Old 04-07-2012, 08:11 AM   #1
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Will someone take/post a quick pic please
I want to see how the screen door is attached to the hinge, rivets or nuts/bolts. Ours was missing the screen door and the hinge for it had been cut off. I have made a couple of hinges, installed them on the replacement screen door and then riveted them back on through 6 holes that were in place on the door for each hinge......but its not pretty and wonder if I should be looking for a better method to fix them.
I had some fixings that I knew I would never need that I threw out and they would have been ideal and I dont know where to get them or what they are called, similar to a nut and bolt except the threaded bolt part screws into a threaded tube section and both heads are the same. The length would have been right for the thickness of material I need to get through.
Thanks in advance!
Bex
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 04-07-2012, 08:18 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had to remove the screen door on my 75 TW to get a crack welded. I attached it the same as it was originally. 3 buck rivet in the holes nearest the hinge and 3 blind rivets in the remaining holes.
Richard
Old 04-07-2012, 09:03 AM   #3
Bex
1976 Argosy 28
Now that makes sense, thanks!
TAC AB-1
Old 04-08-2012, 12:22 PM   #4
Bex
1976 Argosy 28
I went with just the 6 outer blind rivets but reamed out the holes and used a larger rivet in each, filled the remaining outer holes and will re-drill and fix , them if the door works itself loose, but I really don't think it will.
