Old 10-14-2013, 09:58 AM   #1
1977 Argosy Minuet 6.0 Metre
Woodland , Washington
What does sealing an Argosy before paint look like
We will be working on the body over the winter, getting ready for spring paint. From what we can tell, we have the usual leaks around the light fixtures (exterior running) and around one of the roof vents.
We do not intend to remove any interior siding if not necessary. We will be gutting, removing all cabinets and bathroom fixtures for a thorough cleanup / fix.
From what I can tell, we should drill out the rivets on the roof vent and seal and re-rivet. makes sense. Same with the lights
But what about the seams themselves. Do you just, as a precaution, put some sealer on prior to paint? Or if it is not leaking don't mess with it?
I have seen the comments on sealers, I think we are OK with our understanding, but if someone wants to repost their thoughts, I will take it in this link.
Carl
woodlandfarm is offline   Reply With Quote
Old 10-14-2013, 10:32 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Is there something wrong with the roof vent, or are you replacing it with a newer type like a FantasticFan? Unless it was improperly installed, you may be able to reseal it in place. If you're going to the effort of drilling out the rivets, having 2 trailers with the original vents and fans I would take that opportunity to install a modern one. (In fact that's what I'm doing with the vents in the 28' rear-bedroom trailer... I'm going with the MaxxFan Deluxe so they can stay open in the rain.)
— David
Old 10-16-2013, 05:00 PM   #3
So maybe if I rephrase the question... Do you put sealant on seems before you paint, even if they are not leaking. Do you just cover the rivet heads, or do you take the rivits out and re-seal and replace?
Old 10-16-2013, 07:41 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
Sealant by its very nature would expand and contract, paint does not. I would remove all sealant currently on the trailer during the paint prep, paint and then re- seal. That way when the sealant fails in the future you can remove it and seal again.
reinergirl is offline   Reply With Quote
Old 12-05-2013, 06:33 PM   #5
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
It probably depends on the paint you use. I've caulked all seams with Trempro 635 in preparation for painting. If you use a urethane paint like Boat Doc used on his Argosy, then, according to Boat Doc, definitely caulk before painting. Automotive paint may be different.
When I get to the point where I paint my Argosy, I'll be going the urethane route. I think urethane is the way to go, at least from my research so far.
DryFly is offline   Reply With Quote
