03-30-2014, 06:27 PM
#541
1954 25' Cruiser
Cruisin
, Wisconsin
Originally Posted by BradS
You sure seem to stay busy improving Nellie. Jennifer told me we get to see you guys soon. I'm looking forward to it I'm curious about your new heater and all your other improvements. I love the shower floor. It's beautiful
Thanks Brad, Jan and I are looking forward to reviewing travel plans with you two, camping season is fast approaching!
10-27-2014, 10:34 AM
#542
1954 25' Cruiser
Cruisin
, Wisconsin
Three years on the road
After using our 1954 Cruiser for three seasons and close to 10,000 miles, we must say we would go through the restoration process all over again.
We have met so many great people and learned so much. There are so many days spent thinking about just heading out on the road and leaving the day to day stresses behind! We look forward each summer to a new direction and new experiences.
About three weeks ago the Cruiser had the honor of hiding our new daughter in law before our sons wedding, it was a perfect fall day. Nellie is part of the family and it was an honor when our Daughter in law asked to use her!
The biggest problem I have had was water leaks from the fantastic vents front and back. I removed the vents several times without fixing the issue, fantastic sent me out new housings at no charge(they have improved them) and so far has fixed the problem. Also I would not use Vulkom caulking anymore because that seems to not adhere to the aluminum after a couple years. Otherwise checking the trailer over before each trip has led to no breakdowns on the road, with lots of luck and someone watching us from above this will continue!
For now Nellie is all winterized and ready to hibernate in the barn for another cold Wisconsin winter!
10-27-2014, 11:02 AM
#543
2006 22' International CCD
1957 26' Overlander
Plymouth
I didn't realize that you had doors on the barn. How nice. Is Nellie's new room mate in there as well?
I brought Holly's frame home this weekend. Someday the body will be reattached
10-27-2014, 11:28 AM
#544
1954 25' Cruiser
Cruisin
, Wisconsin
Hey Brad, The doors were a bonus from the wedding, the barn was the back up plan if it rained. I was forced to stop working on aluminum and finish the barn,Its nice to have them done. Unfortunately Nellie and Mae don't get along so since Nellie is older and bigger so she wins and gets to be warm and kozy inside
10-27-2014, 03:18 PM
#545
Florissant
, USA
Very cool to use it in the wedding!
10-28-2014, 12:55 PM
#546
used to have rivets
1953 25' Cruiser
1967 24' Tradewind
Sacramento
You say you would do it all over again, but does that include building another barn?
10-28-2014, 02:18 PM
#547
1954 25' Cruiser
Cruisin
, Wisconsin
Another barn, that's a great idea! At least an addition on both sides would be good, more room for aluminum!!
03-06-2015, 04:13 PM
#548
WESTPORT
, Massachusetts
Great job!
01-15-2016, 04:54 AM
#549
1954 25' Cruiser
Cruisin
, Wisconsin
Tune up time
We have traveled with the Cruiser about 12000 miles in in the last four years and tires are a little over 6years old so I thought it is time for new tires more because of the age? We used Goodyear Marathons the first time around and seemed to work just fine. We are thinking about a 5000 mile trip to Oregon in May and I like to avoid any potential problems! Always fun prepping for the first trip of the new year! I will probably use the same tires unless anyone has something better, I know there are many opinions on this.
01-15-2016, 06:22 AM
#550
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Hey Tinman! Nice to hear that you are still having fun with the Cruiser.
For sure lots of opinions on tires here. I'll share mine with you. If I had your Cruiser, I'd probably put a pair of the Yokohama RY 215 7R15 LRD tires on it.
Have fun!
Lance
01-16-2016, 12:57 PM
#551
1954 25' Cruiser
Cruisin
, Wisconsin
Have fun!
Thanks Top, I will check those out, it's good to have a couple options!
08-13-2016, 11:54 PM
#552
1954 25' Cruiser
Cruisin
, Wisconsin
New AC
We have needed a bit more cooling in the Cruiser, the unit under the bed worked ok but just couldn't get it comfortable on both ends of the trailer. So for now until a better option is found we decided to install a unit on the roof, I had installed a drain line and wiring when I did the restoration. The new look will take some getting used too but nice to be able to camp anytime!
08-14-2016, 09:19 AM
#553
1954 22' Safari
Deerfield
That's a tough pill to swallow visually, I sympathize --- however, it'll feel a bit less painful when you're not dabbing sweat from your brow. Looks like a nice install, well done.
08-14-2016, 02:52 PM
#554
1954 25' Cruiser
Cruisin
, Wisconsin
Thanks Brad,
Definitely not the looks we want but it will be nice to get it cool inside. I would take it off today if I could find good and quiet down vented unit I could install inside. I am surprised that the industry hasn't come out with a quiet rooftop unit?
08-14-2016, 03:26 PM
#555
1954 26' Romany Cruiser
jefferson
, Oregon
cruiser
Looks good Doug,
I plan on putting one on my cruiser also. I didn't install the drain tube. Not too late I guess. Where does the tube go when it reaches the floor? Did you drill a hole and run it through the floor? Is it totally necessary or can the evap run down the outside? Cheers, Mike
08-14-2016, 06:00 PM
#556
1954 22' Safari
Deerfield
Sure, but thinking about most typical SOBs - and the priorities of their buyers - I'd bet air conditioner shrouds rank low on their list.
As for the new ones, it looks like they've more or less moved entirely to the ducted versions first seen on the Land Yacht a couple years ago. I seem to recall the unit itself sat in a shallow recess, too... making it further disappear. Now that would be a hell of an upgrade to a 50s unit.
08-29-2016, 08:49 PM
#557
1954 25' Cruiser
Cruisin
, Wisconsin
New aluminum and rivets!
Made up a new refrigerator door panel tonight, its been on the list for quite a while!Fun project!
08-29-2016, 09:08 PM
#558
1960 24' Tradewind
Folsom
so cool, great job.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
08-29-2016, 09:44 PM
#559
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Very nice.
Hittenstiehl
08-31-2016, 05:11 AM
#560
1964 17' Bambi II
Schererville
, Indiana
Very cool & creative!
Becky
1964 Bambi II
1988 Avion 32S
