Old 01-15-2007, 12:46 PM   #1
PoconoAir's Avatar
1965 17' Caravel
Canadensis , Pennsylvania
Images: 26
What Argosy is This?
I was looking for an Airstream and came across this Argosy by Airstream. It is the right size for what I want to do and certainly less of a project than the '55 AS I am considering. I forgot to measure it (on private property!) Looks like it has not been use for a while. Should I bother trying to contact the owner?
Name:	Aft Reduced.jpg
ID:	30845   Click image for larger version
Name:	Curb Reduced.jpg
PoconoAir is offline   Reply With Quote
Old 01-15-2007, 12:52 PM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi Poconoair, I would contact the owner if you are interested in it. The door looks a bit messed up. But if the insides are good and that is the only thing you have to worry about, probably not a bad deal IF they want to sell it.
I am sure someone else will chime in here.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 01-15-2007, 01:06 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
At first guess I'd say it's a 24 ft. The AC unit is not original - no loss. Looks like it might have worthington aluminum propane tanks (painted) hang onto those!
That trailer needs a bath!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-15-2007, 01:13 PM   #4
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I have a 24ft 78 Argosy and this looks a little longer than mine. May be a 26ft. Probably a 76 or older, but looks pretty good except for that door thing and it could be the door is just open. Worth a try to see if owners want to sell. Good luck to you. An Argosy is a great trailer. I'm including two pictures from similar angles so you can judge length. Think I'd ask why it has those blocks under the rear end.
ID:	30848   Click image for larger version
juel is offline   Reply With Quote
Old 01-15-2007, 01:20 PM   #5
Janet H's Avatar
1964 26' Overlander
Images: 90
I don't think so... all the photos i can find of 26 footers have 2 windows curbside.
Do you have any pics of the other side or the vin? The vin contains all this info including where it was made, year and length.
Old 01-15-2007, 01:24 PM   #6
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Street Side Image
Apple for apple, do these hold their value as well as a plain AS?
thanks for comments
Name:	Street Reduced.jpg
Old 01-15-2007, 01:25 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It is definitely a '73 or '74. '72 had no reflectors mounted on the banana wrap, and '75 was a single color, not two-tone. Rear taillight binnacle was also changed in '75. Looks like a 24' trailer. Also, midships windows indicate center twins. Streetside bedroom window would be further forward if it were a double, the window is where the closets are on a double.
Old 01-15-2007, 01:26 PM   #8
PoconoAir's Avatar
1965 17' Caravel
Images: 26
The Plate
I guess the length is in there somewhere.
Name:	Plate Reduced.jpg
Old 01-15-2007, 01:31 PM   #9
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Looks like a '24, here is a pic of my 26'
Make an offer!
Where did you say it was?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-15-2007, 01:32 PM   #10
Janet H's Avatar
1964 26' Overlander
Images: 90
thanks for comments
You will find mixed opinions about this. originally they sold for les money than unpainted airstreams... they were lighter weight and often had cutting edge design items. They were sort of the beta test bed for standard Airstreams. Many of the features of these old trailers are now standard on new Airstreams. They have become desiralble becasue of their light weight, but don't kid yourslef, you will have lots of repair issues with an abandonded trailer of this age.
Leaks, floor rot and old axles will all have to be fixed or replaced. Systems may have to be replaced and paint will need to be redone... but once finished, you'll have a great trailer!
Old 01-15-2007, 01:32 PM   #11
Well Preserved
1993 21' Sovereign
24T4V1181= 24 feet length, center twin beds, 1974 model, built Versialle, Ohio, 1181st off the assembly line.
Old 01-15-2007, 01:37 PM   #12
Janet H's Avatar
1964 26' Overlander
Images: 90
One of the cool things about argosys is that you can still occasionally pick one up for a song. They resell well, once fixed. we have been offered big bucks for ours.
But.. the days of great deals are rapidly disappearing.
Old 01-15-2007, 01:47 PM   #13
PoconoAir's Avatar
1965 17' Caravel
Images: 26
Certainly if I get in contact with the owner and eithere don't make an offer or have my offer rejected, I will give the contact to someone here. This will take a week or more.
If the end caps are steel how did AS cut weight in these? Steel floor frame, right? Does that plate say 5800something# GVW?
Old 01-15-2007, 02:32 PM   #14
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
I se that the owner has it jacked up and on blocks.Also door looks like it was pried out at the bottom no crease lucky. check the tires for dry rot if they are it would be easier to change while jacked up..
just want to camp happy
bobchevy89 is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 12:45 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 05:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 10:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 08:14 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 08:39 PM
