I presume you mean "plastic s
mell"... I would empty the fresh water tank if it has been sitting there a while, and either do a full sanitation treatment (the process can be found in this sub-forum:
Fresh Water Systems - Airstream Forums ) or refill the tank adding a weak bleach solution to the fresh water tank...it may take several treatments to get rid of the smell... We add a weak bleach solution to our fresh water periodically or when we are using an unfamiliar water source.
Good luck!
