Old 07-26-2014, 06:14 AM   #1
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Wheel bolt to stud conversion?
Having grown up with VW's I have acquired a strong aversion to wheel bolts. Is it possible to convert my hubs / brake drums to studs and nuts? Makes installing the wheels much simpler.
Gearheart is offline   Reply With Quote
Old 07-26-2014, 06:20 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You can, but it's not very easy. You'd have to machine a larger hole for the shoulders of the studs in order to ensure the stud won't foul the brake magnet. You would also need to drill out the threaded holes for the bolts. The easiest part would probably be sourcing correct length and type studs.
Plan B would be to find a set of drums with studs already installed.
Old 07-26-2014, 07:08 AM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Yes you can by using Wheel Studs Replacement Wheel Stud, Screw-In, 1/2" x 2" Redline Accessories and Parts 25-53. I did this back in 2008 when I replaced the old 15" rims on my 1976 31' Sovereign with 16" aluminum wheels and tires. Here is the thread I started at that time on the change over.
http://www.airforums.com/forums/f465...tml#post561838
Post 24 has a picture of the old Airstream hub with the wheel studs installed. I used lock tite on the threaded portion that screwed in to the hub and then mounted the wheel chrome lug nuts. I never had a problem with them at all. In 2010 I replaced the old original axels with new axles and hubs that came equipped with studs.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-26-2014, 08:17 AM   #4
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
When I upgraded LaTortuga with new axles, the new drums had nuts to replace the old bolts, which were original.
Savage68 is offline   Reply With Quote
Old 08-04-2014, 07:30 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I just bought a new hub from Southwest Wheel in San Antonio. It was a Dexter replacement 10" hub & drum w/studs and a bearing kit-cups already installed. $69.00 Total. I would think you could find this at any Dexter Distributor.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Stripped wheel stud texascanuk Wheels, Hubs & Bearings 13 05-04-2011 07:58 PM
Broken Wheel Stud gsmithii Wheels, Hubs & Bearings 12 10-11-2010 01:09 PM
Broken wheel stud 65 Caravel kevinkatz Wheels, Hubs & Bearings 7 07-07-2009 06:31 AM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
