10-07-2018, 11:13 AM
#21
1976 31' Sovereign
Oswego
I have across pu bed tool box that I mounted 12 volt winch on side of tool box. Made ramp of plywood w/2/3 on edge on out side edge to stiffen & eye bolt one and of Each 2by, then hook w/motor cycle style straps hooked at corner of bed keeps ramp from sliding off when unloading, then winch gen. in out also use for for other things to heavy to lift. Have 4/8 bed 1 sheet plywood fits no cuts.
10-07-2018, 11:19 AM
#22
1976 31' Sovereign
Oswego
Originally Posted by jschloo
if you can live without Air conditioning, you can do like we did and use our CarGenerator. its just 16 pounds, attaches to the front of your tow vehicle whenever you need power, and produces up to 1000 watts which will easily high speed recharge your batteries, run TV's all lights, etc... available from Airstream factory, or Amazon, or direct from the website. we have 520 watts of solar on the roof but its not enough or when you have cloudy rainy days.
Also Harbor Freight tools has 900 watt 2 cycle gen that will do same plus small micro wave oven but no ac. Cost under $100.00 & very lite wt.
10-07-2018, 01:42 PM
#23
2005 28' International CCD
Pagosa Springs
I use this
I use this manual crank one. There’s also a 12 v one
https://spitzlift.com/pickup-trucks/
"would you rather have a mansion full of money or a trailer full of love?"
10-07-2018, 01:48 PM
#24
2018 30' Classic
Jacksonville
In this order...…...mind, machine, muscle
1. I get my young wife, the farmer's daughter, to lift it.
2. I go back to primary machines and put a 2x lumber from tail gate to ground and slide the generator up the incline plane. Works for the big open frame Subaru generator.
3. I go to the shop and get the steel ramps out and wheel the generator up the ramps.
4. I just pick up the Champion 3400, lighter. I'm still in decent shape. Untill one through three doesn't work.
Oh that, I've been doing this since 2012. I've only used the generator at the house after Hurricanes/Tropical storms. You don't have to go to places that don't have power.
10-07-2018, 02:30 PM
#25
2011 27' FB Classic
varies
, changes constantly
Originally Posted by Docv
I worry about the heavy lifting of stuff like a generator into my truck bed.
Are there any gadgets to help with that?
Docv
Meandher Ford F-250 towing a classic 30 foot twin soon
We have a bed slide and a Harmar wheel chair lift, all fits under a campershell. Not a bargain solution but it’s been working for us since 2011 to lift the Yamaha 3000 and many other heavy items.
Good luck 😎
10-07-2018, 06:50 PM
#26
Carrolton
, Georgia
Another option for your generator
I read about this in a magazine. I plan to buy one for my TV, F-350. Going to run it in carrier with long cord.
Ken Blitchington
Amazon
TorkLift A7752
Take a look.
10-08-2018, 04:04 AM
#27
2010 27' FB Classic
N/A
Ken Blitchington
Amazon
TorkLift A7752
Take a look.
Ken,
Please post a picture of the carrier and generator mounted on your truck, once you get it all rigged up. Are you planning to leave the long cord attached under your truck then just plug into the trailer when needed?
Thanks!
