09-25-2018, 04:53 PM
meandher
2021 27' Globetrotter
Miami
Getting older
I worry about the heavy lifting of stuff like a generator into my truck bed.
Are there any gadgets to help with that?
Docv
Meandher Ford F-250 towing a classic 30 foot twin soon
09-25-2018, 04:59 PM
2015 27' Flying Cloud
Newberg
, Oregon
400-500 watts of solar on the roof and lithium batteries come to mind. At a price. Or, making sure you always have shore power.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
09-25-2018, 05:38 PM
2007 22' International CCD
Corona
Or one of those winches that can be installed in the bed of the pickup truck. Harbor Freight is one of many sources...
09-25-2018, 05:49 PM
1994 34' Excella
Warren
, Manitoba
I just found a helpful item for the truck. Check out the Traxion tailgate ladder. Just ordered one to try. Looks like a great idea, rather than the under bumper steps that fold out, that you can't use when the Rock Tamers and hitch are on the truck. Not a lot of money from Amazon, and worth a try!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
09-25-2018, 06:08 PM
Storm Master
2005 25' Classic
Austin
I second the bed crane. They fold up pretty narrow and out of the way. I found a good deal on a used electric wheelchair lift and modified the base to fit in the passenger side corner of the bed. Main reason I wanted a bed crane was just in case I got injured or threw out my back I could still manage to load and unload the gen set, hitch stinger, heavy things my wife buys etc.
09-25-2018, 06:17 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Leave the generator in the bed of the truck .....
09-25-2018, 06:27 PM
2007 23' Safari SE
2016 23' International
Fernandina Beach
google Lift Table. Lots of designs, and the Cart type make an excellent storage platform for the garage. Thinking about one myself.
09-25-2018, 06:57 PM
1987 32' Excella
Nepean
, Ontario
I bought an el-cheapo bed crane that uses a bottle jack to swing the arm up, from Harbor Freight about 5 years ago and had it mounted rear curbside in the bed just a few inches from the tailgate. They guys who mounted it positioned it to be over the frame and bolted through to the frame. Makes hauling my 3000-watt el-cheapo generator (also from Harbor Freight) a piece of cake.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
09-25-2018, 08:09 PM
2011 27 FB International
Tucson
Pictures???
09-25-2018, 09:32 PM
Tampa
Sure.
Here's what I use and I have a 145# generator.
It's a hydraulic table from Harbor Freight, 1000# capacity (because it goes higher) I leave the generator on it in the garage, lowered. Then I roll it to the truck, raise it up with a foot pedal, about 15 pumps, and scootch the generator into the bed. It remains there until I'm home and reverse the process.
The thing is built like a tank, and I used a 20% off coupon to buy it.
09-25-2018, 11:03 PM
Salem
, Oregon
Hi, I have a Yamaha 2400 generator. It weighs about 75 lbs. I can, and have lifted it, but I have off and on back problems so I don't push it. I modified a small mover's dolly to fit the rubber feet on my generator and store it in my garage like this. I also have a plywood ramp that I made about 30 years ago. I lean the ramp on my tailgate and push my generator, on the dolly up the ramp into the bed of my truck. I have a tie down system which holds my generator in the bed where it stays while traveling. I run my generator while in the bed.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
09-26-2018, 05:33 AM
Lin
, Ne
Docv
Forget the gadgets, just ask for help.
09-26-2018, 07:14 AM
meandher
Miami
can it just mount on the bed or does it need reinforcement , I don't think I will be lifting more then 150 lbs at a time
tks
09-26-2018, 01:33 PM
1987 32' Excella
Nepean
, Ontario
This is the crane I bought:
https://www.harborfreight.com/12-ton...ane-60732.html
It needs to be through bolted to the frame.
VE3JDZ
AIR 12148
WBCCI 8080
09-26-2018, 06:09 PM
2010 27' FB Classic
N/A
Originally Posted by Mollysdad
Sure.
I like your idea, thanks for posting the picture along with the info about the hyd. table.
09-27-2018, 07:18 AM
meandher
Miami
how much can you lift with it?
09-28-2018, 07:43 AM
1987 32' Excella
Nepean
, Ontario
The beam of the crane extends. With the beam pushed in: 1,000 lbs; with the beam fully extended: 500 lbs. The mechanism is very simple - it uses a bottle jack to raise and lower the beam. There is a pin to set the length of the beam and another to secure the rotation of the beam for travelling. When I bought mine HF had a 50% off coupon, so it only cost me $50 to buy it. The tech who installed it charged me $50 as well - best $100 I ever spent.
VE3JDZ
AIR 12148
WBCCI 8080
10-01-2018, 12:07 AM
DawnLuvsPossums
2016 16' Sport
Gainesville
[emoji173]TY![emoji173]
I'm disabled and had to sell my AS because of it (even lifting my honda 2000s is out of the question!). Now I'm in a van, but still having to find solutions for being unable to lift anything. This could just be not only the answer for me, but an AFFORDABLE one at that!
10-01-2018, 12:34 AM
DawnLuvsPossums
2016 16' Sport
Gainesville
Re: Hydraulic table
Originally Posted by luvspossums
[emoji173]ty![emoji173]
i'm disabled and had to sell my as because of it (even lifting my honda 2000s is out of the question!). Now i'm in a van, but still having to find solutions for being unable to lift anything. This could just be not only the answer for me, but an affordable one at that!
10-07-2018, 10:50 AM
Anna Maria
Sure.
That looks like a winner. How heavy is the table ?
