01-15-2007, 11:46 AM
1965 17' Caravel
Canadensis
, Pennsylvania
What Argosy is This?
I was looking for an Airstream and came across this Argosy by Airstream. It is the right size for what I want to do and certainly less of a project than the '55 AS I am considering. I forgot to measure it (on private property!) Looks like it has not been use for a while. Should I bother trying to contact the owner?
01-15-2007, 11:52 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Hi Poconoair, I would contact the owner if you are interested in it. The door looks a bit messed up. But if the insides are good and that is the only thing you have to worry about, probably not a bad deal IF they want to sell it.
I am sure someone else will chime in here.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
01-15-2007, 12:06 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
At first guess I'd say it's a 24 ft. The AC unit is not original - no loss. Looks like it might have worthington aluminum propane tanks (painted) hang onto those!
That trailer needs a bath!
01-15-2007, 12:13 PM
1976 31' Sovereign
Chandler
, Oklahoma
I have a 24ft 78 Argosy and this looks a little longer than mine. May be a 26ft. Probably a 76 or older, but looks pretty good except for that door thing and it could be the door is just open. Worth a try to see if owners want to sell. Good luck to you. An Argosy is a great trailer. I'm including two pictures from similar angles so you can judge length. Think I'd ask why it has those blocks under the rear end.
01-15-2007, 12:20 PM
1964 26' Overlander
OlyPen
I don't think so... all the photos i can find of 26 footers have 2 windows curbside.
Do you have any pics of the other side or the vin? The vin contains all this info including where it was made, year and length.
01-15-2007, 12:24 PM
1965 17' Caravel
Canadensis
, Pennsylvania
Street Side Image
Apple for apple, do these hold their value as well as a plain AS?
thanks for comments
01-15-2007, 12:25 PM
Retired.
, At Large
It is definitely a '73 or '74. '72 had no reflectors mounted on the banana wrap, and '75 was a single color, not two-tone. Rear taillight binnacle was also changed in '75. Looks like a 24' trailer. Also, midships windows indicate center twins. Streetside bedroom window would be further forward if it were a double, the window is where the closets are on a double.
01-15-2007, 12:26 PM
1965 17' Caravel
Canadensis
, Pennsylvania
The Plate
I guess the length is in there somewhere.
01-15-2007, 12:31 PM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Looks like a '24, here is a pic of my 26'
Make an offer!
Where did you say it was?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
01-15-2007, 12:32 PM
1964 26' Overlander
OlyPen
thanks for comments
You will find mixed opinions about this. originally they sold for les money than unpainted airstreams... they were lighter weight and often had cutting edge design items. They were sort of the beta test bed for standard Airstreams. Many of the features of these old trailers are now standard on new Airstreams. They have become desiralble becasue of their light weight, but don't kid yourslef, you will have lots of repair issues with an abandonded trailer of this age.
Leaks, floor rot and old axles will all have to be fixed or replaced. Systems may have to be replaced and paint will need to be redone... but once finished, you'll have a great trailer!
Retired.
, At Large
24T4V1181= 24 feet length, center twin beds, 1974 model, built Versialle, Ohio, 1181st off the assembly line.
01-15-2007, 12:37 PM
1964 26' Overlander
OlyPen
One of the cool things about argosys is that you can still occasionally pick one up for a song. They resell well, once fixed. we have been offered big bucks for ours.
But.. the days of great deals are rapidly disappearing.
01-15-2007, 12:47 PM
1965 17' Caravel
Canadensis
, Pennsylvania
Certainly if I get in contact with the owner and eithere don't make an offer or have my offer rejected, I will give the contact to someone here. This will take a week or more.
If the end caps are steel how did AS cut weight in these? Steel floor frame, right? Does that plate say 5800something# GVW?
01-15-2007, 01:32 PM
1977 24' Argosy 24
Inverness
I se that the owner has it jacked up and on blocks.Also door looks like it was pried out at the bottom no crease lucky. check the tires for dry rot if they are it would be easier to change while jacked up..
just want to camp happy
01-15-2007, 01:42 PM
Retired.
, At Large
5800#GVW =3800 MT trailer, plus options and "stuff". 3800 plus 200 for an air conditioner, plus 60 pounds for LP+ the weight of the tanks, + the weight of the water in the holding tanks, + the weight of the awning, it should weigh about 4500 pounds in working order, plus consumables.
