Old 02-11-2009, 09:00 PM   #1
cbgenrich's Avatar
Atlanta , Georgia
What's this Argosy Minuet worth?
I have come across an Argosy for sale, and thought someone here might be able to help me assess the deal.
It's an "Airstream Argosy Minuet 1978, 22ft. Very good condition" Before I say what it's listed for, what do you think would be a good price?
I wish I knew more about it, esp. a floor plan and GVWR.
-CB-
cbgenrich is offline   Reply With Quote
Old 02-11-2009, 09:18 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings CB!
Welcome to the Forums!
First, the relatively easy part of your question regarding floorplan and empty-weight. The attached image is for 1979 models, but the 1978 floorplans were identical and weights were essentially unchanged.
As you can see in the scan, the empty weight for the 6.7 Metre (22') Minuet is 2,725 with a hitch weight of 280 pounds. I don't have the GVWR figures immediately available but belive that the GVWR is approximately 4,000 pounds. The loaded hitch weight will likely approach or be slightly over 500 pounds. With the relatively light hitch weight on this coach, it is often advisable to travel with a full water tank to increase the hitch weight to between 12% and 15% of actual trailer weight.
The one variable with the interior is the front lounge area. The lounge was standard and the dinette was a $50.00 factory option. Everyone has their personal favorite, and mine is the front lounge -- I would never utilize the dinette -- just too confining -- but to each his own -- this is a very personal preference.
I hesitate to comment on price as the value of all RVs are fluctuating due to the current economic conditions. Prior to the current fluctuations, I would have expected the price to vary between $2,000 (needing near total restoration) to $7,500 (presentable and ready to use). Something to be aware of with these 6.7 Metre coaches is that there is a slim chance that you may encounter one with the composite aluminum floors -- there weren't many 6.7 Metres built with this feature but there have been a few that have been found.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 02-11-2009, 10:12 PM   #3
cbgenrich's Avatar
Atlanta , Georgia
Thanks for the great reply.
Here's the deal: Airstream Argosy Minuet 1978, 22ft. Very good condition
The photos show it is the front lounge version. I guess there just is not table anywhere? Two sofas?
What do you think about that posting?
-CB-
Old 02-11-2009, 11:44 PM   #4
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
It would be HIGHLY unlikely that a trailer of that age has never had a leak.
But, you never know. Since you live in the area, why not run over and take a look? If you aren't comfortable, maybe you can find an inspector from the forums to go with you? There are a number of folks here who do that as a service, good luck.
And welcome to the forums!
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 02-12-2009, 06:59 AM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings CB!
From the photos, I can verify that, at some point, the exterior has been repainted. The color leans more toward RV white than the Argosy beige that was utilized in 1978 (this isn't a problem, just something to be aware of) -- originally, the tongue, banana wraps, and rear bumper would have been painted a highly metallic copper. The interior appears to be nicely preserved. Provided the coach checks-out in regard to lack of rot from leaks and the appliances can be verified to be working as stated in the ad, the coach is priced within the ball-park (IMHO).
Kevin
P.S.: The coach's dining table is what is referred to as a "Credenza Table" -- it folds into a small cabinet to the right of the door as you enter the coach.
Kevin D. Allen
AIR #827
Old 02-12-2009, 08:57 PM   #6
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
Hello all! Well C.B. I hate to burst your bubble, but we bought it a few weeks ago. I don't know why that guy didn't remove the ad. We did not pay what he was asking, but think we got a pretty good deal. Some things he said were B.S., but the leak issue seems to be true. There's been a small leak from a window by the side gaucho, but it was nothing that couldn't be fixed with a little caulk.
Good luck finding another one and when you do, let's go camping!
Beth & Chris in Atlanta
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 02-12-2009, 09:02 PM   #7
1966 26' Overlander
Originally Posted by overlander64 View Post
ISomething to be aware of with these 6.7 Metre coaches is that there is a slim chance that you may encounter one with the composite aluminum floors -- there weren't many 6.7 Metres built with this feature but there have been a few that have been found.
Kevin, what do you mean "be aware" of the composite aluminum floors? Good/bad, etc.??? FYI - this unit has the aluminum floor and we're trying to figure out how to level them a little. We looked at the forum link ya'll did earlier on that subject. Any suggestions?
Beth
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 02-12-2009, 11:59 PM   #8
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Beth!
Beth
The composite aluminum floors are great as long as you are aware that they are there as they do impact the selection of floor coverings. One of the reasons for the thicker carpet pad and the thick shag that was original in the Minuet was that it was needed to disguise and hide the rivets that attach the composite panels to the coach's frame. There are really only two solutions -- go back with pad and carpet -- or go with a laminate flooring and add something like Armstrong's Quiet Step Underlayment. My 6.0 Metre Minuet has the composite aluminum floors, and the Armstrong Laminate floor covering with the thickest available Quiet Step Underlayment have worked out beautifully -- this coming season will the fifth since the interior was refurbished.
Kevin
Kevin D. Allen
AIR #827
Old 02-13-2009, 02:07 AM   #9
cbgenrich's Avatar
Atlanta , Georgia
Beth, not a problem. It's still a bit early in my plan to make a move on something like this, but if it was a good deal and checked out as adequate, I might have gone for it. I hope you guys enjoy it.
Are you familiar with the May 15-17 rally in north Georgia? Check the site calendar. I'm not an RV owner of any type, but plan to be. Airstreaming is a real possibility and at this point I figure to make a day trip there on the Saturday. Mayhap I'll see you there. I would love to see your coach.
-CB-
Old 02-13-2009, 06:20 AM   #10
1966 26' Overlander
Greetings Beth!
Kevin
Kevin, I looked back over our thread discussion on these floors right after we bought the Minuet 2 weeks ago. We were actually at Home Depot last night and were going to look at the floors you had recommended, but couldn't think of "quiet step" but we'll look later - other things to do on the trailer in the meantime.
Thanks again.
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 03-04-2009, 10:26 AM   #11
campman's Avatar
1979 Argosy Minuet 6.0 Metre
JACKSON , Mississippi
Send a message via Skype™ to campman
Kevin...some time ago you stated this about the 78 minuet: "originally, the tongue, banana wraps, and rear bumper would have been painted a highly metallic copper"...
Is this true of the '79 6.0? I have never seen any of the original pictures in old ads that show other than the same color of the unit in total. My '79 was, as common, manufactured in '78. I would appreciate your thinking. Thanks a lot, Dan
Dan in Mississippi, formerly of Ohio, New Hampshire, Alaska, New York and New Guinea...among others.....
From Paul Theroux: ..the difference between a traveler and a tourist is.."travelers don't know where they're going, and tourists don't know where they've been"
campman is offline   Reply With Quote
Old 03-04-2009, 01:03 PM   #12
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Look at Vintage Airstream Photo Archives for pictures of '79 Minuets. None seem to have the bronze lower painted areas, though most may well have been painted since new.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 03-04-2009, 01:16 PM   #13
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
The copper color referred to on Argosys is only on the very bottom and may not be consistent on 79s. I attached a pic of our 77 during an axle upgrade a few years ago and you can see the sections that were really dark copperish.
The sales literature here shows a picture of an Argosy with banana wraps that are the same color as the body
Name:	minuet banana color.jpg
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-04-2009, 01:49 PM   #14
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Out-of-Doors Mart can fax or e mail you a list of all paint color charts for trailers and motor homes of the Argosy years. It is a helpful guide when restoring the Argosy trailer.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Is a '77 Argosy worth $6,800? anna.kerwin Trailer Values 13 03-04-2008 09:09 AM
For Sale 1974 Argosy. What is it really worth altamont All Argosy Trailers 3 10-09-2007 11:10 AM
Argosy Minuet anniefanny Member Introductions 7 04-25-2006 08:12 AM
worth of a 73 26ft Argosy 59toaster All Argosy Trailers 4 07-14-2004 12:11 PM
