Old 10-29-2014, 01:53 PM   #1
1977 24' Argosy 24
SW Florida , Florida
Images: 8
Want Electric Jack for Argosy 20' Trailer
Hi, All,
It's been quite a number of years since I logged into this forum. That being said, I am older and a bit wiser and wish to buy an electric power jack for my 20 foot Argosy camper. I am tired of cranking it up and down by hand.
Has anyone any suggestions as to what is best? I called some generic RV place and was told $350, then after several exclamations on my part, the guy miraculously "found" his lowest priced one for $200. I did not get off the boat yesterday, but I think he might have!
Does the old original crank jack get removed and an electric one put in its place? What runs the electricity to it?
Thanks for any and all help.
Elisa is offline   Reply With Quote
Old 10-29-2014, 03:13 PM   #2
1976 31' Sovereign
Oswego , Illinois
Smile electric jacks
Originally Posted by Elisa View Post
Hi, All,
You can find jacks reasonable priced on ebay. Barker is a good brand & good price. For electric for jack, the hot wire for breakaway swt can be spliced into as it will not interfere with breakaway swt. Jack self grounds thru mounting bolts
Old 10-29-2014, 03:31 PM   #3
1977 24' Argosy 24
Images: 8
So does the old jack need to come off or can the new one be mounted close to it? I need someone to do this...
Old 10-29-2014, 03:52 PM   #4
1974 Argosy 20
Kooskia , Idaho
The new one bolts in place of the old one. Three bolts and one wire will get you in business.
Old 10-29-2014, 03:57 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Today I swaped out my busted Barker for a new heavy duty Barker. It took about 30 minutes from start to finish.
MICHAEL
Old 10-29-2014, 04:50 PM   #6
1977 24' Argosy 24
Images: 8
Hey, I can cover couches, make curtains, fix the gas stove, paint, clean, etc., but I am CLUELESS with tools. Gonna have to pay to get this done.
Old 10-30-2014, 05:27 PM   #7
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
How did you fix the gas stove without tools?? How do you do upholstery and make curtains without tools? You probably know more than you think you do!
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 10-30-2014, 06:21 PM   #8
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
3 bolts and 1 wire are really not a high tech problem. Currently is one selling for $135 at a local surplus store. You should be able to beat that Stateside. Find someone that is mechanically inclined and barter services for the install. Perhaps a home cooked meal or some sewing would work.
Gearheart is offline   Reply With Quote
Old 10-30-2014, 10:48 PM   #9
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Block the tongue up so you can take the jack out. Take out the three bolts and lift the old jack out. The whole thing lifts straight up leaving a hole in the tongue. lower the new jack into the hole, align the three bolt holes, insert the bolts and tighten them down. The jack is now installed. Find the lead to the break away switch that is "hot", splice the wire to the jack into that wire and you are done. Adventure RV usually has electric jacks on sale.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 10-31-2014, 09:08 AM   #10
1977 24' Argosy 24
Images: 8
Thank you all, particularly for the step-by-step directions.
What about something like this that is separate: Powerbuilt 3 Ton Unijack Truck Lift Jack - Walmart.com
Old 10-31-2014, 12:12 PM   #11
Gainesville , Florida
Doesn't look like the right thing. Go to the camping world site for what is available. Etrailer also has a good selection.
Old 10-31-2014, 05:35 PM   #12
1978 Argosy 24
MooreHaven , Florida
The Walmart jack would not be much help,it only lifts about 3 1/2 inches,needs to be pumped by hand and would have to be stored somewhere and carried to the front of the trailer every time you needed it. The one you need replaces the original so requires no carrying or storing also no hand pumping.Do a search on ebay for trailer tongue jack you will find plenty of them and the install is really simple,even if you decide to pay some one to do it it`s a 20 minute job.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 10-31-2014, 07:02 PM   #13
AWCHIEF's Avatar
Images: 33
I got my mew Barker jack from Amazon. They had the best price that I found. Free shipping and no tax with Amazon Prime.
MICHAEL
Old 02-22-2015, 05:16 PM   #14
Sun Rae
jack9443's Avatar
1977 Argosy 28
Lewisburg , Tennessee
Try harbor freight was around $125.00 last Thursday
jack9443 is offline   Reply With Quote
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 04:02 PM
Trailer front electric jack mocus Towing, Tow Vehicles & Hitches 29 07-29-2012 03:21 PM
I want new Fantastic Fans but I dont want to give up the lights. memgrove2000 Roof Vents, Skylights & Fans 4 03-10-2009 10:21 AM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 09:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 10:50 AM
