Old 12-07-2014, 08:43 AM   #1
2018 33' Classic
Newport , Pennsylvania
Best hitch for 2015 Classic
I have a 2011 Chevy duramax diesel 3500 single rear wheel and I am interested in some advice regarding hitches, which is best, easiest to unhook and hook.
EarlM
EarlM is offline   Reply With Quote
Old 12-07-2014, 08:56 AM   #2
2007 22' International CCD
There are several hitch threads on the forums beating this question to death. Have a look, read the opinions, then decide what makes you comfortable. I use a ProPride system that meets my needs. Others will strongly differ with me. YMMV.
rmkrum is online now   Reply With Quote
Old 12-07-2014, 08:57 AM   #3
2018 33' Classic
Thank you
Old 12-07-2014, 09:44 AM   #4
1986 31' Sovereign
Miami , Florida
What you have asked is akin to asking "which religion shall I practice". There are strong feelings on the issue and the endless discussions get pretty heated.
In the end, you can read 5 posts or 500 and still get no consensus.
Since you tow with a monster truck, any of the major brands will likely work just fine. You may even want to google "Airsafe" for a softer ride.
Welcome to the Forums,
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 12-07-2014, 10:41 AM   #5
EarlM
Earl.
A load equalizing hitch, is like a marriage.
It mates two different things together.
Before a reasonably good answer can be given to your question, you must describe the "exact" tow vehicle, and the exact Airstream, it's size and the payload you intend to carry.
Then you have a decent chance for a decent answer, that then will be based on, "that's what I do", "that's my opinion", that's what the manufacturer states", or "actual factual experience".
Then and only then, will you have something to work with.
Old 12-07-2014, 11:02 AM   #6
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Earl,
As already indicated by RM and Mike, you will find hundreds of opinions here. Many will be based on "Pride of ownership" and "I've towed thousands of miles and haven't wrecked", neither of which are very helpful.
RM and Mike are both giving you very good advice to get with the searches and sort through the hundreds of opinions you find. In addition to learning more about all the alternatives, you will find an occasional solid piece of information that will help you and therefore it is worth the effort. Unfortunately you will also find some folks here that feel they are competent vehicle dynamics experts, when in fact they are simply giving very poor advice not founded on any real expertise other than their practical "I haven't wrecked" experience.
Since you have a very capable tow vehicle, you have the cargo and hitch capacity to hang whatever solution you want on the truck. The more common challenge of having an overloaded TV is one that you will not face.
Good luck with your studies and have fun.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 12-07-2014, 12:43 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
"best, easiest to unhook and hook" translates to ProPride for me. It is one of only two choices for sway elimination (the other is Hensley). The hitch head and w.d. bars stay on the trailer, the stinger can be easily stored there as well by just pulling ahead a few inches and sliding it back in. Some have had a learning curve on backing into it, but it's a simple matter of alignment. Back in, hook up, and go.
That's a heavy truck to expect good hitch weight distribution with and only a portion may be needed. Research weight distribution needed for your truck, and weight distribution bars to accomplish this without transferring unreasonable road shock to your new Airstream.
Doug and Cheryl
Old 12-07-2014, 01:49 PM   #8
Yup. ProPride is just back in, latch, jack for WD, plug in umbilical cable, connect breakaway and walk check one more time.
Then go with fewer worries.
Old 12-07-2014, 01:59 PM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Earl, there are a lot of options for hitches and each has their good and bad sides. What I would recommend is based on my budget, use and how it functions with my tow vehicle. Are there better out there? Maybe, but when I factor in all of my needs and issues, mine is perfectly satisfactory for how and where I drive.
So rather having folks recommend, maybe you can do a little research on the various hitches out there. Find out their cost and make a preliminary list of choices. Then search out each of your choices here on the forum. Lots of threads. You can also ask those who own those hitches, what they like, and what they don't like. Hopefully this will lead you to a decision. That will probably get you better information than an open question for what is the best hitch.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-08-2014, 07:57 PM   #10
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have a brand new ProPride sitting in my garage that'll be mounted on my brand new '15 Classic .... when it arrives. The guy who bought my 28' Intl (wisely) wanted to buy the ProPride when he purchased my trailer. I guess I revealed my preference for trailer hitches, but after around 20,000 miles with the 28, I wouldn't tow with anything else.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 12-09-2014, 01:49 AM   #11
2018 33' Classic
Bab
What kind of TV do you have for your new classic?
Old 12-09-2014, 05:13 AM   #12
BAB
BAB's Avatar
2015 30' Classic
2014 Ram Laramie 2500 CC 4x4 with 6.7L Cummins.
_________________
ProPride 3P
AIR# 58452
Old 12-09-2014, 08:12 PM   #13
2018 33' Classic
I think I am ready to go the Hensley route thanks for your help
Purchase new 2015 FC 25'..best price? atheness 2009-2015 Flying Cloud 42 01-20-2015 10:19 AM
2015 Classic preview ASinmyFuture 2011 - 2015 Classic (all lengths) 244 01-19-2015 05:22 PM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
2015 Classic Airstream RVDreamer Our Community 24 05-13-2014 01:57 AM
2015 Classic news Firedog1 Airstream Trailer Forums 7 01-06-2014 05:37 PM
