Old 10-11-2010, 06:59 PM   #155
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The last 4
The last of major rivet drilling!! Hit it right after work tonight and got the last 4 windows drilled out. Loving the fall weather around here 75degrees today, 3 inches of snow last year! Everyone is in a great mood.
Name:	Last of airstream windows 005.JPG
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 10-11-2010, 07:11 PM   #156
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Evening Doug
That has to feel good!
Did Tim tell you we rented shop space together. We get it for 6 months starting in November. If Im lucky ,Ill be telling you about my new endcaps before spring.
Your work looks great! Please keep it up
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 10-11-2010, 09:07 PM   #157
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by BradS View Post
Evening Doug
Sounds great Brad, I am sure you are excited to get started. I am hoping to get the outside pretty well finished up on the cruiser and work on the inside over winter.
I will be looking forward to watching those endcaps loose those wrinkles.
Old 10-12-2010, 06:10 AM   #158
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Looking good Doug! Not the best window design, but I bet you are glad to soon be done. What are you working on next? I am anxious to get back working on May starting in November. I have to pull the interior end caps out. It's time to start bucking rivets for me too. Shout if you need any bucking help.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 10-13-2010, 04:38 AM   #159
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks Tim, I can see the advantage of rebuilding a smaller trailer, fewer windows! Next I have a little work left on the belly pan then wiring and the inside skins. we will see how the fall goes.
Old 10-16-2010, 06:57 PM   #160
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The last Window gaskets
Finished installing gaskets on the last 4 windows today, I am very glad to be done with them!!! I only had a little over 1 inch of window gasket left out of 48 feet of material! It was a good way to finish!
Name:	Last of airstream windows 003.JPG
ID:	113225   Click image for larger version
Name:	Last of airstream windows 001.JPG
Old 10-17-2010, 11:24 AM   #161
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Windows done!!!
If I do another trailer some day I think I will avoid another 50's trailer!!
good to be done with the windows!
Time to move on, what next?
Name:	windows done!!! 001.JPG
ID:	113262   Click image for larger version
Name:	windows done!!! 004.JPG
Old 10-31-2010, 06:52 PM   #162
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Pumpkins
A little carving fun tonight!
Old 10-31-2010, 07:51 PM   #163
BradS's Avatar
1957 26' Overlander
Images: 14
Very Nice Doug
Tim and I put our trailers into the shop today. As soon as my boss turns his back tomorrow, Im gone!
WBCCI 10289
TAC MN-69
AIR 11240
Old 11-01-2010, 06:53 AM   #164
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Like the Pumpkin Doug!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 11-06-2010, 09:00 PM   #165
used to have rivets
1953 25' Cruiser
1967 24' Tradewind
Sacramento , California
Let me add my appreciation for your work, perserverance, and posting. I started my '52 crusier 4 years ago. Took the shell off, pulled the frame out and stopped. Yesterday, I finally cleared a path to the frame and decieded to start again. So, I came back to the forum after a couple years, and saw your great thread.
I like the idea of you being a couple steps ahead, so I can can steal your ideas.
TooMuchTin is offline   Reply With Quote
Old 11-07-2010, 06:05 PM   #166
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Thanks Bruce, I took almost a year off also, it is quite a project to get done and with all the other responsibilities of life, it is hard to keep up the momentum. I Looked at your old thread and look forward to the updates and pictures. I don't know if I will have much that will be worth stealing. I am not as meticulous with my work as some of the others on here. The inside layout will be of our own design also, we will see. Might be 2020 before it is done, until then its just something that I can spend all my extra money on.
Doug
Old 11-15-2010, 05:08 PM   #167
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
More Progress
I made a little more progress lately, installed two fantastic fans, two new taillights from Vintage Trailer Supply - Vintage travel trailer parts and supplies!, installed the last of the six storage bins in the belly pan and painted the floor inside. Gathering pieces for wiring now. I guess we will have to decide on a final layout now.
Cooper got too involved with the painting she likes working on the cruiser as much as I do!! White would not have been the first choice for floor colors but I had a gallon already so it was nice to use it up.
Just received the last vent from VTS, that will seal up the last roof hole. The only other hole is the rear storage door, which is in pretty tough shape, I think I will have to rebuild that.
Name:	new coat rack, snow, projects 090.JPG
ID:	115318   Click image for larger version
Name:	new coat rack, snow, projects 094.JPG
Name:	cruiser curb side 006.JPG
Old 11-16-2010, 05:33 AM   #168
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I like the progress Doug. You have to love the Terriers. They always like to think they are bigger dogs then they are. I bet Cooper and our Zeke would like each other. We'll introduce them at a camping event in the near future! At your rate, you'll be camping in the '54 real soon.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 08:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 06:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 11:21 AM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 09:05 PM
