Old 06-24-2010, 05:48 PM   #141
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
One or Two Axles
Originally Posted by cruiser54 View Post
I wanted to build in in my Cruiser a double axis. Airstream4u in Hamburg has advised me! More difficultly to maneuver, more weight, Silouette of the Cruiser not more so harmoniously.... etc.
Greetings from Switzerland
Werner
Werner,
The classics should be left as they were made.
However, if a well traveled, common edition were to be retrofitted, I say go for 2.
Here, high speed highway stability and ease of tire change after a flat are positives.
Driving with a flat is sometimes mandatory for safety.
In a land of short distances and twisting narrow roads I would still go for 2 axles.
I like 4 wheel brakes versus 2. But then again I like fat girls and mopeds.
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 06-24-2010, 09:14 PM   #142
OO , OO
Send a message via Skype™ to cruiser54
The translation of your text gives no sense for me.
Question: 2 axes, for it or against it?
Werner who wants to learn here also English....
cruiser54 is offline   Reply With Quote
Old 06-25-2010, 09:29 PM   #143
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Talking Who Me?
Ok, to be perfectly clear...... it depends.
He who calls the tune, pays the fiddler.
A classic year that is getting a bottom to top restoration, leave it at one axle.
Then go buy an Airstream to travel in, leave the museum piece at home.
If you are going to drive a million miles, go on a Wally Byam Caravan, have a kid(s) bouncing on the floor, going on on safari to the wilds of Italy, travel on winding roads, get 2 axles.
I do not know how many one axle guys tell me they wish they had two axles.
Axle envy I think it is called. Ever have a tire blow out with one axle? It is easier to survive a blow out with 2 axles, ever have a flat tire in a bad part of town, give me 3 good tires to get away rather than one tire. Want to change a tire with 2 axles, just roll the good tire up on a ramp and change the flat, no jack needed.
2 axles for me, unless I had a sweet old Airstream with one axle that I took to meetings to show off... then of course One axle trailers are the absolute best in the world.......
Werner, please let us know what you choose, Airstreamers are international.
Cruiser54 what is your opinion?
Old 06-26-2010, 09:12 PM   #144
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Axle
Originally Posted by 51cruisette View Post
Has anyone every changed a trailer from a single axle to a double or is it necessary on a 55 Cruiser?
Erica
I have read alot about the advantages of having duel axle's and it does have it's benefits like fastrob say's next but I don't think I would want to change the outward appearance of our cruiser like that. I have had blow-outs on 2 different single axle trailers(not airstreams), one at 60mph on a curve and had to pull our camper an extra 1/2 mile before stopping at a safe spot and really caused no damage other than the tire and an excited driver behind us. I plan on towing our cruiser across the country when done and i am not concerned about the single axle.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 07-17-2010, 05:37 PM   #145
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Windows and vents
Had a few hours over the last couple weeks, removed all 3 vents and cleaned up around the openings. Looks much better, I need to call Vintage Trailer Supply and get one more vent assembly. I was planning on using one of the originals with the aluminum top but it ended up not in very good shape.
Ugly vents are gone!! New fantastic fans are in place. one with a rain sensor and one without.
The old gaskets are built into windows, which requires drilling out the rivets holding the windows in.
Two windows down and nine to go.
T
The Aluminitus is coming back, starting to turn an aluminum color!!
Old 07-18-2010, 08:17 AM   #146
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Looks great Doug!
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 08-30-2010, 06:19 PM   #147
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Wow, Doug your doing a great job. I just bought 53 Cruiser last night. I am very scared of the shell off. I was thinking of just doing the rear, the middle and then front in sections. Since I will being working solo.
Would you do the shell off again or in sections? Can you post photos of the door step area? Mine has been "fixed" by a PO and not sure what it should look like.
nick6930 is offline   Reply With Quote
Old 08-30-2010, 06:53 PM   #148
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
It looks great Doug Please keep inspiring us/me with more updates. I have done very little other than dream. I hope to get started soon, although that may be just a dream as well.
Keep up the great work
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 08-31-2010, 06:30 AM   #149
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Hi Nick
It was a lot easier to take the top off I think and get it out of the way.
If I had the free time I would do it all again. Things have slowed up a lot due to the happenings of life, aging parents and lots of family things. I get about 4 hrs a week on the cruiser. it has been 2 yrs. now and it is still fun to work on.
I am about half way done with rebuilding the windows. It has been taking me about 4-6hrs per window and with 12 to do it has been slow.
The only pictures I may have of the step area is of the frame on here, we had to switch computers a while back so I am not sure about the old pictures.
Hey Brad,
Good to see you are still out there, we keep waiting to see pictures of the overlander all fixed up!!
Old 10-03-2010, 09:11 AM   #150
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Curb side windows/belly pan
Pretty well finished all the curb side windows and belly pan yesterday. I pulled it out of the barn for a quick picture and to turn it around to start the other side 5 more windows to go. The good part is I am getting faster as I go through the windows!! I also added 3 small storage areas in the belly pan and plan for 3 more on the street side. Work is slow but still gaining.
Bucked my first rivets putting the windows and rain gutters back on, actually goes a lot easier than I thought, quicker then pop rivets!
First frost here today, perfect airstream working weather for the cruiser.
Name:	cruiser curb side 002.jpg
ID:	112235   Click image for larger version
Name:	cruiser curb side 005.JPG
Name:	cruiser curb side 010.JPG
ID:	112237   Click image for larger version
Name:	cruiser curb side 004.JPG
Old 10-09-2010, 06:58 PM   #151
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
So tired of windows!
Three more windows done today. They are getting pretty old, after 3 vents, 7 windows, and an average of 45 rivets each it just isn't as much fun anymore. Four windows left. I am getting faster anyway, about 2-3hrs each now.
Name:	windows, Ben,Dave,Nicki 017.JPG
ID:	112759Click image for larger version
Name:	windows, Ben,Dave,Nicki 010.JPG
Name:	windows, Ben,Dave,Nicki 009.JPG
ID:	112760Click image for larger version
Name:	windows, Ben,Dave,Nicki 016.JPG
I also had a little polishing help from my 13year old niece, Thanks Nicki.
Name:	windows, Ben,Dave,Nicki 021.JPG
Old 10-09-2010, 07:58 PM   #152
Kirk T's Avatar
1956 26' Cruiser/Overlander
1957 26' Overlander
Alva , Oklahoma
Do you want to part with whats left of your old vents?
Kirk T is offline   Reply With Quote
Old 10-10-2010, 07:35 AM   #153
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
vent
Hi Kirt, the vents I took off were not original. It did look like they had 50 years of caulking on them. About the only thing they are good for is an ugly vent contest!!
Old 10-10-2010, 07:58 AM   #154
Kirk T's Avatar
1957 26' Overlander
Alva , Oklahoma
Ok. Thank you. Your rig is looking good. I am looking forward to working on mine.
1954 cruiser, 25'
Got a new axle on my and I am not sure what I got rustyrivet Axles 3 11-26-2008 09:44 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 09:27 PM
Just got home with our Argosy.... Moonshot All Argosy Trailers 18 09-14-2004 07:41 PM
Got to ask.. Have I got Frame seperation? JohnG Repairing/Replacing Floor &/or Frame 7 07-23-2004 12:21 PM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 10:05 PM
