Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 06-26-2016, 01:14 PM   #1
75ArgosyRob's Avatar
1975 Argosy 26
Ripley , West Virginia
weather stripping for access compartments
curious of what styles, brand, size or where to order new weatherstripping/door gaskets for the access/storage compartments for my 75 26' argosy?
any feedback?
Battery door, interior lip measures 1/2"wide and 1/2" tall
[/URL][/IMG]
under bed access, 3/8" wide 3/8" tall
[/URL][/IMG]
75ArgosyRob is offline   Reply With Quote
Old 06-26-2016, 06:18 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
1/4h x 5/16w epdm rubber weatherstrip "D" shape
Order online. I bought mine at grainger. I've got 200 ft, so of your in or near birmingham alabama stop by and I'll give you what you need! Then we can go to lunch on you😁
Matt
rugjenkins is offline   Reply With Quote
Old 07-02-2016, 10:30 AM   #3
1976 Argosy 26
diamond bar , California
I'm not to sure if the battery door gets the weather strip. I think the batteries need to vent to the outside, unless you go AGM type.
I thought building a box and venting to the outside would be easy. I purchased (2) 6v batteries at Costco, a dual battery box, fittings to vent to the existing door, and though the bottom. My plan was to add a panel behind the battery door and vent to there.
I read somewhere, someone did a similar install but also added a exterior shower behind the existing door.
AGM's and seal the door probably was the best way looking back, as others suggested.
909kenu is offline   Reply With Quote
Old 07-04-2016, 10:48 AM   #4
triterra's Avatar
1969 27' Overlander
1976 Argosy 28
1978 28' Argosy 28
Lodi , California
I used standard D from out of doors mart (an airstream online store) and local big box store. I put them on with weatherstripping adhesive (auto parts store). The double sided tape will not hold it in place for long. Start at the bottom center of the door and work around. I used the same on my Windows.
triterra is offline   Reply With Quote
weather stripping Londoner Windows, Doors, Locks & Vents 7 07-13-2008 08:03 PM
Somebody put some weather stripping... nds Our Community 7 01-23-2004 11:52 AM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
