Old 10-28-2014, 02:18 PM   #547
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by TooMuchTin View Post
You say you would do it all over again, but does that include building another barn?
Another barn, that's a great idea! At least an addition on both sides would be good, more room for aluminum!!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-06-2015, 04:13 PM   #548
WESTPORT , Massachusetts
Great job!
T-CASWELL is offline   Reply With Quote
Old 01-15-2016, 04:54 AM   #549
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Tune up time
We have traveled with the Cruiser about 12000 miles in in the last four years and tires are a little over 6years old so I thought it is time for new tires more because of the age? We used Goodyear Marathons the first time around and seemed to work just fine. We are thinking about a 5000 mile trip to Oregon in May and I like to avoid any potential problems! Always fun prepping for the first trip of the new year! I will probably use the same tires unless anyone has something better, I know there are many opinions on this.
Old 01-15-2016, 06:22 AM   #550
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Hey Tinman! Nice to hear that you are still having fun with the Cruiser.
For sure lots of opinions on tires here. I'll share mine with you. If I had your Cruiser, I'd probably put a pair of the Yokohama RY 215 7R15 LRD tires on it.
Have fun!
Lance
Top is offline   Reply With Quote
Old 01-16-2016, 12:57 PM   #551
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Have fun!
Thanks Top, I will check those out, it's good to have a couple options!
Old 08-13-2016, 11:54 PM   #552
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
New AC
We have needed a bit more cooling in the Cruiser, the unit under the bed worked ok but just couldn't get it comfortable on both ends of the trailer. So for now until a better option is found we decided to install a unit on the roof, I had installed a drain line and wiring when I did the restoration. The new look will take some getting used too but nice to be able to camp anytime!
ID:	269026   Click image for larger version
ID:	269030   Click image for larger version
Old 08-14-2016, 09:19 AM   #553
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
That's a tough pill to swallow visually, I sympathize --- however, it'll feel a bit less painful when you're not dabbing sweat from your brow. Looks like a nice install, well done.
bredlo is offline   Reply With Quote
Old 08-14-2016, 02:52 PM   #554
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks Brad,
Definitely not the looks we want but it will be nice to get it cool inside. I would take it off today if I could find good and quiet down vented unit I could install inside. I am surprised that the industry hasn't come out with a quiet rooftop unit?
Old 08-14-2016, 03:26 PM   #555
1954 26' Romany Cruiser
jefferson , Oregon
cruiser
Looks good Doug,
I plan on putting one on my cruiser also. I didn't install the drain tube. Not too late I guess. Where does the tube go when it reaches the floor? Did you drill a hole and run it through the floor? Is it totally necessary or can the evap run down the outside? Cheers, Mike
Stanley29 is offline   Reply With Quote
Old 08-14-2016, 06:00 PM   #556
bredlo's Avatar
1954 22' Safari
Sure, but thinking about most typical SOBs - and the priorities of their buyers - I'd bet air conditioner shrouds rank low on their list.
As for the new ones, it looks like they've more or less moved entirely to the ducted versions first seen on the Land Yacht a couple years ago. I seem to recall the unit itself sat in a shallow recess, too... making it further disappear. Now that would be a hell of an upgrade to a 50s unit.
Old 08-29-2016, 08:49 PM   #557
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
New aluminum and rivets!
Made up a new refrigerator door panel tonight, its been on the list for quite a while!Fun project!
ID:	270336   Click image for larger version
Old 08-29-2016, 09:08 PM   #558
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
so cool, great job.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 08-29-2016, 09:44 PM   #559
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Very nice.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-31-2016, 05:11 AM   #560
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Very cool & creative!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 09:05 PM
