Old 05-26-2015, 10:07 PM   #1
1977 Argosy 28
new braunfels , Texas
Wheels
I have'77 28' Argosy. I need new wheels. What is the size, 15x6 or 7?
5.5 bolt pattern? What is the size of the center hole? I would like steel
with moon hub caps, anyone know where to find these?
Thanks for the help.
baddog0263 is offline   Reply With Quote
Old 05-27-2015, 09:58 AM   #2
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Rims...
Hello Baddog,
I have a '76 Argosy that is 28' long. The rims on mine are 15x6, 6 bolt, 5.5" circle.
I'm told that rims from Chevy truck fit.
Oh, welcome to the forums...
Good Luck!
Chris
newsgauger is offline   Reply With Quote
Old 05-28-2015, 08:38 AM   #3
1977 Argosy 28
Thanks, the hole in the middle of the wheel, What is the diameter? Or does it matter?
Old 05-28-2015, 10:48 AM   #4
2005 19' Safari
GLENDALE , AZ
On the wheels on late model Airstreams, I think the center bore is 4.25". Not sure if this applies to your Argosy.
I suggest you measure your current wheels for reference. A wheel with an undersized center bore probably won't fit over your hubs.
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
