Old 03-21-2011, 05:09 AM   #197
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I like where your water hook up is Doug. There you go making me think some more.
Tim got home this weekend, asked about our visits. Would you be interested in having visitors for a couple of hours maybe next weekend?
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-21-2011, 09:22 AM   #198
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Sounds great! Always good to bounce a few more ideas around.
Sunday afternoon might work the best.
Doug
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-21-2011, 03:12 PM   #199
BradS's Avatar
1957 26' Overlander
Images: 14
Sunday would work best for me as well. Ill chat with Tim and get back to you
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-21-2011, 09:34 PM   #200
used to have rivets
1953 25' Cruiser
1967 24' Tradewind
Sacramento , California
I am sure any day your great work will get me motivated.
Did you consider putting the hinges up and the latches down? What are the drawbackd of that? The latch is pratical, lockable, and readly available, but did you see any others that would work?
I too really like the water supply/hose storage, and the quick couplier will be great.
Bruce
TooMuchTin is offline   Reply With Quote
Old 03-22-2011, 09:15 PM   #201
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Bruce
Thanks Bruce,
Its the people I meet and the great work I see on here that keeps me motivated. That and work lately has not been easy, so the cruiser has been good therapy.
I didn't really consider the latches on the bottom, I wanted them easily accessible and to have the doors out of the way when open. I will put a little rain gutter on top to help seal them. So just a preference I guess.
Doug
Old 03-23-2011, 08:39 PM   #202
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Rock guard and door cap
Kind of a miserable snowy/rainy day here in Wisconsin 55, sunny and grass showing last week, snow, ice and bad winds today. I spent a little time in the shop today making a rock guard for the front window and a new rain cap for the door.
Name:	airstream rock shield 001.JPG
ID:	125186   Click image for larger version
Name:	airstream rock shield 004.JPG
Old 03-23-2011, 08:52 PM   #203
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Wow- a pleated/segmented rock guard! That's very cool!!
Rae
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 03-23-2011, 09:27 PM   #204
Byams55FlyCl's Avatar
Centrally Located , Wish you were here!
Please share your secret?
Very very very Cool!
Great idea, and super use of a wintery spring day.
How does it attach and remove?
WBCCI & TAC
Goin' Vintage!
Kathy
http://byams55flyingcloud.blogspot.com/
Byams55FlyCl is offline   Reply With Quote
Old 03-23-2011, 09:32 PM   #205
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Rae
Thanks Rae
Old 03-23-2011, 09:39 PM   #206
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The top slips into the hinge and the bottom will have two stainless studs attached to the windows with wing nuts. The P.O. had screwed the window shut so the holes for the bolts in the corners were already there.
Doug
Old 03-24-2011, 06:03 AM   #207
BradS's Avatar
1957 26' Overlander
Images: 14
Wow Doug. I cant wait till Sunday. I have been actually working this week so I feel like I am getting very little done. I love the rock guard !!!
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-26-2011, 09:03 PM   #208
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Front belly pan and rub rail
Started working on the front belly pan today and it has been as much of a challenge as I thought it would be. I ended up cutting it into sections, just would not slide up into place like I wanted it to. I've seen lots of pictures of others struggling with it and now I know. Definitely would be easier before the top goes back on!
It ended up ok, not quite as smooth as I would like. After the new rub rail was on it looked better.
Also made rain caps for the storage doors.
Doug
Name:	airstream rub rails 001.JPG
ID:	125427   Click image for larger version
Name:	airstream rub rails 003.JPG
Name:	airstream rub rails 004.JPG
Old 04-23-2011, 08:06 PM   #209
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Lots of little things
I have not posted for a while but really have been working on lots of time consuming things on the outside. Lights, belly pan, patching holes and installing new rub rails all around. I rebuilt all the marker lights and the license plate light and installed a couple of work lights front and back where some old holes were.
Now I can move back inside and finish some sealing on the seams and start installing the interior skins. Also received the new tanks.
Doug
Name:	4-23-11Airstream marker light, rub rail 001.JPG
ID:	127969   Click image for larger version
Name:	4-23-11Airstream marker light, rub rail 007.JPG
Name:	4-23-11Airstream marker light, rub rail 008.JPG
ID:	127971   Click image for larger version
Old 04-23-2011, 09:42 PM   #210
pbearsailor's Avatar
Port Hadlock , Washington
Lookin' good, Doug. Like that rub rail!
Sometimes you can just be too busy doing stuff to post.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 09:05 PM
