Go Back   Airstream Forums > Airstream Community Forums > Our Community > Community Polls
Old 05-28-2006, 09:37 PM   #1
Profile:  2000 30' Excella
Johns Island , South Carolina
Backing - Method, Tricks, Pointers???
Now that I've picked up the AS, enjoyed camping in it for three nights and dragged it home, I have got to get comfortable backing the beast into camp sites. Before I take it to a deserted parking lot to practice, can you give me any pointers? How do you position your rig before beginning to back in? Reference points? Any specifics or rules of thumb would be helpful.
Thanks.
Ernie -
kudzu is offline   Reply With Quote
Old 05-28-2006, 09:56 PM   #2
klevan's Avatar
Profile:  Albuquerque , New Mexico
Thanks.
Ernie -
1. Always remember you're pulling a trailer. Never get into a place without an exit strategy.
2. Backing is just as easy as driving forward.
a. Use your mirrors.
b. Always have a spotter. ( After 30 years of trailering, I violated this rule last month and backed my Airstream into a Juniper tree.)
c. Grip the bottom of the steering wheel. Move it in the direction you want the tail to travel.
d. Be gentle. Give the trailer time to answer the helm.
e. Make sure the spotter knows to look out for rocks,posts and pipes that could snag a B.A.L. jack and tree limbs, and overhangs that can snag the shiny aluminum.
f. Pick out the spot in advance where you want to place your roadside tire, and maneuver to that spot.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 05-28-2006, 10:06 PM   #3
FiveGreers's Avatar
Profile:  Crestview , Florida
Everyone is different....
...and you'll find the way that best suits you. I have no problems (but ours is only 22'- ) backing in ONLY if I look backwards. I cannot use my mirrors in the initial stages-only at "perfecting" the final parking spot. I have to look over my shoulder and back up-completely facing backward! I had an audience upon our return Saturday-three neighbors-and all it takes me is one try to get it parked having to do a 90 degree back up job. I heard clapping and a word of advice to get a trucking job! But for the life of me, I cannot back up using only mirrors facing forward- . So go figure. You will try until you find the method that suits you.
Minya and the kids
2005 22' Safari-
...lost her in the divorce-
Would like another (Airstream), please!
FiveGreers is offline   Reply With Quote
Old 05-28-2006, 10:29 PM   #4
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
Walkie Talkies for the spotter!!!!!! They come in real handy.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 05-29-2006, 06:12 AM   #5
scf31's Avatar
Profile:  1977 25' Caravanner
Jeffersonville , Kentucky
The only thing I could add is that I like to walk on the camp site before I park there and look for any low trees or anything else thet would get in the way of the Airstream , also check utilities location, go slow and use your spotter ,,,,,Good luck !!!!
Master of Airstream
creations for less than 4 Years!
scf31 is offline   Reply With Quote
Old 05-29-2006, 06:26 AM   #6
GlenCoombe's Avatar
Profile:  Sumter , South Carolina
Kudzu, congrats on your new AS. Try to watch the pros if you get a chance. Most tractor-trailer drivers prefer to back in to the left side. This allows you to see out your drivers side window. Use a point of reference on that side and don't give it up as you back around it. Pull forward small amounts to straighten / correct your over cuts.
An open parking lot with lines is the best place to start. When you can back straight then you're ready to insert into tighter spots.
When in doubt, stop, get out and survey, pull forward.
Remember that even the most seasoned commercial drivers go brain dead after a long time going forward. Learn by doing.
I actually back my motorhome into parking spots 95% of the time, so I can see where I'm going when I exit. The more you do it the better you get.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom & PuttLab
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 05-29-2006, 10:13 AM   #7
klevan's Avatar
scf31 is absolutely correct! This should be Step #1 no matter how much of a hurry you think you're in and no matter who is waiting. Get out of your tow vehicle, and walk the site. The longer you've been on the road, the more important this is. It allows you to decompress, clear your head, and change tempo from screaming down the highway to slowly backing in. As GlenCombe suggests, if you have a choice, always back in to your left. Funny how many RV parks supposedly designed for RVs are not set up this way, so you'll have to get good at backing right as well.
If your wife is your spotter, you can wear his and her Tee=Shirts whwnever it's time to back in.
Her tee-shirt says, "Stop shouting at me."
His says, "I'M NOT SHOUTING, DAMN IT."
Ken Levan
Old 05-29-2006, 06:54 AM   #8
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
patenice is the key.
don't rush, make sure your spotter watches for overhead obstuctions as well!
i have a cheap set of two way radios for blind spots, and in the interest of marital bliss never get hot under the collar with your helper!
i have also found removing the sway control and load bars makes turning the trailer into tight spots easier.
john
you call them ferrets, i call them weasels.
Old 05-29-2006, 12:00 PM   #9
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I've attached a PDF I created for a trailer backing seminar I ran at a rally last month. If you print out the PDF double-sided, it will fold nicely in half and create a little booklet.
The three biggest take-away points from my backing up seminar are:
1) Get a ground guide -- someone to tell you what’s going on behind you as you back up.
2) Pre-establish hand signals with your ground guide as this will be the means they will communicate with you as you back-up the trailer.
3) Grip the steering with one hand at the 6 o-clock position. Move your hand in the direction you want the end of the trailer to move.
And, one last pointer, practice makes perfect!
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 05-29-2006, 01:35 PM   #10
wbrownrr's Avatar
Profile:  2002 22' International CCD
San Luis Obispo , California
I agree with the advice given. My wife is always the spotter, and she claims that she is "directionally challenged". It is sometimes helpful for me to first walk the site with her before backing and discuss the line I need the trailer wheels to take. This helps her to signal me when to cut the tow vehicle wheels in order to get the AS to track properly.
Don't despair! Backing gets easy with practice. So.... practice, practice, practice.
Oh, and one last piece of advice. We ride a tandem bicycle.... by tandem etiquette I am considered the "captain" and she is the "stoker." Best advice we were ever given was, "The stoker is always right." So, by extension, "The spotter is always right." Saves a lot of trouble!
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
wbrownrr is offline   Reply With Quote
Old 05-30-2006, 08:15 PM   #11
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Only one piece of advice that I got from a trucker and have used ever since. Don't be afraid or ashamed to back up more than once to get your unit properly aligned and make the last back up a straight one.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 05-30-2006, 08:36 PM   #12
GO Bob's Avatar
Profile:  1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
Great advive here. One more if the is any confusion or hint of question, STOP!!!, get out look and talk it over. Remember the flagman is the most important person but the driver is responsable. Practice, your AS need to excercised like anything else.
GO Bob is offline   Reply With Quote
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 09:27 PM
new water lines Rob Fresh Water Systems 29 07-11-2006 09:25 PM
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 02:14 PM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 03:08 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 04:05 PM
