Old 03-21-2016, 11:27 AM   #1
1976 Argosy 28
Atlanta , Georgia
Where is the 1976 Argosy Vin Number
I purchased a 1976 Argosy 28 Ft Center Bath. I have found the tag that say's MFD by Argosy with the date and Type Trailer number. But can't find the actual VIN number. Where do I find this specifically?
The Trailer number is 23A6v1964 the manufactured date is 3 76
I need to apply for title
New to the forums so I appreciate any help you can provide.
nocmanus is offline   Reply With Quote
Old 03-21-2016, 02:19 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
If you got the 23A6v1964 off a small plate at the front of the trailer, that is your VIN. The plate has weight rating, date of manufacture, and serial number, and is behind the propane tanks.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 03-21-2016, 04:12 PM   #3
1974 Argosy 20
Kooskia , Idaho
The really, really, official VIN is on the underside of the tongue frame rail (under the propane tanks) probably on the curb side. It may be paint filled or quite rusty, but it is there. May take a rotary wire brush to bring it out. It should be the same # you have already found.
Old 03-21-2016, 04:51 PM   #4
1976 Argosy 28
Atlanta , Georgia
Did some further research and the VIN does match. I will look on the A Frame where I'm sure the number is and clean it up.
Thanks. Now the real fun begins. Rehab!
Old 03-22-2016, 05:37 AM   #5
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
It's possible the second number on your plate may be worn down. If it's a 28footer, it should start with 28 rather than 23.
Here's the numbering system so you can decode it
(But you won't have "digit 1" since it is an argosy.)
http://vintageairstream.com/frequent...erial-numbers/
fluxcap is offline   Reply With Quote
Old 03-22-2016, 12:00 PM   #6
1977 31' Sovereign
Lynnwood , Washington
1) There should be a VIN tag riveted to the front of the trailer (possibly road side lower).
2) There should be a VIN number stamped on trailer tongue (A-frame); on top; curb side, near the body. You may need a wire brush to remove paint and rust.
Tom
TomKirk is offline   Reply With Quote
Decipher your VIN - charts for VIN and Weights GreatPumpkin Title, VIN & Registration 4 05-27-2015 03:33 AM
Vin number Airstream Argosy Trailer glynett Member Introductions 0 05-26-2015 02:44 PM
Can't find the VIN number plate. 1977 ARGOSY MH Octane Classic Motorhomes 4 08-10-2011 05:02 PM
Argosy vin number location PodPeople All Argosy Trailers 10 09-06-2004 09:46 PM
VIN number deeinva Our Community 1 08-11-2003 09:04 AM
