn out of a filling station over a little dip, the left L bracket hit the pavement. The whole bracket moved up and back hitting the gas line. Crimmped it, but I don't think caused a leak. None the less, gas is off until I can get line replaced.
Tom
henw is offline   Reply With Quote
Generator installed in Airstream flyfisher Generators & Solar Power 14 01-22-2004 06:48 PM
New Axle Installed. Success! DanLyle Axles 0 04-24-2003 11:00 PM
replacement airconditioners installed free wb13798 Mechanics Corner - Engines, Transmission & More... 1 04-16-2003 06:44 PM
Fan-tastic vent - has anyone installed one? wayner1239 Electrical - Systems, Generators, Batteries & Solar 14 03-21-2003 04:46 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
