Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-16-2018, 01:36 PM   #1
Amclay22's Avatar
Bedford , Texas
Water Leak Underneath Argosy
Hello, can anyone offer advice for troubleshooting a water leak underneath our 1977 Argosy? We didn't have a leak until after a 21 hour trip from NM to TX and it wasn't until after we hooked up to water line and the water drained to the grey tank. Then we saw the water leak out of the bottom of the camper. Advice? Things to check? Let me know! Thanks!
Amclay22 is offline   Reply With Quote
Old 07-16-2018, 05:01 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Check to see that the drain valves are closed. There is (was) a pressure regulator near the water inlet that drains off water if line pressure is too high. These are things you can spot as pipes or hoses hanging down from the belly pan. If the leak is coming from a seam in the belly pan, then the source is harder to find.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-17-2018, 07:40 AM   #3
Elk Rapids , Michigan
There's really not enough info to help here, the reply above pretty much says as much as anyone can without more details.
But, there's a fairly good chance that one of your copper lines has corroded through. Have you looked at all the places you can see without disassembling stuff? Put the pressure back on it and look underneath the bathroom and galley sinks, along the line on the street side that comes from your fresh water tank. Drain the black and grey tanks to make sure you don't have a leak there.
Chances are though you are about to become familiar with PEX, ABS, or both. 41 years is a pretty good run for plumbing in your house, and your house isn't going down the road at 65mph. Once you start looking you'll probably find it's been leaking much longer than you think and there's rot in the floors.
Sorry to be the bearer of bad news, hopefully it will just be an open drain valve but be ready to dig into your trailer and replace all the plumbing if you want it reliable and trouble free....
Cheers,
John
matthewsx is offline   Reply With Quote
Water drip underneath dsheridan 2009-2015 Flying Cloud 3 08-31-2016 09:49 AM
Water leaks from panels underneath Airstream Nicknbarb Repairing/Replacing Floor &/or Frame 5 09-21-2014 12:01 PM
Leak underneath bead parson jon Land Yacht/Legacy Motorhomes 1 06-06-2014 11:46 AM
'79 Sovereign rear bath dripping water underneath!! al franklin Sinks, Showers & Toilets 9 08-03-2011 04:07 PM
Water tank plate underneath LI Pets Waste Systems, Tanks & Totes 3 09-19-2006 08:52 AM
