Old 03-11-2009, 10:51 AM   #99
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by 62overlander View Post
That looks tremendous... great job. Did you do it all with hand tools?
Thanks Frank, I did shape it by hand. I started by hammering the out the old one flat for a template, then I cut the new one so it would stand out an extra3/4".I rolled the general shape to mach the door and started bending 3/8" lipps on both sides with a pliers a little at a time and just kept checking against the shape of the door.
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-18-2009, 09:46 AM   #100
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
C channel
I had a couple of options today, I could go to work and do paperwork or work outside(70 degrees and sunny)on the cruiser for couple of hours. It was nice spending time on the Airstream, maybe I'll go to work tomorrow when it is raining. So I did get to finish installing the C channel all the way around and I think I have the body pretty well positioned now.It did take quite a bit of adjusting to get the body to fit right on the corners. With the help of the forums and all of the tips it does make it go better. The Trailer definitely has to be leveled well. Here are some before and after pics of the corners,I think it looks quite a bit better.
Name:	Airstream Gutting 013.jpg
ID:	78705   Click image for larger version
Name:	Airstream Gutting 015.jpg
Name:	54 Airstream C channel installed 003.jpg
ID:	78707   Click image for larger version
Name:	54 Airstream C channel installed 002.jpg
Name:	54 Airstream C channel installed 001.jpg
Old 04-18-2009, 11:25 AM   #101
toastie's Avatar
1955 22' Safari
Great Lake State , .
Looks great...........
toastie is offline   Reply With Quote
Old 07-08-2009, 09:35 PM   #102
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Back to work
Well now that our daughter is married and a few of the other projects are done, its time to dive in again.
Jan and I just got back from the Madison international rally, it was pretty motivating to see all that aluminum. So tonight I placed an order to VTS for fans,gaskets,rivets and a bunch of other stuff.
The push is on, Jan and I set up and manage the campground at our local county fair so we thought it might be cool to use the aluminum tent if I can get it sealed up a bit more. it will be a good push for a while anyway.
Here is a few international pics:
Name:	2009 Airstream Rally 074.jpg
ID:	83677   Click image for larger version
Name:	2009 Airstream Rally 075.jpg
Name:	Little Norway July 2, 2009 079.jpg
ID:	83679   Click image for larger version
Name:	Little Norway July 2, 2009 078.jpg
Old 07-18-2009, 10:13 PM   #103
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Belly pan
I finally got a little time this week to get back to work. I started putting the belly pan on the sides, about a month ago I picked up new material for this, 3033 4'x8' sheets. I am leaving the center open for now for future work. I decided to bring the new material to work to roll the edges to the basic shape.
I also want to add small storage spaces in between the outriggers, Jan and I saw this on some other models, should work good for power cords and hoses,etc.
Name:	airstream bellly,insulation,polish door 007.jpg
ID:	84078   Click image for larger version
Name:	airstream bellly,insulation,polish door 008.jpg
Name:	airstream bellly,insulation,polish door 010.jpg
ID:	84080   Click image for larger version
Name:	airstream bellly,insulation,polish door 012.jpg
Old 07-19-2009, 02:29 AM   #104
Baltimore , Maryland
funny how you "saw that on some older units" Your trailer is a 54..... I have what you are doing on my 62. Not sure if you noticed it when we were standing there talking at Madison. Mine is for my power cord and I wish I had put in some others while I was at it, that hatch is very handy.
Old 07-19-2009, 06:50 AM   #105
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
storage
Hi Frank, We are planning on putting about 6 of those little storage areas in, they are not very big but should work good for campfire sticks and all the outdoor stuff. We have been following your blog, you have put on a lot of miles since Madison collecting trailers, it should keep you busy for a while
Doug and Jan
Old 07-19-2009, 07:16 AM   #106
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Sealing the outer shell from inside
Last night and this morning I was able to get all of the seams resealed, I used a product that we use at work for sealing forced air duct work in homes.It adheres well and stays pliable. the seams in the left show the original factory black tar from 1954 and the right is the new gray rubber coating.I covered everything even the rivets and seams the factory did not do for some reason.
Name:	airstream bellly,insulation,polish door 003.jpg
ID:	84087   Click image for larger version
Name:	airstream bellly,insulation,polish door 001.jpg
Old 07-19-2009, 09:54 AM   #107
soldiermedic's Avatar
Florissant , USA
Hey Doug,
Please post a shot of your completed drawers. I would like to see how you plan to fasten them closed.
Everything looks great!
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 07-19-2009, 08:27 PM   #108
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by soldiermedic View Post
Hey Doug,
Steve
Hi Steve, I see your floor is coming along, looking good. I actually had not thought of drawers, just storage spaces. The ones we saw at the international rally did not have drawers but I like that Idea for the ones that don't have water and electric coming out of them. I think I will just make a metal box to slide into the space, the spaces are only 3" by 20"w by 15"deep.
Old 07-19-2009, 08:38 PM   #109
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Insulation
Spent some time today insulating the shell with Reflectix for the first layer. Next I will install the wiring then a layer of foil faced fiberglass insulation. Its nice to see a change inside.
Name:	airstream bellly,insulation,polish door 015.jpg
ID:	84134   Click image for larger version
Name:	airstream bellly,insulation,polish door 021.jpg
Old 07-20-2009, 04:31 PM   #110
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Polishing door
Took a break from insulating and played with the door some, a previous owner had taken a orbital sander or disc grinder to the edges and a few spots. I am sure glad he stopped there. I was not sure how to get rid of the grinder marks until my wife had found a thread on polishing window frames, he used 80 grit sanding wheels then 300-400grit sand paper then his polish,it worked pretty well. So I used some 320grit paper that I had then truck box polish from the airstream guy.
Name:	airstream bellly,insulation,polish door 016.jpg
ID:	84206   Click image for larger version
Name:	airstream bellly,insulation,polish door 018.jpg
Name:	airstream bellly,insulation,polish door 020.jpg
Old 08-19-2009, 05:08 AM   #111
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Cruisers New Home
After sitting outside for some 55 years, the cruisers new home is starting to take shape. Her new place will be 24' wide by 40' long with a 2nd floor for some parts storage. overall about 30 ft. tall to the top of the cuopala. Lots of digging holes(20 of them ) on day one (I would not want to do that for a living). Day 2 brought some shape, setting poles(filling the holes back in) and framing in the sides. Day 3,today brings in the trusses and some more height.We have had some great help with building from friends, my brothers,and my brother in law Ron and his boys. Jan has been keeping us going with her great lunch program,Thanks Jan.
ID:	85673   Click image for larger version
Old 08-19-2009, 05:13 AM   #112
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The cook
It would not let add the most important picture,Thanks again Jan.
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 09:05 PM
