Old 06-25-2016, 07:05 PM   #197
toastie's Avatar
1955 22' Safari
Great Lake State , .
Found this on YouTube, went with this system for all my compounding and polishing, very fast.....toastie
toastie is offline   Reply With Quote
Old 06-25-2016, 08:50 PM   #198
1954 26' Romany Cruiser
jefferson , Oregon
yes totally different from the Hofarc video I watched. Seems to work very nice and fast. I might try that and see how that goes. Thanks
Stanley29 is offline   Reply With Quote
Old 06-25-2016, 10:19 PM   #199
Central , Mississippi
Originally Posted by Stanley29 View Post
yes totally different from the Hofarc video I watched...Thanks
They seem to make pretty good stuff on how to install a claw foot tub in an Airstream.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-26-2016, 12:04 PM   #200
toastie's Avatar
1955 22' Safari
When using the cyclo polisher for the finish, I followed Tom of perfect polish with nuvite "S". Take note of the wraps that you can get from perfect polish, a great design, and a time saver. When compounding I use Bright Work Metal Polish "white".......toastie
http://www.perfectpolish.com/cloth.html
http://www.brightworkpolish.com
Old 07-02-2016, 11:37 AM   #201
jefferson , Oregon
polishing end caps
Im thinking I need to get on the end caps before I start on the interior. Don't want to make a mess and it is messy. I saw a video of a guy using the method you mentioned but his first step was with 400 grit sand paper followed by 800 then on to the polish. I used 200 on my rear end cap and it didn't take anytime at all taking off the corrosion or pitting. I haven't yet tried to polish it up yet with a finer grade polish like nuvite C. I plan on doing that and see if I can get a shine back into it.
Old 07-02-2016, 12:05 PM   #202
jefferson , Oregon
1954 airstream
Still waiting for my interior aluminum to arrive. While Im waiting I went through and ran tests on all my ac circuits. Making sure all my switches and light connections work before the skin goes on. Everything checked out good. My second layer of insulation is in. Does anybody know anything about a drain hose for the ac? I ran a dedicated wire to the location but didn't think about a drain line. How big and where should I run it?
Old 07-02-2016, 01:03 PM   #203
toastie's Avatar
1955 22' Safari
No problem, I think we all develop our own techniques when it come to polishing.
toastie
Old 07-17-2016, 03:23 PM   #204
jefferson , Oregon
antenna for 54 cruiser
Thanks Toastie for the heads up on the antenna. I must have missed that from VTS.
Old 07-17-2016, 03:38 PM   #205
jefferson , Oregon
inner skin
Finally getting around to skinning the inside. Decided to go with .032 5052 4x10 foot sheets. Ran then length wise forward. Figured the sheer strength wood be greater and also less cutting. Only cutting the 4' side instead of the 10ft. Not that big of deal. Ive overlapped them anyway. Too hard to get a good fit butting them on 3/4inched. Im hoping to not forget any of my wires and have her all skinned up by the beginning of the month. Time consuming cutting out all the 110 boxes and drilling the rivet holes. Went down to harbor freight and invested in a air drill and rolling table. helps a lot to have the tools.Here are some picts
ID:	267076   Click image for larger version
Old 07-28-2016, 01:26 PM   #206
jefferson , Oregon
Guess they do not carry that antenna anymore. Ill have to keep looking
Old 08-08-2016, 09:52 PM   #207
jefferson , Oregon
1954 cruiser under shell
Got the old girl all riveted up inside with fresh aluminum. Went with .032 5052. Think I paid $39 a sheet for 4x10. Took 8 I believe to do the job. Ran them length wise for maximum sheer strength. Both end caps are polished to the second stage. Made a mess. Still need to put the cyclo 5 on them. Got one tonight on eBay for $150. Hope it runs.
roughed up all the inside skin with 230 sand paper to prep for paint. I will caulk all the seams tomorrow, tape it off and shoot it with at air gun. I plan on using a low voc paint but not sure what just yet. Im thinking a auto paint might work the best. Here are some picts hope they are straight this time
ID:	268603   Click image for larger version
Old 08-08-2016, 09:59 PM   #208
jefferson , Oregon
got my solar panels up. Went with go power 200 watt system with the pass through. Ran the cables down through the street side wall. Should fit nice. I used 3m double sided tape then sealed the edges with sikaflex 221. I wish I would have been a little neater with the sealant. You can see the edges of the panels if you look hard. I still need to aluminum tape the cables down
Old 08-13-2016, 11:59 PM   #209
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looking good Mike, you are getting to the fun part now! You will be on the road in no time!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 08-14-2016, 09:08 AM   #210
jefferson , Oregon
Thanks Doug,
Thats the encouragement I need. I just finished painting the inner skin. Taped off the front and back ends that are polished. Went with delicate white acrylic latex paint. Put too much primer on with the neighbors airless sprayer. Didn't go so well. The gun spit and I had the wrong nozzle. After two days of sanding the runs out I went and bought my own gun from Harbor freight ($189 on sale). I did it right. Im happy with the final product. Picts to follow.
Im thinking of laying up some panels of wood maybe 3ft wide along the sides that border the polished aluminum. I bought 1/4 luan because I couldn't find the birch I wanted. I will test some pieces with stain to see if I can get the look Im after. Does anybody have some advice on attaching paneling to the aluminum?
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
