Old 12-11-2007, 08:09 PM   #1
Question Wood around black tank is bad
The wood in my 74 Arogsy28 that sorrounds the black tank where the toilet sits is completely rotton. When it came out it was in splintered pieces. Now I need to figure out how to replace those wooden sections. Has anyone done this and have some pictures or wisdom to share?
Also, I couldn't get the flange where the toilet attaches off so I gotta work around that.
Darryl
Darryl Elkins
74 Argosy 28
Darryl is offline   Reply With Quote
Old 12-11-2007, 08:29 PM   #2
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
search it
a quick search will yield many threads on floor repair
good luck!
fotochop is offline   Reply With Quote
Old 12-11-2007, 08:30 PM   #3
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Been There, Done That...
Unfortunately, your best bet is to replace the entire floor with one solid piece. We did that last year in our Sovereign. It was no piece of cake, but we are so glad that we did. The previous had tried to piece together a new floor by cutting different sections and fitting them in. The gaps were filled with caulk. It was a real mess.
We have pictures buried in our digitial "vault". I will try to get hubby to email you if you are interested.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 12-11-2007, 10:19 PM   #4
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Welcome to the club!
Here, these pics will get your juices flowing....
I used a large flat head screwdriver and a hammer to unscrew it. Be careful and patient and it will come out. If you want to be safe, fabricate a tool or use two screw drivers at once. JUST DON'T BREAK IT!
Good luck, rear floor jobs aren't the end of the world (but you can see it from there)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 12-11-2007, 11:06 PM   #5
This is in an Argosy so the black tank sits on top of the floor and that is the part that needs to be replaced. The toilet for my Argosy is a low profile that sits on top of the tank.
Attached is a pic I found on the web showing how it is suppose to look but I had to remove all of the wood under the toilet between the sink and tub.
As for making a tool to remove the flange I think I can do that maybe with a 4 inch putty knife or something like that.
Darryl Elkins
74 Argosy 28
Old 12-12-2007, 08:44 AM   #6
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
The floor under the black tank of our 20' Argosy was shot. It's not as hard as you miguht think to repair, just time comsuming. Oh yes... if you aren't good at coming up with combinations of swear words now... you will be!
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 12-12-2007, 11:43 AM   #7
pauly g's Avatar
1960 22' Safari
Oceanside , California
I had to remove my flange by carefully sawing slots into it, then breaking it into chunks and removing it. Just don't cut too far, or you will cut into the threads of the tank.
pauly g is offline   Reply With Quote
Do I have to use the Black Tank? jimsease Waste Systems, Tanks & Totes 8 08-09-2006 11:22 PM
Black Tank Devoman Waste Systems, Tanks & Totes 14 08-02-2006 01:13 PM
Bad day at Black Rock Pahaska Off Topic Forum 11 08-31-2005 01:28 PM
Black tank Gunnyusmc All Argosy Trailers 4 07-19-2004 05:42 PM
Black Tank Gunnyusmc Waste Systems, Tanks & Totes 3 07-02-2003 08:38 AM
