Old 11-20-2011, 12:16 PM   #1
1954 25' Cruiser
Marshfield , Massachusetts
Blasting Off!! '54 Cruiser...Back To Life...
OK...My wife Debbie and I bought this '54 Cruiser from: VintageCampers.com :: Vintage Campers, Vintage Trailers, Vintage Parts, Vintage Restorations
We bought the camper in Dec of 2010 and Debbie drove from MA to Peru, Indiana last month and towed it back home. Our plan is to completely redo it, shell off. We have always had trailers in our lives and recently sold our 2006 Airstream CCD Bambi so we'd have room in the driveway for the Cruiser.
Between 2005 and 2010 I built an airplane that I now have 72 hours on. I am very familiar with aluminum due to that project and have all the required tools plus some additional ones that I know will come in very handy.
I have moved the trailer into our airplane hangar, which is heated, so we can work on it over the winter. The Cruiser was in very good shape for its age and you can check out some before pics on this link: '54 Airstream Cruiser
All the pictures that appear in this thread will also be on that website, so go there if you want to see higher resolution. The pics below show the trailer in the hangar and the interior with current status.
Right now we have started the demo and have everything out except the wetbath, the broom closet and the upper aluminum cabinets. As we progress I will update this thread. I have reviewed many of the other rehab threads on the forums and those have been invaluable for me in formulating the plan of attack here.
Thanks for looking...Don and Debbie
Name:	DSC01978 (1024x768).jpg
ID:	145669   Click image for larger version
Name:	DSC01980 (1024x768).jpg
Name:	DSC01981 (1024x768).jpg
ID:	145671   Click image for larger version
Name:	DSC01976 (1024x768).jpg
Name:	DSC01977 (1024x768).jpg
Don...
1954 Cruiser
http:www.donsbushcaddy.com
54Cruiser is offline   Reply With Quote
Old 11-24-2011, 09:39 PM   #2
Tool Hoarder
West , California
Hi Don
Looks like a great project. So whats the plan? Shell on or off? Hows the frame?etc. With your experiance with plane building, this project should be up your alley. That rivet squeezer is very handy indeed. I also love all my air drills and guns. A mig welder comes in handy as well. Good luck, keep it comming!
marzboy is offline   Reply With Quote
Old 11-28-2011, 07:38 PM   #3
1954 25' Cruiser
Javier,
The plan is shell off...or at least up enough to get the old floor out and the new one in. I haven't seen the frame yet but my feeling is it's in good shape, nevertheless I'll be strengthening it in certain areas. I need to learn to weld, my airplane was all aluminum...no welding just 10,000 or so rivets. If you think that manual rivet squeezer is a good tool wait til you see my pneumatic squeezer Invaluable. Before I picked up the trailer from vintage campers I had them replace the axle with a torsion bar variety so that's done.
I'll be back at it this weekend.
Don...
1954 Cruiser
Old 01-13-2012, 01:01 PM   #4
1954 25' Cruiser
Ok, the holidays are over and we're back on track. Interior demo is now complete. No real mysteries here, the wet bath was kind of a chore getting out and the hunk of pipe sticking through the floor will stay in place until I take the floor out...big piece of galvanized pipe hanging though the belly skin. I cut out the corners of the shower enclosure from top to bottom...about 4" of each side. I may end up re-using these to make sure I get a good seal at the corners when I construct the new bath, at the very least they will give me a good template for the curve of the shell.
ID:	148803   Click image for larger version
Don...
1954 Cruiser
Old 01-14-2012, 02:13 PM   #5
1954 25' Cruiser
Debbie went down to the hangar on Friday morning and drilled off all the lower interior skins. So far I have to say I think I got a real gem. There is one spot of corrosion which you can see in one of the pics that goes right to daylight, the area where daylight can be seen is part of the belly wrap, not the exterior skin. The interior corners with the segmented U channel are all in great shape. The floor does have some holes as you can see but it is being replaced (of course) anyway.
Next steps are to drill off the banana wrap, drop the belly skin, brace the interior and raise the shell. Not this weekend though...24/7 football from here on out. GO PATRIOTS!!!! Debbie and my daughter Jesse are going to the game, while I eat ribs on my neighbors couch
Name:	AC1 (1024x768).jpg
ID:	148893   Click image for larger version
Name:	AC2 (1024x768).jpg
Name:	AC3 (768x1024).jpg
ID:	148895   Click image for larger version
Name:	AC4 (1024x768).jpg
Don...
1954 Cruiser
Old 02-14-2012, 08:37 AM   #6
Tool Hoarder
West , California
Make sure that you brace the shell before you disconnect the ribs from the frame. Also make really accurate measurements where the ribs connect to the outriggers. Dont ask me why....
Old 02-20-2012, 03:20 PM   #7
1954 25' Cruiser
Javier...wise advise is always heeded, I will be at that point very soon so I will do that. I also plan to take some good measurements so I know where the shell should be once I lower it back down. Thanks.
Continued with drilling out all the lower perimeter solid rivets, very tedious work but it's done. After building the airplane if there's one thing I know about it's drilling out rivets. Blind rivets are obviously easy to drill out, just put the drill bit in the hole and go at it. Solid rivets are another story. The mistake most people will make is they think they have to drill right through...you don't. All you really want to do is snap off the head as this will protect the integrity of the hole. There is a small dimple on solid rivets and you should carefully place your drill bit on that, start slow and drill no more than 1/8th inch deep. Then insert a 1/8th punch in the hole and snap off the head. Then still using the punch, bang it with a hammer to remove the shop head from the other side of the aluminum. I have tried many different methods and this is the best for not compromising the hole. Invariably you will screw one up and you'll need to use the needle nose vice grips to yank it out.
Anyway the entire perimeter is done. The four hidden rivets where the front and rear quarter panels meet up with sides are also out. All that needs to done now is to cut off one rivet on the inside bottom of each rib where it attaches to the C channel and it will be time to lift.
Name:	DSC02049 (1024x683).jpg
ID:	151588   Click image for larger version
Name:	DSC02052 (1024x683).jpg
Name:	DSC02054 (1024x683).jpg
ID:	151590   Click image for larger version
Name:	DSC02055 (1024x683).jpg
Don...
1954 Cruiser
Old 02-20-2012, 03:23 PM   #8
1954 25' Cruiser
Few more pics from the work today. As always Mrs Enterprise (Debbie) is right along side me. She focussed on removing screws holding the C channel to the floor while I drilled out the rivets on the perimter. I was really psyched that the wheel well trim survived the removal process...should be able to clean these up and reattach.
Name:	DSC02048 (1024x683).jpg
ID:	151592   Click image for larger version
Name:	DSC02056 (1024x683).jpg
Don...
1954 Cruiser
Old 02-22-2012, 03:51 PM   #9
Tool Hoarder
West , California
Great work! Nice to see that the little lady is gettin in on the action. Cant hog all the fun to ourselves now can we. With all those solid rivets you may want to purchase this tool. It makes drilling out solid rivets a snap!
Old 02-23-2012, 05:29 PM   #10
1954 25' Cruiser
I actually have the tool but for some perverse reason like using the punch to remove
Last night I removed the last rivets holding the shell. Where the ribs come down to the floor there was a rivet through each rib from the folded up belly skin which was of course covered on the exterior by the shell...a very awkward location , couldn't get the drill or the dremel in to cut them so used a cold chisel from the inside to snap off the shop head and then push the universal head out between the belly skin and shell skin. Once I brace it, I can lift it
Don...
1954 Cruiser
Old 03-11-2012, 03:01 PM   #11
1954 25' Cruiser
Shell Lifted!!
We braced the interior using metal studs...really easyto cut to size and rivet to the ribs. I bolted in two, 2x6's, one at either end, about 7" off the floor so the jacks could fit underneath. Cranked the jacks up and voila...it lifted. A little bit of resistance at the front end. One of my jacks is too small and I'll have to get another that can lift a bit higher. I screwed together two, 2x4's to make a 4x4...made 2 of these. I need to pick up 12 concrete blocks to make 4 stacks of 3 blocks each (24" high), then I will continue jacking the shell up, slide my 4x4's on top of the blocks and under the shell, then lower the jacks and take them out.
Name:	DSC02086 (1024x683).jpg
ID:	153079   Click image for larger version
Name:	DSC02088 (1024x683).jpg
Name:	DSC02089 (1024x683).jpg
ID:	153081   Click image for larger version
Name:	DSC02090 (1024x683).jpg
Don...
1954 Cruiser
Old 03-31-2012, 08:32 PM   #12
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Don, Just found your thread,Great to see Another 54 Cruiser, this will be fun to watch!! Keep the pictures coming!
Doug
It's not worth doing if you're not having fun.
https://tinman54.blogspot.com/
https://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 04-01-2012, 01:50 PM   #13
1954 25' Cruiser
Doug, I have been following your progress and it is keeping me inspired. Lots of things are scheming to get in the way of the work on my Cruiser...building a new house and the airplane has taken a lot of time lately...but I am on a mission. Dropping the belly pan is next.
Thanks for the advice on the battery, I will do the same.
Don...
1954 Cruiser
Old 05-23-2012, 08:47 AM   #14
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Don, Hope you are still making some progress. Here are some interesting facts on the Cruiser if you haven't seen them.
http://www.airstream.com/files/libra...b2c382c759.pdf
Old 05-30-2012, 07:40 PM   #15
1954 25' Cruiser
Doug, I did not have that document, thanks very much.
Probably won't be back on the project until Sept.
We just put our house on the market and the previous 8 weeks have been one item after another to get it ready. Amazingly we sold it in 2 days for 10K over asking price...the real estate market is definitely swinging back.
Now we just have to get through the closings and into the new place in August. When Sept hits I'll be ready to Airstream once again
Don...
Don...
1954 Cruiser
Old 02-24-2013, 02:10 PM   #16
1954 25' Cruiser
Back at it...overdue update.
Well it's funny how life gets in the way of airstream rehab...sold a house, bought a house, crashed my airplane (walked away), bought another airplane on the west coast and flew it back to the east coeast...that adventure detailed on youtube....
After lifting the shell with jacks I got 12 concrete blocks and put 3 at each corner, jacked the shell up and used a double 2x4 to support the shell and got rid of the jacks. The shell is now 24" above the floor.
The space between the belly pan and the floor was amazingly disgusting...no skeletons yet but I'm sure they are in there.
I was able to save both the front and rear ends of the belly pan for use a template for replacement. Getting the floor out is next.
Name:	DSC02368 (1024x683).jpg
ID:	179735   Click image for larger version
Name:	DSC02367 (1024x683).jpg
ID:	179737   Click image for larger version
Don...
1954 Cruiser
Old 02-25-2013, 05:23 PM   #17
1954 25' Cruiser
Another pic of the space between belly pan and floor. I have the trailer sitting on concrete blocks so I can get all the rivets on the belly pan and drop it.
Also one of my favorite tools, a pneumatic angle drill with threaded bits. The head is very small so you can really get into tight spaces, that particular bit is a 1/2" stubby. A great tool.
ID:	179843   Click image for larger version
Don...
1954 Cruiser
Old 02-26-2013, 06:39 AM   #18
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Good to see you back at it! Lots of nasty stuff in, the frame doesn't look to bad, rusty but no holes!
Old 02-26-2013, 07:28 PM   #19
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
metal illness for sure!
Hi Don & Debbie
Nice to see you are back to the restoration again. I watched the video and am a little queasy from turbulence not to mention seeing the contents inside the bellypan.
Thanks for the updates and photo documentation. I recently read the tool list and it helped me decide on the Mikita compressor. Now I just need a plane hanger and I'll be ready to go.
Thanks again.
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
Old 02-27-2013, 09:48 AM   #20
Tool Hoarder
West , California
Great to see you back to it! It will feel good when you get thru the dismantling. Keep pushing!
Is the FJ Cruiser hard to see out of? aluminitus Tow Vehicles 14 11-09-2011 05:21 AM
5 wks airstreaming and now it is back to work Lothlorian On The Road... 10 07-29-2011 11:23 AM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
Tire Life Cracker Tires 17 02-27-2011 02:15 PM
