Old 03-28-2016, 10:14 PM   #113
1954 26' Romany Cruiser
jefferson , Oregon
1954 cruiser
insulation
ID:	259531   Click image for larger version
ID:	259533   Click image for larger version
Stanley29 is offline   Reply With Quote
Old 03-28-2016, 10:42 PM   #114
jefferson , Oregon
insulation
insulation going in
ID:	259539   Click image for larger version
ID:	259541   Click image for larger version
Old 03-28-2016, 10:49 PM   #115
jefferson , Oregon
belly pan
Got the tough part done today. Hopefully tomorrow will go smoother. Lots of head scratching but I think I figured it out. Would love to watch somebody do this that knows what their doing. Cheers
ID:	259543   Click image for larger version
Old 03-29-2016, 12:53 PM   #116
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Looks great! I feel your pain on the insulation--Fiberglass will always find a way through even the best defenses.
calais66 is offline   Reply With Quote
Old 03-30-2016, 12:09 PM   #117
jefferson , Oregon
Thanks, should finish the belly pan today. The back section took me most of the day yesterday and im not terribly pleased by the results. We'll see how much is covered up by the shell. If not then ill do it again. Cheers
Old 03-30-2016, 10:15 PM   #118
jefferson , Oregon
belly pan done
Finished up the belly pan today. Came out alright I guess for being my first one. Took me 3 days. The corners kicked my butt. compound corners take some skill and experience to do right. My next one will be better. The real test will come when I drop the shell down on her this weekend. Here are some shots of the belly pan
ID:	259685   Click image for larger version
ID:	259687   Click image for larger version
Old 03-30-2016, 10:24 PM   #119
jefferson , Oregon
more belly pan
belly pan
ID:	259689   Click image for larger version
ID:	259691   Click image for larger version
Old 03-30-2016, 10:29 PM   #120
jefferson , Oregon
1954 cruiser
don't forget to run your brake wire. Luckily I caught myself before I put down the aluminum. I welded on the old shock studs onto the new plates on the new axle
ID:	259693   Click image for larger version
Old 03-31-2016, 06:54 AM   #121
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Looks good
Aerowood is online now   Reply With Quote
Old 03-31-2016, 07:58 AM   #122
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I'm so envious you got to do yours upside down - I just did mine this last weekend on my back - what a pain - it turn out fair - not NEARLY as nice as yours - congrats - very nice job!!!!
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 03-31-2016, 05:39 PM   #123
Central , Mississippi
The belly pan looks great but why work on a nice day, fire up that old radial and let's go for a biplane ride!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-31-2016, 11:26 PM   #124
jefferson , Oregon
1954 cruiser
Thanks guys…appreciate the kind words. The learning curve is steep. Id do things a little different. The 2" insulation was a problem because I cut it to fit to the edge of the floor , which I was quite proud of, ended up getting in the way of the belly pan. I Had to go back and trim it all off….pain in the a….. When I made new out riggers I made the mistake of cutting them all 15". I should have cut them to 14 or 14.5 and brought the floor out to 15". That would have prevented interference with the belly pan. I had to cut a lot of them back with the saw…More time lost. I probably should have rolled her back over to finish the corners. I was drilling blind. I would have but didn't have a lot of confidence in my old climbing ropes. I should probably throw a couple of big chains over the rafters before doing anymore hoisting. The ropes make me nervous.
Old 04-02-2016, 07:01 AM   #125
jefferson , Oregon
It sure makes it easy when you can just lay down a 10x4 sheet of aluminum and go at it. Man thats got to be tough doing it upside down. How in the world do you hold it in place? Do you have a thread on your project?
Old 04-02-2016, 07:07 AM   #126
jefferson , Oregon
belly pan 1954 cruiser
flipped her back on her feet yesterday. Will try to take time from my orchard today to slide her under the shell
ID:	259787   Click image for larger version
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
