View Poll Results: Where does your TV Cable & Phone cord 'exit' your rig to hookup?
Rear Bumper Storage 16 25.00%
Refrigerator Access panel 12 18.75%
Other 36 56.25%
Voters: 64. You may not vote on this poll
Old 10-04-2004, 12:48 AM   #1
Cat
Cat's Avatar
Mukilteo , Washington
Images: 8
Send a message via Yahoo to Cat
Cable/Phone HookUp
What place does your TV cable & phone cords 'exit' your Airstream to hookup outside?
Cat is offline   Reply With Quote
Old 10-04-2004, 05:11 AM   #2
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
Mine exits the floor under the credenza.
GStephens is offline   Reply With Quote
Old 10-04-2004, 06:49 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Modification
My Overlander originally had a television antenna mounted street-side of the forward window. A 300 ohm flatlead came out of "weathertight" fitting on the skin & attached to the antenna.
With no plans to use the antenna, I removed it & soldered a balun transformer to the wiring, pushed it into the hole, and sealed the hole with a bulkhead-style, 75 ohm coax cable fitting. A similar excercise made the inside jack ready for modern day televisions.
I neither have a phone jack nor plans to install one. But if I did, I would probably run the wiring out the bottom as I don't think I could bring myself to drill a hole in the visible skin.
Tom
Old 10-04-2004, 12:17 PM   #4
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Cable exits
The current Classics (I don't know how far back) have the TV and phone jacks inside the compartment where the power cord stows. The TV jack is a bear to screw on unless you purchase a slip-on connector. There is no finger room around the jack and it is out of sight unless you get on your knees/
John W. Irwin
WBCCI #9632
Old 10-04-2004, 06:30 PM   #5
2004 25' Safari
South West , USA
The '04 Safari has 2 covered jacks (duplex outlet) on the street side rear, 1-75 ohm coax, the other a 4-pin phone jack.
RivetED is offline   Reply With Quote
Old 10-07-2004, 07:03 PM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Mine exits the floor on the street side somewhere around the wardrobe cabinet in the center sleeping area.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-07-2004, 09:20 PM   #7
JohnG's Avatar
I've opted to forget the TV and just use a radio. I enjoy sitting under the awning and listening to it while I relax and enjoy the scenery around me. I do bring my cell, but that is for emergencies. I really don't want to pull my AS and set it up in order to relocate my couch-potatoness in front of a boob-tube.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 10-24-2004, 01:37 AM   #8
Cat
Cat's Avatar
Images: 8
Radio
I think that's the BEST thing I've heard in a long time!!! KUDOs for YOU John!!!
Below is a website I recent learned about for your 'listening' enjoyment (online)...you won't BELIEVE the "library". (list). This website all about old radio shows.
just click here> http://www.radiolovers.com/
Old 10-24-2004, 02:38 AM   #9
Cat
Cat's Avatar
Images: 8
Exiting Holes?
I think it's a 'given' not to puncture the chassis of these Airstreams, and I think I understand what the post above was describing about removal of the antenna and 'plugging' the hole it left.
And then,
I checked that; my power cord comes out and is stored IN the bumper compartment. I cleaned it all out, being quite certain I'd find the cable & phone hookups there---not so. Now, I am designing a convenient and functional spot for them --- custom made.
I just wish you 'guys' would speak in layman's terms...because someone else said
"... soldered a balun [WHAT THE HECK IS 'balun' & 'bulkhead style' ??] .... to the wiring, .....bulkhead-style, ....
I can't follow what I don't understand...so please...for those of us who are not up on these terms...please use lay-speak.
Thank you so much.
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Old 10-24-2004, 10:23 AM   #10
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You could go to an Airstream dealer and have them install the newer style phone/cable access panel, but it looks like home depot style material to me. It seems that you would need a weather tight dual outlet cover, and the inside parts to convert one side for the tv, and the other side for a phone jack. Holes would have to be drilled somehwere convenient in the skin. Preferable in the general vicinity of the water connection and dump valve.
I drilled a small hole in the skin, and mounted a coax connection. The cable runs inside the streetside closet, and connects to the antenna booster inside the overhead bin for the winegard antenna.
I am not familiar with your interior layout, but am assuming that your existing tv wiring is already coax, not flat wire.
My final suggestion to you would be to seek professional help, even though this is not a very difficult upgrade. The function of these systems directly depends on the quality of the installation.
Uwe
www.area63productions.com
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
Septic system hookup rfield54 Waste Systems, Tanks & Totes 3 09-04-2006 07:48 PM
color code for hookup plug richardjohnsonlaw Towing, Tow Vehicles & Hitches 10 01-10-2004 10:03 PM
No grey tank, no sewer hookup Safari Tim Our Community 8 07-11-2003 07:36 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
