Old 10-15-2010, 10:39 AM   #1
WI-78ArgMin6.7
ArgosyMinuet's Avatar
1978 Argosy Minuet 6.7 Metre
Franklin , Wisconsin
Winterizing Argosy Minuet with heater disconnected
Hello Everyone!
I would like to winterize my trailer which I bought this summer with a leaky water heater which the previous owner disconnected(bypassed). Can I still winterize the water lines/etc. and not winterize the water heater (which hasn't been used for a while)? I didn't plan on paying for the heater to be reconditoned or a new one yet. Also I didn't plan on storing the trailer in a building (I would do it in a heart beat if the opportunity came around). It will be outside in my yard...should I put a tarp over it during the winter? I've heard this can cause issue with the finish & paint. At least should I cover the rooftop AC unit? Any quick advise on steps to winterize this unit?
Any advice is always appreciated. Thanks in advance!
Bill
ArgosyMinuet is offline   Reply With Quote
Old 10-15-2010, 10:48 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
pull the old water heater out and connect the cold-inlet directly to the hot-outlet.
then, winterize as desired - you'll get all the lines that way.
pump RV antifreeze throughout all the lines - it's cheap enough
cover on A/C isn't necessary
kennethowens is offline   Reply With Quote
Argosy Minuet ccarman All Argosy Trailers 2 08-11-2010 08:14 PM
Propane catalytic heater in Minuet? mutcth All Argosy Trailers 10 10-26-2009 04:35 PM
Argosy Minuet value? Anon Trailer Values 9 05-13-2007 12:24 AM
Murphy and I are Winterizing the Argosy. Need Pump Motor. RBolton Winterizing, Storage, Carports & Covers 12 10-24-2006 09:56 AM
Argosy Minuet anniefanny Member Introductions 7 04-25-2006 08:12 AM
