Old 09-25-2015, 03:58 PM   #1
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
winterizing trick
I do not have a bypass circuit for my gas water heater on my 73 Argosy but after a bit of head scratching I have discovered a work around. The shower head lockout switch. I drain the system as good as possible and shut off the valves on the heater inlet and outlet lines. I drain the heater as normal. I put 4 gallons of RV antifreeze into the empty fresh water tank and start the pump. Open the cold water taps one at a time until the pink juice comes out, shower head last. Do not overlook the toilet and the rinse hose as well as the shore water inlet and the 2 drain valves under the back.
Now, with the shower shut off valve slid over to stop, turn the shower hot tap on while leaving the cold on. If you have a single mixer valve set it in the middle. The pink juice will now enter the hot water lines from the back heading forward. Open the bathroom vanity hot valve until you get pink juice and close it. Go to the kitchen and turn on the hot water until you get pink juice there and presto you're done. All lines are protected. Don't forget to protect the black and grey tanks and leave some pink juice in the toilet bowl.
Gearheart is offline   Reply With Quote
Old 11-22-2015, 05:23 PM   #2
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
Thanks for this! It's dipping below freezing tonight, and we won't be camping again until mid January, so I went ahead and got the trailer prepped for the next 4-5 weeks assuming we may have a few below freezing nights. No bypass on my water heater, but your tip did the trick! Thanks!
fluxcap is offline   Reply With Quote
Old 12-05-2015, 04:43 PM   #3
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
I have since seen a set up on Vamethyst's 22 footer where the water heater is not under the kitchen cabinets. This short cut will not work on her trailer. The tee lines to the kitchen sink must be right beside the water heater shut off valve so that the lines can be filled towards the sink from the heater location.
My new winterizing trick mandolindave Winterizing, Storage, Carports & Covers 25 11-29-2014 08:25 AM
Sticky Window Trick Foiled Again Windows & Screens 18 07-13-2008 04:06 PM
paint can lid trick pinkflamingoes Lights - Interior & Exterior 1 02-13-2006 08:43 AM
what's the trick? baxter Sinks, Showers & Toilets 0 11-21-2005 06:40 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
