Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Cruiser > 1950 - 1958 Cruiser
Old 06-14-2011, 07:36 PM   #61
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Of course, I can't prove that there were no tandem conversions among the Cape Town to Cairo Airstreams, but I have never heard any suggestion that there were any conversions, nor do I think it is likely that there were any.
But speaking of conversions, Airstream required all trailers on the 1963-64 Around the World caravan to be equipped with Duratorque torsion axles that had been standard equipment on Airstreams since 1961. Airstream was ready to convert earlier Airstreams to Duratorques at either factory prior to the ATW caravan if necessary, but it is currently unknown if any were converted. Most Airstreams on the ATW caravan were 1962 and 1963 models, but there were a few with 1959-61 wheel well shapes, so some might have been converted. To date, I have not identified any 1958 or prior Airstreams (that would have for sure been converted) on the ATW caravan.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 06-28-2011, 06:49 PM   #62
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Had a good weekend, I was able to get the marine grade plywood cut and put West marine epoxy on both sides. I am just waiting for the wheel wells to be finished by the sheet metal guy in town. I place my order for Prodex reflective insulation today. There was a buy one get one free promotion going at insulation4less.com. I hope this stuff will work as good as it says it will. I like it better than the bubble wrap stuff because I am skeptical that the bubbles will last the long haul. I know the stuff on my pool only last a year, yes I know it is in the sun and the UV rays but still not convinced it would last 40 years.
I have priced out 5053 Aluminum .032 4'x8' sheets for the belly pan locally for $63 and hope to put the order in soon. However, is .032 too thick should I go with .027?
What is the thickness of the C channel .032 or .040?
Do I put the Marmoleum floor down before the C channel, like it was originally? Should I just use tile or full sheets. I like the idea of full sheets but not sure if there will be problems at the joints where the plywood meet.
Thanks again for any opinions
nick6930 is offline   Reply With Quote
Old 06-28-2011, 10:05 PM   #63
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
No Marmoleum
Nick,
We (Zoe' and I) highly recommend against the Marmoleum. Not happy with it, it is cracking already, has spots in it that won't come out from "we have no idea"... doing it over, I'll go with a light CORK floor anyday!
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-29-2011, 05:41 AM   #64
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
That is the exact info I need. I have read that the full sheets crack at the seams and tiles are a better choice. However, I was not certain if that was true because I thought from listening to thevap.com Colin used full sheets. I like cork, saw it in Franks trailer. I just wonder how it would hold up to 3 dogs and future puppies. The stuff Frank used seemed to be on the soft side with their nails. I wonder if there is any insulation factor to cork?
Old 06-30-2011, 08:06 PM   #65
Baltimore , Maryland
cork is my choice. It just feels good under foot. I cannot testify about dog claws. I have installed marmoium click and saw the things Rob mentioned about scuffs also.
Old 07-05-2011, 10:46 AM   #66
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I went with the .040.
ddstech is offline   Reply With Quote
Old 09-19-2011, 07:56 PM   #67
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Well, after a very long break (not by choice), I am trying to get back into the grove. Our newly born son has taken up most of the summer. That and having a local place take 4 months to make wheel wells only to make them single tubs not tandem like the measurements said. So I bought aluminum racing tubs that I plan on cutting in half and buck rivet .040 aluminum in the middle to create the tandem wheel wells.
Since I do not have a metal brake, I have ordered a heavy duty piano hinge. I have 2" angle iron and will just make a brake that can do the job for the wells as well as the C channel. If all goes well the wells should be done in the next week or two and then my first dry fit of the shell. I cannot wait. I know the wife will be excited to get the frame out of the driveway and back in the barn.
Old 10-17-2011, 03:55 PM   #68
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Wheel wells on and test fit
I had a great weekend. I finally got around to making the wheel wells. They turned out pretty good, though I think I would do things differently if I were to do it again. Instead of using buck rivets, I decided to use Olympic rivets. The primary reason was out of ease. I know how to use Olympic rivet.
I put the rest of the flooring down and bolted most of it down. I still need to add a few more elevator bolts. I could not wait and this morning I cleaned out the barn and test fitted the frame to the shell.
QUESTION: The shell seems smaller than the floor. How much should this be forced into place?? I used the original floor front and rear to get the curves. So I am fairly certain that I have the correct size for the curves. I can get the one side on easy but the other side seems to be about 3"-4" too big. I did not have time to fuss with it before work. I may have been able to get it closer if I man handle it more. But I thought I would ask first.
All comments and recommendations are welcome.
Next on the list finish installing the elvator bolts. Insulate the floor and start the belly pan (well my version, which will be more like a banana wrap.) i plan on putting a belly pan on the front and rear and only a wrap on the sides so the tank placement will be open.
Old 10-18-2011, 01:20 PM   #69
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
I am going to throw the quesiton out there again about fitting the shell back on. Are there any tricks to checking how tight is too tight? Since I have to put the belly pan on first before the final install of the shell, I will not be able to shave any of the floor after the belly pan and C Channel is installed.
Should the skin slip over the floor easily or be very snug?
Old 10-19-2011, 05:51 PM   #70
Central , Mississippi
I wouldn't say my '63 was an easy fit...I did have to push in some spots and use a strap to get the front to line up centered. As long as it goes over the floor and doesn't expand the door opening I think you will be ok. I did some math to see theoretically how much the belly pan added to the perimeter...it was a very small amount.
I fit the shell with the sides of the belly pan wrapped up, shoved the end C channels into place and screwed them to the floor, then lifted the ends of the shell, one at a time, to wrap the belly ends into place.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 11-01-2011, 02:43 PM   #71
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Oh well yet more weeks go by and little progress. I finally got the shell to fit on the dry fit. I think I may belt sand a little off the corners so that it will not be an issue once the belly pan goes on.
I just ordered a 30" metal brake from Habor Freight to bend the C Channel. Which I hope to do this weekend.
{My Thoughts} I am starting to think making her a double axle was not the best idea. I like the concept but it has created a lot of extra work for myself. Finding space for the tiolet is going to be an issue in the wet bath. Since the toilet was in the location where the second axle now sits. I also made the wheel wells the same heigt as the originals. However, since I switched the axles to torflex the whole thing sits a lot higher. I think there is too much room in the well area. I could have used that room for the toilet on top of the well if I dropped the whole thing down 4"-5". I really dont want to redo the wheel wells but I am tempted.
The other area of concern is the door step. Should I keep it plywood and line it with diamond plate for strenth? I see I am going to need to do some metal work in that area.
Old 11-01-2011, 04:28 PM   #72
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
channel
My trick for bending channel. I used a 1x2 as a spacer. I know all 1x2s are not created equal so you will have to verify against the old channel.
Bend one side just eye balling it. Rotate the channel, put the 1x2 as a spacer, clamp down, remove 1x2, bend the second side. It is not imperitive that the sides are the exactly same height. You will get it pretty close with the practice you will have.
Saves alot of time measureing. Even if you cannot find a 1x2 to match your channel, measure and make one channel, then cut a block for a spacer.
Also, for your curved pieces, bend one side, cut the V notches so that it will bend, then bend the second side of the channel.
I am not sure about your brake, but you should be able to adjust the clamp forward/back the pivot point so that you can adjust the radius of the bend. Too tight of a radius will casue the aluminum to break. Maybe not right away, but over time the fatigue will split it.
Good luck.
FC7039 is offline   Reply With Quote
Old 11-01-2011, 05:12 PM   #73
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Thanks for the advice FC7039. Something as simple as the 1x2 spacer is great. I am not sure if I would have thought of that til the last 12" section.
Old 01-24-2013, 08:43 PM   #74
La Gringa's Avatar
2011 27 FB International
Providenciales , BermudaTriangle
Originally Posted by nick6930 View Post
Plans???Was I suppose to plan something?....I have more dreams than plans.
Keep moving in the direction of your dreams and the rest will fall into place...
Polly ;-)
"If one advances confidently in the direction of his dreams, and endeavors to live the life which he has imagined, he will meet with a success unexpected in common hours." Henry David Thoreau
https://2gringos.blogspot.com
La Gringa is offline   Reply With Quote
Old 01-14-2018, 07:13 AM   #75
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Like so many before me, life happens and I failed. I started this in 2010 and there it still sits in my barn. Anyone want to take over the project let me know. I’m selling off all my Airstream projects. The cruiser project is perfect for someone that wants to build it the way they want since the tanks have not been placed yet. Everything has been stored in my barns.
1953, cruiser
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
Crimmins' '54 Cruiser AndrewM 1950 - 1958 Cruiser 47 07-12-2011 12:30 PM
RM4872 Dometic won't start CRunkel Refrigerators 1 04-06-2011 09:09 AM
Optima AGM Red Top start Battery Install John H. Classic Motorhomes 8 03-19-2011 09:17 PM
FJ Cruiser mirrors frank1917 Tow Vehicles 4 02-28-2011 08:20 AM
