Old 08-24-2009, 10:09 AM   #1
1974 Argosy 24
Winston Salem , North Carolina
upgrading to a grey tank in a '73
Greetings everyone
after using our 1973 Argosy 24 now for a few times i am tempted to install a grey water tank.
Has anyone attempted to do this ?
my first idea is to install one in between the wheel mounts, so that the trailer is not out of balance if i would have to travel with a full tank.
any thoughts are greatly appreciated
Michael
michael13 is offline   Reply With Quote
Old 08-26-2009, 11:23 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
No takers on the question I see.
It is a difficult proposal.
You may want to consider one of the portable
external shuttle tank if you are in a location that
doesn't have a sewer hook-up.
kennethowens is offline   Reply With Quote
Old 08-26-2009, 12:20 PM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
We installed a gray tank in our 63, but I assume you could do something similar in yours. Here is a link to our blog describing the process. Hope it helps!
http://www.airforums.com/forums/blog...tallation-144/
http://www.airforums.com/forums/blog...on-update-166/
FLYNCLD is offline   Reply With Quote
Old 08-27-2009, 09:15 AM   #4
1974 Argosy 24
thanks for the blog link
this helps a lot
this will be a project for next spring/ summer
definitely worth attempting
Old 09-08-2009, 05:26 AM   #5
1973 Argosy 22
WINDSOR , Ontario
i have a 73 and love not having a grey. We use the portable tank and find we can stay longer without have to go and dump after only a few days. Good Luck
MAVERICK is offline   Reply With Quote
Old 09-08-2009, 05:41 AM   #6
2008 16' Safari
Destrehan , Louisiana
While I'm sure you could find a way to do it, I'm not sure it would be worth the effort. The blue boy is probalbly a better choice. Easy to use and portable. Trailers had grey water tanks installed after regulations changed and the were required in new trailers. If you camp at a full hook-up site, you don't need a grey water tank. If you're boondocking, you can just run a hose and let the grey water go. Again, you don't need the grey water tank. If you're at a regular camp site with no full hook ups, you can pull out the portable tank. I never saw a need to install a grey water tank in my old 72 AS. I find the grey water tank in the new trailer to be more of a PIA than a convenience.
dlb435 is offline   Reply With Quote
Anybody add a grey tank to late model bambi? sigv Waste Systems, Tanks & Totes 3 05-27-2012 09:54 AM
Grey Water tank. is it really necessary? Slowride66 Waste Systems, Tanks & Totes 22 10-11-2011 12:54 PM
Grey tank inlet help? brattwurzt Waste Systems, Tanks & Totes 1 08-21-2011 07:54 PM
Grey water tank for 1973 AS Tradewind 25' mick20 1970-79 Tradewind 4 06-07-2011 12:43 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
