01-29-2016, 05:14 PM
#41
1954 26' Romany Cruiser
jefferson
, Oregon
axle
Not sure if Im going to go with a torsion control axle or not. I got a quote from Colin Hyde for a torsion axle but after speaking with a few other guys Im thinking maybe I will stick with the old drop style with the leaf springs. Hell it was good enough for Wally and he went around the world on dirty roads. Might be easier just clean up the old springs and strap the new axle on. I think my trailer has 10 springs
01-29-2016, 05:18 PM
#42
jefferson
, Oregon
As far as the back tank goes. Im trying to figure out if I can move the crapper out just enough that I can have a straight discharge and not mess with going over, under or through the frame. That would be ideal and easiest Im thinking. I do have the advantage of 26 feet. Just do a little repositioning.
01-30-2016, 10:41 AM
#43
1955 22' Safari
Great Lake State
Stanley
I went with a straight Dexter axle with the old springs and very happy that I did.
It raised the trailer about 4" and allowed me to go with deeper tanks. See my post 170 for cost, http://www.airforums.com/forums/f36/...-38289-13.html. Would also recommend dropping the old axle and taking it to a local rv dealer for exact measurements, make sure that you go with the right bushings.
toastie
01-30-2016, 11:25 AM
#44
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I have done the same as Toastie....on five different Vintage. I like it ...price, looks, labor and finished ride.
01-30-2016, 11:42 AM
#45
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Nice old trailer. Glad to see you taking good care of it.
Yeah, it was good enough for Wally until he found a better axle/suspension. I converted a 56 Overlander from springs to a new torsion axle. It is not a hard thing to do. The ride is much better with a torsion axle.
The price you list of $800 for one torsion axle is pretty steep. I'm sure you could get a better price from Redneck Trailer Supply for a Dexter axle.
Lance
01-30-2016, 11:56 AM
#46
Always learning
1972 29' Ambassador
Central
Sub-floor choice- I would use 3/4" Joubert MGP
http://www.joubert-group.com/gamme_produit.php?id=83
The beauty in MGP is that is has no voids. Voids accelerate rot.
I buy tanks from Pelland Enterprises. They have just about every tank there is in their catalog.
http://www.pellandent.com/RV_Product...CategoryID=156
I good solution for a black tank is an above the floor design. There are many ways to store poop. Nearly every way has been shown or talked about here on the forum.
I would also use the old frame as a template to build an entirely new frame as HiHo has described.
Lance
01-30-2016, 04:00 PM
#47
jefferson
, Oregon
54 cruiser
Good info thanks
02-02-2016, 09:50 AM
#48
jefferson
, Oregon
frame cross members
I believe Hiho just replaced two cross members on his frame. Mainly to support his tanks. He said he used 2x4 x.125 steel tube. Ive looked at that. Might be a tad heavy since I have to replace damn near all of them. Im looking at a lighter gage. Still heavier then the original. Problem I see is attaching the nuts on the other side of the floor bolts with square tubing. I could have the piece formed but that quote I got was around $500 or so. Any suggestions? Mike
02-02-2016, 09:55 AM
#49
jefferson
, Oregon
frame
frame
02-02-2016, 10:15 AM
#50
Always learning
1972 29' Ambassador
Central
I think HiHo gave a description of how he would build a frame from scratch somewhere here on the forums. I think he could give you some insight as to his thinking on the frame.
Hew is a link to a Paul Mayeux's Cruiser on Picasa. He had a new frame built. Good pictures to look at for anyone rebuilding a 50s Airstream.
https://picasaweb.google.com/1063316...?noredirect=1#
Paul is the owner of A&P Vintage Trailer.
You don't have to use elevator bolts to attach the floor to the rectangular tubing. You can use self tapping floor screws as is currently the practice of Airstream.
Lance
02-02-2016, 02:01 PM
#51
jefferson
, Oregon
Thanks Lance, yes self tapping screws. good idea. Ive spoken with Paul before. He seems like a busy guy and I hate to bother him since he builds these for a living. He told me he had a guy fab a frame for him for around $3800 or so. I would do that if the main rails weren't in good shape. I think Ill try to salvage what I have and save the money. Mike
02-02-2016, 03:49 PM
#52
Always learning
1972 29' Ambassador
Central
Paul is a very busy guy for sure.
I understand your thinking on the frame. The rectangular steel is pretty inexpensive and very strong for outriggers and cross members. You can also cut access holes for fasteners.
Lance
02-02-2016, 05:27 PM
#53
Central
, Mississippi
In the next few months I'm starting a scratch built frame and will use the rectangular tube thruout. Although I'm not a fan of self tapping screws, these have worked super for me.
I space then a little closer than stock and really like them. Predrill with a #8 drill bit.
I'm planning on 4" tall outriggers from the tube and leaning toward 6" tall main rails and cross members. The sides of the belly pan will only be 4" deep so the banana wraps will still work. They sides will attach to some angle welded down the length of the main rails at the 4" dimension. I will have 6" deep tanks in the center of the frame.
02-04-2016, 11:46 PM
#54
jefferson
, Oregon
frame
Replaced almost every cross member. I used 2x4x.083 square tubing. Pretty stout stuff. Not sure how to tackle the 12 outriggers that I need to replace. The curved cut and the fact that the tube I bought is 4" instead of 3". Anybody have any ideas?
02-04-2016, 11:49 PM
#55
jefferson
, Oregon
frame
new cross members welded in place
02-05-2016, 08:09 AM
#56
Central
, Mississippi
I believe it was Truckasarus that cut outriggers using a plasma cutter and a wooden jig. The tube slid into the box like jig and the end had a profile that the plasma cutter traced to cut the curve. That's how I plan on doing mine.
02-05-2016, 08:48 AM
#57
jefferson
, Oregon
That was my thought too. Thanks
02-05-2016, 10:17 AM
#58
Always learning
1972 29' Ambassador
Central
I think I've also seen the curve traced and cut with a band saw. Carlos maybe?
It was an old thread.
Lance
02-05-2016, 01:23 PM
#59
jefferson
, Oregon
I just realized the steel shop made 15 cuts at 12" instead of 12 cuts at 15". Im getting a price for the shop to take a sheet of metal, cut and bend the pieces. For a couple of hundred bucks might be worth it.
02-12-2016, 08:28 PM
#60
jefferson
, Oregon
frame
Finally got the cross members and outriggers welded on. Used a couple of pieces of old outrigger to make a template. Didn't have a plasma cutter handy so did it the hard way. Went ok….cut it with the angle grinder/blade then hit it with a grinder to shape it. Not perfect but I think it will do the job. Jumped around all over the frame to make sure it wouldn't come apart. So far so good. Next step is to paint. Ordered up some Eastwood rust encapsulator. Still have to come up with a grey/black tank plan. Cheers
