Old 05-30-2012, 07:40 PM   #15
2008 27' Classic FB
Plymouth , Massachusetts
Doug, I did not have that document, thanks very much.
Probably won't be back on the project until Sept.
We just put our house on the market and the previous 8 weeks have been one item after another to get it ready. Amazingly we sold it in 2 days for 10K over asking price...the real estate market is definitely swinging back.
Now we just have to get through the closings and into the new place in August. When Sept hits I'll be ready to Airstream once again
Don...
Don...
2008 27FB Classic
My Airplane Construction Website:
http://www.donsbushcaddy.com
NTRPRZ is offline   Reply With Quote
Old 02-24-2013, 02:10 PM   #16
2008 27' Classic FB
Back at it...overdue update.
Well it's funny how life gets in the way of airstream rehab...sold a house, bought a house, crashed my airplane (walked away), bought another airplane on the west coast and flew it back to the east coeast...that adventure detailed on youtube....
After lifting the shell with jacks I got 12 concrete blocks and put 3 at each corner, jacked the shell up and used a double 2x4 to support the shell and got rid of the jacks. The shell is now 24" above the floor.
The space between the belly pan and the floor was amazingly disgusting...no skeletons yet but I'm sure they are in there.
I was able to save both the front and rear ends of the belly pan for use a template for replacement. Getting the floor out is next.
Name:	DSC02368 (1024x683).jpg
ID:	179735   Click image for larger version
Name:	DSC02367 (1024x683).jpg
ID:	179737   Click image for larger version
Don...
2008 27FB Classic
Old 02-25-2013, 05:23 PM   #17
2008 27' Classic FB
Another pic of the space between belly pan and floor. I have the trailer sitting on concrete blocks so I can get all the rivets on the belly pan and drop it.
Also one of my favorite tools, a pneumatic angle drill with threaded bits. The head is very small so you can really get into tight spaces, that particular bit is a 1/2" stubby. A great tool.
ID:	179843   Click image for larger version
Don...
2008 27FB Classic
Old 02-26-2013, 06:39 AM   #18
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Good to see you back at it! Lots of nasty stuff in, the frame doesn't look to bad, rusty but no holes!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 02-26-2013, 07:28 PM   #19
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
metal illness for sure!
Hi Don & Debbie
Nice to see you are back to the restoration again. I watched the video and am a little queasy from turbulence not to mention seeing the contents inside the bellypan.
Thanks for the updates and photo documentation. I recently read the tool list and it helped me decide on the Mikita compressor. Now I just need a plane hanger and I'll be ready to go.
Thanks again.
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
safari62 is offline   Reply With Quote
Old 02-27-2013, 09:48 AM   #20
Tool Hoarder
West , California
Great to see you back to it! It will feel good when you get thru the dismantling. Keep pushing!
marzboy is offline   Reply With Quote
Old 02-28-2013, 07:41 PM   #21
2008 27' Classic FB
Doug, Gary & Javier thanks for the encouragement....no turning back!!
Hope to get the floor out this weekend.
Don...
2008 27FB Classic
Old 02-28-2013, 08:13 PM   #22
hissilver's Avatar
2018 25' International
Van Wert , Ohio
Great info...thanks for sharing
hissilver is offline   Reply With Quote
Old 03-10-2013, 05:50 PM   #23
2008 27' Classic FB
Framed
Spent a good couple hours getting the plywood off the frame. No better way to do it than crawl underneath with the grinder and cut the bolts off. On each end of the plywood is also a wood screw...hate those 1950's flat head screws, no qucik way to getem out other than the screw driver.
The frame is in worse shape than I thought it would be. I guess the building technique back in '54 was to lay a blanket of fiberglass over the entire frame and put the plywood down on top of it. This thin layer of fiberglass that ended up between the plywood and the top of the steel frame was a great collector of moisture and the tops of my steel frame members are very rough in some areas.
I quit for the day when I just about sliced off the top of my thumb...NOTE TO NITWITS: Wear Leather Gloves!!! Another warning...when laying under the beast cutting off the elevator bolts, they are very hot when they let loose...makes you squirm when they land on your legs...and yes thankfully I was wearing a thick pair of Carharts
ID:	180688   Click image for larger version
Name:	DSC02401 (1024x683).jpg
Name:	DSC02403 (1024x683).jpg
ID:	180690   Click image for larger version
Name:	DSC02404 (1024x683).jpg
Don...
2008 27FB Classic
Old 03-10-2013, 06:02 PM   #24
reinergirl's Avatar
Hollis , New Hampshire
Ouch, ouch, ouch!! Had a tetanus shot lately?
reinergirl is offline   Reply With Quote
Old 03-10-2013, 07:07 PM   #25
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
That will feel good for day or two!! I think I cut one bolt off from the bottom then used an angle grinder on the top of the floor. I didn't like the nasty stuff landing on me!
Old 03-10-2013, 10:45 PM   #26
Tool Hoarder
West , California
Thats why I stock plenty of Peroxide and crazy glue dude.
Is the FJ Cruiser hard to see out of? aluminitus Tow Vehicles 14 11-09-2011 05:21 AM
5 wks airstreaming and now it is back to work Lothlorian On The Road... 10 07-29-2011 11:23 AM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
Tire Life Cracker Tires 17 02-27-2011 02:15 PM
