Old 03-14-2008, 06:24 AM   #1
ckelly617's Avatar
1973 Argosy 24
Panama City , Florida
When hooking up to electric which amp would we use?? 30, 50?
What's the difference?? 30 amp, 50 amp, at another park I saw 56 amp. So, how many amps would we want to use for a '73 Argosy 24ft. Would it tell me this information in the manual?
ckelly617 is offline   Reply With Quote
Old 03-14-2008, 06:39 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
30 amp is a 3-pronged lug that transfers 120VAC thru one set of cables into your trailer. This is the 'standard' for most RVs out there, unless you have a big MoHo or 5th wheel, where they are wired for 50 amps.
50 amps is a 4-pronged plug that carries 2-120VAC circuits for a totalof 240VAC. While nothing in most RVs run on 240VAC, it is there if it is required. 50 amps allows you to run 2 air conditioners (3 if you have them, and he larger MoHos DO) and almost everything else in the coach.
Now to your question. If your trailer is wired for 30 amps, you can plug into a 50 amp receptical at the CG with the use of an appropriate adapter. You willstill be drawing 30 amps, even though you will be connected to 50 because you will only be accessing one of the 2- 120VA circuits available.
Hope this helps.
Old 03-15-2008, 01:12 AM   #3
ckelly617's Avatar
1973 Argosy 24
Thanks for the reply. We found that 3 prong plug in you're talking about and we have it hooked up and working. Thanks again for helping me out.
Having a little trouble hooking up the brake controler. SaabLover Brakes & Brake Controllers 1 11-04-2007 10:26 AM
Midwest Hooking up Solar Panel Jurgena Boondocking 3 06-22-2007 05:39 PM
hooking up new radio powd Audio, Video & TV 15 07-20-2004 09:37 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 11:50 PM
