Old 03-10-2016, 08:41 PM   #85
1954 26' Romany Cruiser
jefferson , Oregon
frame under shell
frame being rolled under the shell. Little more work on the end cap. My hats off to the guys who have done this. Serious fumes and patients. Not looking forward to the rear one. Think I might try the aircraft grade remover
ID:	258551   Click image for larger version
Stanley29 is offline   Reply With Quote
Old 03-13-2016, 09:56 PM   #86
jefferson , Oregon
floor
After several attempts of trying to duplicate the front and aft sections of the floor I remembered I still had the trim laying around. Good thing it saved the day. Not sure is I could have even come close. Should be good to go now. Interesting how the aluminum that is the main support of the shell doesn't reach the floor. 1/2 inch on some of them….
Old 03-13-2016, 10:10 PM   #87
jefferson , Oregon
floor
views of the shell sitting on the floor
ID:	258729   Click image for larger version
Old 03-13-2016, 10:15 PM   #88
jefferson , Oregon
floor 1954 Cruiser
Rolled the frame out from under the shell and put in the remaining screws then pulled them out and applied a coat of wood sealer. More coats tomorrow. Have to take care of the wheel pants next
Old 03-13-2016, 10:25 PM   #89
jefferson , Oregon
floor 1954 Cruiser
floor with coat of sealer
ID:	258737   Click image for larger version
Old 03-14-2016, 05:13 PM   #90
jefferson , Oregon
Looking for some insulation ideas. Has anybody have experience with spray insulation?
Old 03-15-2016, 04:42 AM   #91
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Google "spray foam airforums" and you'll find lots of discussion
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 03-16-2016, 09:49 AM   #92
jefferson , Oregon
insulation
Just ordered up my aluminum for the belly pan. went with .030 5052. $45/sheet 4x10. Still need to figure out how Im going to insulate the floor and need to find a large grey tank. Until then I will leave one cavity open. Found some 2" blue foam at Lowes. R10.. A bit pricy…then there is a guy selling some R-4 pink stuff fairly cheap. I think I saw HIHO using it. Anybody have any advice?
Old 03-18-2016, 07:55 AM   #93
jefferson , Oregon
end caps
Did some more work on the end caps. After using copious amounts of paint remover I moved to the polish. F9….didnt do a great job.this is the front cap. I need to go at it with some steel wool or sand paper to get the deep corrosion out of the aluminum. The rear cap is coming along. I used steel wool and it works much better.
ID:	258969   Click image for larger version
Old 03-18-2016, 08:03 AM   #94
jefferson , Oregon
My aluminum for the belly pan has arrived. Trying to finish up the wheel wells before I flip the trailer and work the bottom size. Having issues fitting them. I had to fab most of the outer portions since the others were rusted off. I cut the floor inline with the main frame rail now Im thinking it should have hung over a half inch. No where to attach the outer lip of the fender that seems to want to rest on part of the main frame rail. I might rip a piece of wood and glue it in then screw the fender to it.
Old 03-18-2016, 08:08 AM   #95
jefferson , Oregon
cruiser fenders
fenders
ID:	258971   Click image for larger version
Old 03-18-2016, 09:51 PM   #96
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
Central , Texas
Images: 24
Send a message via Yahoo to Top
I personally think sub-floor insulation is a useless waste of time and effort that will only cause more harm than good. A good heater and a warm to the foot floor covering is my best advice for cozy feet in cold weather camping.
Lance
Top is offline   Reply With Quote
Old 03-19-2016, 08:23 AM   #97
jefferson , Oregon
No insulation eh. Interesting….where will the varmints live? If its a waste of time its definitely a waste of money. Foam board insulation is not cheap. Couple of things. Im not anxious to screw a bunch of holes into the bottom of the floor…also Im thinking that being upside down and bouncing down the road the foam boards would eventually come loose. Maybe. Bat would make the most sense but definitely do not want mice and they will get in…no doubt. Some spray foam maybe. HOFARC does a lot of this
Old 03-19-2016, 09:07 AM   #98
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
True. I insulated the underside of Abby with two layers of DOW TUFF-R polyiso foam board and the floor is cold on cold mornings. I wish I would have spent my time and money on other things.
Spray foam may be better. It sure is costly though.
Lance
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
