Old 01-14-2016, 09:16 PM   #15
1968 26' Overlander
Manheim , Pennsylvania
Yes, we definitely want pictures! When you click reply, don't use the quick reply box, use the blue "reply to post" button just above it. That opens a new page where you can click on the little "paper clip" above the typing box, which will open up a new tab. Then you can upload a picture to the site. Then go back to the typing window tab and reclick the paper clip. Your picture should show up there as a button to push. Then you can push the "preview post" to make sure it all shows up!
I just figured out all of this stuff myself too...
SonOfAnder is offline   Reply With Quote
Old 01-15-2016, 10:31 PM   #16
1954 26' Romany Cruiser
jefferson , Oregon
Im trying to figure out the pict thing. Thanks, Mike
Stanley29 is offline   Reply With Quote
Old 01-15-2016, 10:45 PM   #17
jefferson , Oregon
Beginning restoration
Old 01-15-2016, 10:47 PM   #18
jefferson , Oregon
shot before gutting her
Old 01-15-2016, 10:51 PM   #19
jefferson , Oregon
Thought Id leave the bathroom intact then I figured out I couldn't get it through the door. duuuuhhhh….Sawed it to pieces to get it out
Old 01-15-2016, 10:54 PM   #20
jefferson , Oregon
started removing panels and old insulation. some cross member are corroded pretty bad. and noticed some corrosion on parts of the inside of the outer panels. Ill have to treat this with something
Old 01-15-2016, 10:56 PM   #21
jefferson , Oregon
leaving the end caps on. the top panel came down on top of me…..knocked over the light and i fell through the floor. the piece was 20feet long. a bitch to get out the door
Old 01-15-2016, 11:04 PM   #22
jefferson , Oregon
panels off
ID:	255762   Click image for larger version
Old 01-15-2016, 11:10 PM   #23
jefferson , Oregon
thought Id put a shine on the old girl so it would be nice to look at while I tackle the tough issues. Nuvite F9….came out ok…I will need to go over some areas again that have deep scratches. I plan on finishing the polish when she's done
ID:	255764   Click image for larger version
Old 01-15-2016, 11:18 PM   #24
jefferson , Oregon
rigged up a couple of 2x6 x 16's to lift the shell. Was going to lift from the 2 far vents but didn't have enough room to run the straps to the com -along since I needed to lift pretty high to get over the wheel wells. I ended up pulling from the center vent. Of course I drilled out all the rivets I could see and most of the blind rivets. That was not easy
Old 01-15-2016, 11:21 PM   #25
jefferson , Oregon
beam in place ready to lift the shell
Old 01-15-2016, 11:28 PM   #26
jefferson , Oregon
Thumbs up
Shell coming off….you figure out pretty quick where the hidden rivet are located. The tough ones seemed to be around the wheel wells. Lifted easily…slow a little at at a time. Came off ok. The shell is definitely heavier in the front. The girl wanted to tip forward. I will secure 2 more straps on cleats for and aft to even the load when I have to lift her again
ID:	255772   Click image for larger version
Old 01-15-2016, 11:33 PM   #27
jefferson , Oregon
I can now get a good look at the rotted floor and rusted out frame
ID:	255774   Click image for larger version
Old 01-15-2016, 11:50 PM   #28
jefferson , Oregon
nasty rotted floor. It was tough to get a good template of the front and rear corners. I layer out some heavy paper and traced it best I could. Didn't work well. I will have to try some other ideas on getting an accurate cut for the new floor. Lots to do before that happens
ID:	255777   Click image for larger version
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 01:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 04:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 01:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 10:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 06:46 PM
