Old 01-26-2019, 07:04 AM   #1
1977 Argosy 20
Olive Branch , Mississippi
What do these do?
What do these do or what are they in my 1977 Argosy.
ID:	332369   Click image for larger version
Argo20 is offline   Reply With Quote
Old 01-26-2019, 07:37 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
What do these do?
Greetings Argo20!
The device in the top photo is your coach's furnace. When I enlarged the photo, I was able to identify the lighting instructions. It is a different model than the one that is in my 1978 6.0 Metre Minuet, but the lighting instrtuctions appear to be the same.
The fixture on the ceiling in the bottom photo, I do not recognize. It is too small to be part of a rooftop TV antenna and the radio antenna would have been mounted beside the streetside front Panoramic wing window. It may be an aftermarket item.
Good luck with your investigation!
Kevin
P.S.: I am not absolutely certain, but from looking at the top photo, it looks like your Minuet may have the composite aluminum floors that most of the 6.0 Metre Minuets have.
Kevin D. Allen
AIR #827
Old 01-26-2019, 08:09 AM   #3
Tuco's Avatar
1988 32' Excella
Ojai , California
The bottom one is indeed where the crank was for the antenna.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 01-27-2019, 11:47 AM   #4
georgezink's Avatar
1977 Argosy Minuet 6.0 Metre
Cape Coral , Florida
Images: 34
The plumbing fixture in the first photo is a valve for your waste line. It is used instead of a vent stack thru the roof. It allows for the water to flow easily. It opens to allow air in as water flows out, otherwise stays closed so odor can't get inside trailer. Usually doesn't give you a problem.
flcracker
georgezink is offline   Reply With Quote
Old 02-20-2019, 08:13 PM   #5
1977 Argosy 20
I have more “what do these do” pics
What do these things do?
ID:	334065   Click image for larger version
ID:	334067   Click image for larger version
Old 02-20-2019, 08:20 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Top Left - Water Heater
Top Right - Furnace
Bot Left - Refrigerator
Bot Right ????
Richard
Old 02-20-2019, 08:25 PM   #7
1977 Argosy 20
And these?
ID:	334070   Click image for larger version
Old 02-20-2019, 09:02 PM   #8
1969 18' Caravel
Greenville , whereEverIroam
I'll take a stab
I believe the plastic grid looking thing on your ceiling is a speaker.
The unit labeled Iota is your battery charger: see more here:
https://www.iotaengineering.com/dls55.htm
The circular metal or plastic thing in your kitchen appears to be a towel holder. It is attached to the plastic "chimney" that directs waste heat from your refrigerator up and out a vent in your roof. Next to the chimney are power outlets, 110 volt standard outlets that likely only work when your trailer is plugged into what we call "shore power" meaning the RV outlet you find at campgrounds so equipped. Above the 110 is, I believe, a 12 volt DC "cigarette lighter" type outlet that is powered from your Battery and/or charger/converter.
Under those is a metal catch for your window blind to hold it closed when you pull the blind down and hook it underneath on both sides. Next is a one of two levers used to open and close your window.
And, the last picture, I believe is a lever to open the exterior exhaust vent for your -over-the-range hood fan, and a switch to turn the fan on and off.
Hope this helps.
skyguyscott is offline   Reply With Quote
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
What do you think about these forums? Andy R Our Community 11 10-28-2006 06:56 PM
Have you ever seen one of these Dave Bowers On The Road... 7 01-11-2003 12:37 PM
can you ID these trailers? john hd Our Community 24 12-14-2002 09:48 AM
What are these........ wires for? niftypkg Electrical - Systems, Generators, Batteries & Solar 2 10-13-2002 01:21 PM
