Water pump location on my '74 reardoor 22ft Argosy
La Tortuga has slid into spring '13 as a project, so I need to address the freezing issue ASAP since we're getting
pretty low temps here in the Bitterroot starting tonight.
The PO had just replaced the water lines when I acquired her so the tanks are dry but I don't know if there is any residual
moisture in the pump, so since time is limited, I'd just remove the pump for the winter.
Another wrinkle, it's w/o power, the intellipower is sitting on the floor currently, not yet installed. But where is the pump?
SS
