Old 06-21-2016, 07:48 AM   #181
1954 26' Romany Cruiser
jefferson , Oregon
inner skin
What did you use to fasten them? I would be afraid of metal screws pulling out over time. 1/4 inch birch? Thats nice stuff. Im sure that installed lengthwise the sheer strength would be enough quite good.
Stanley29 is offline   Reply With Quote
Old 06-21-2016, 08:00 AM   #182
jefferson , Oregon
birch paneling
Any picts available? Would like to check out the finished look of your trailer. Thanks
Old 06-21-2016, 08:15 AM   #183
jefferson , Oregon
54 cruiser
received my converter ac/dc control panel yesterday along with 2 fantastic fans and an array of other cool stuff. The rest of the appliances including a 200watt flex solar system, Furnace, fresh water tank and grey tank, on demand water heater and Natures Head commode should arrive any day now. I ordered it now so I could make sure of the positioning and wiring before laying in the inner panels.
Cleaned up the back hatch and riveted on the new emblem. Re-wired the DC in the trailer. Didn't like the way I had it setup. Much cleaner now. Also taped out the floor plan. 24" cabinets and benches for the dinette? Seems tight.
ID:	264888   Click image for larger version
Old 06-21-2016, 08:37 AM   #184
1955 22' Safari
Laredo , Texas
Panelled my 55 FC
I did mine in 1/8" Baltic birch (over existing inner skin). Birch is held in place by aluminum flat bar trim and not actually attached to inner skin. Gets lots of compliments.
Name:	Roof vent paneled.jpg
ID:	264891   Click image for larger version
55AS is offline   Reply With Quote
Old 06-21-2016, 08:57 AM   #185
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
bambitex that is a stunning ceiling.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-21-2016, 06:16 PM   #186
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Palo Alto , California
'67 safari birch interior
We did a birch interior in our safari. We also attached it over the inner skin.
ID:	264906   Click image for larger version
markdenise is offline   Reply With Quote
Old 06-22-2016, 11:39 AM   #187
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
I kept the roof and end cap tops aluminum and slid the wood under the original skins that I kept. I used Olympic rivets on the seams (as well as on the extra rib supports) and screws along the bottom. The thought is the galley, dinette, gaucho, etc. will add some extra sturdiness as well once they go in.
The panels went in vertically to match the grain of the original closets and galley. Also made it easier to bend to the contour of the end cap.
calais66 is offline   Reply With Quote
Old 06-22-2016, 02:45 PM   #188
1962 28' Ambassador
Mesa , Arizona
MarkDenise looking equally great.
Hittenstiehl
Old 06-22-2016, 10:00 PM   #189
jefferson , Oregon
polishing end caps
Has anyone ran into the problem of deep etching or corrosion in the end caps? Im killing myself trying to polish this out. Ive been hitting it with F7. I worked one panel with some steel wool but now I have scratches I have to work out. Im up for suggestions. Cheers, Mike
ID:	264986   Click image for larger version
Old 06-23-2016, 03:56 PM   #190
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Paint thinner and lots of elbow grease. Move and change the rags often!
Old 06-24-2016, 09:49 PM   #191
jefferson , Oregon
1954 airstream
One of two fantastic fans installed. 48 rivets on each one. What a pain. Im done drilling out rivets. Did a little more polishing. I think someone must have left her in front of a sprinkler for 20 years. Lots of oxidation. Other side is much better. Received my self composting toilet today. Natures choice. We'll see how that works out. Im excited about no blue juice of stinky slinky.
Old 06-24-2016, 09:51 PM   #192
jefferson , Oregon
fans
picts of the fan install and toilet position
Old 06-25-2016, 11:42 AM   #193
toastie's Avatar
1955 22' Safari
Great Lake State , .
Here are a couple of picture's of mine, you really have to apply pressure.
What of pads are you using?
toastie
ID:	265172   Click image for larger version
toastie is offline   Reply With Quote
Old 06-25-2016, 03:30 PM   #194
jefferson , Oregon
end caps
Im using the wool pads that vts sells with nuvite F7.
Old 06-25-2016, 03:30 PM   #195
jefferson , Oregon
looks like the same stuff as mine
Old 06-25-2016, 03:39 PM   #196
jefferson , Oregon
picts
picts
ID:	265184   Click image for larger version
Old 06-25-2016, 07:05 PM   #197
toastie's Avatar
1955 22' Safari
Found this on YouTube, went with this system for all my compounding and polishing, very fast.....toastie
Got everything at Caswell's
(1) - GA58 Grinder/Buffer Adapter
(4) - SSCW1220 Spiral Sewn Cotton Wheels
(2) - LCW1240 Loose Cotton Wheels
(1) ea. - BRBC5 Brown Tripoli Bar & White Rouge Bar, I would
go with the black rouge for your problem.
(1) - WR995 Wheel Rake (for cleaning & fluffing the wheels)
Old 06-25-2016, 08:50 PM   #198
jefferson , Oregon
yes totally different from the Hofarc video I watched. Seems to work very nice and fast. I might try that and see how that goes. Thanks
Old 06-25-2016, 10:19 PM   #199
Central , Mississippi
yes totally different from the Hofarc video I watched...Thanks
They seem to make pretty good stuff on how to install a claw foot tub in an Airstream.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 06-26-2016, 12:04 PM   #200
toastie's Avatar
1955 22' Safari
When using the cyclo polisher for the finish, I followed Tom of perfect polish with nuvite "S". Take note of the wraps that you can get from perfect polish, a great design, and a time saver. When compounding I use Bright Work Metal Polish "white".......toastie
http://www.perfectpolish.com/cloth.html
http://www.brightworkpolish.com
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
