Old 03-05-2009, 01:09 PM   #85
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
That is one great design Doug. Even the roof has your signature on it! :-)
-Tim
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 03-07-2009, 03:27 PM   #86
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Has anyone ever used stainless screws instead of rivets to reattach the main body to the C- channel on the outside bottom walls? Most of that joint is covered by the front and rear trim and it seams as thou the screws would be just as strong. By doing this I could more easily remove the belly pan later if I wished to change something or repair something.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-07-2009, 06:41 PM   #87
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
Tinman - The install of the new floor in my '54 Cruiser was finished last weekend, and I'm using stainless screws to reattach the front & rear lower trim pieces. Matter of fact - ALL the perimeter screws & bolts are stainless. Nothing else made sense, and the thought of anything else stunk of the shoddy work done by a PO. My resto is going very slow - a lack of enough money and any skills at all!! Thank God for good Airstream friends, wonderful vintage fanatics!! This is definately a longer term project than I originally thought. Ever heard THAT before?? Wiring is next, when the Intellipower 4560 arrives from VTS (currently on back order . . ). Then we have to get serious on a floorplan, which hinges on how I design the bathroom, plumbing & tank(s). I'm also thinking of not having a shower. Just a toilet & sink & kitchen sink. That negates several issues for me.
You're doing GREAT work, and so fast!! I salute you. Please do keep it up, with lots of photos. Photos - that's how I learn. I suffer from learning disorders . So keep 'em coming!!
I'd do a thread or blog & post photos, if I had the least bit of computer skills . . . .
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 03-07-2009, 07:10 PM   #88
soldiermedic's Avatar
Florissant , USA
Whitsend,
Your restoration is going SLOW? You just had the floor replaced which is considerably further than mine is, and I have been at it much longer. I wish we had the Airstream helpers in Missouri that you have in Texas.
Good work Tinman, and keep the photos coming.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-07-2009, 08:21 PM   #89
Jim mi amigo, this sounds like a cop-out! I'd LOVE to see just a few pictures. I'm not one of your vintage restoration gurus, but I'd be delighted to help you document if you like. A Forum thread, or a blog, or a stone carving with sanskrit-- whatever you like!
As for the question at hand, I can't really comment. I tend to follow the factory's original design when and where it makes sense, but if you really do think you might want to remove the belly at some future point, and you think the screws will help, then I don't suppose there's anything necessarily bad about that.
Old 03-08-2009, 01:08 AM   #90
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Didn't SoldierMedic find that not only were the belly skins attached with screws (flathead!!), but also the interior skins on his '50's Flying Cloud? My only thought would be that they might back out with vibrations?
Marac
Old 03-08-2009, 04:42 AM   #91
1961 24' Tradewind
rockport , Maine
Here is a rough model of the new barn and workshop.
Love the look of the barn, wish we could do that here in Maine! The snow load from the high steep roof onto the lower shallow pitch roof would be too much. Now that we're near 100" here again this winter, it's hard not to think of snow!
hwy61 is offline   Reply With Quote
Old 03-08-2009, 06:02 AM   #92
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Hi Jim, It sounds like you are ahead of me now and moving right along,it would be great to see some of your pictures, I'm sure your taking plenty, hope you can get the thread or blog figured out, I'm with you pictures are what I like best. I am hoping we get some nice weather in the next few weeks here so I can make some progress.
Doug
Old 03-08-2009, 06:11 AM   #93
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Barn
The snow can be a concern here, that is part of the reason I'm going from 12' to 14' sides so I can get a steeper pitch on the shop portion.Also I think I am addicted to this now I want to be able to lift the next shell off inside.
Old 03-08-2009, 06:19 AM   #94
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Screws
Marac
About half of the outside was screwed before, that is why I felt I would just use screws all the way around, I think they will look ok and with volkum on each one they won't loosen up very easily. The floor was so rotten before, I'm not sure what was keeping the top on when we brought it home.
Old 03-08-2009, 06:30 AM   #95
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
New aluminum :(
Not quite the the kind of aluminum that I look for on here but it will let us camp a couple of times this summer while the Cruiser gets a facelift My wife didn't want me to go to fast on the cruiser just so we could use it this summer.
Name:	1992 POPUP CAMPER.jpg
Old 03-10-2009, 08:27 PM   #96
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Rain shield for door
Raining/snowing here again so I thought I would try to make a new rain shield for over the main door.This one is aluminum, I am going to try one out of stainless steel also, just because it seems like the old one took a lot of abuse.
Work is a little slow right now so I'm taking a couple days off next week for some cruiser time. I have new aluminum coming for the belly pan so I'm hoping to get all the edges or banana wraps done and fasten down the shell permanently.
Name:	Door rain cap 002.jpg
Old 03-11-2009, 04:26 AM   #97
Baltimore , Maryland
That looks tremendous... great job. Did you do it all with hand tools?
Old 03-11-2009, 05:26 AM   #98
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Tinman54,
Just like a bunch of other folks, I have just found this thread and found it interesting.
We have the rain sensing fantastic vents on our '06 and so far they have worked flawlessly. They clam up after sensing rain, wait 15 minutes, then open again. If no more rain is sensed they stay open or close if they feel more of the liquid sunshine. I am ciphering on how I can add a pair to our '87. They certainly do move a lot of air.
When you are finished with your barn, which looks very cool, you can come to PA and throw one up for me.
Keep up the good work and you'll be streamin' in no time.
PS - You could paint the pop-up silver and throw an Airstream nameplate on it and you would have something similar to an Airstream Basecamp.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 09:05 PM
