Old 03-26-2005, 10:02 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Talking Update to the 76 Argosy 24 (the White Pearl)
Gaucho Re-upholster -er
Although the original color in the galley is green, we have decided to add a splash of Yellow. With a little luck we may have it in place today!
ID:	11201   Click image for larger version
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-26-2005, 12:27 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
WOW! That's gonna look great. I redid our Minuet cushions - that side couch was a handful. Have you discovered the trick with a vacum to aid stuffing foam into fabric?
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-26-2005, 12:38 PM   #3
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Talking It's in!
Thanx! Yes, what a hoot, kids thought we were loosing it!
Turned out pretty good.
www.balrgn.com
Old 03-26-2005, 07:27 PM   #4
mandolindave's Avatar
Well.....................
What is the trick with the vacuum?? It's a pain to get the corners
in the right place!!!!!
mandolindave is offline   Reply With Quote
Old 03-26-2005, 07:34 PM   #5
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
The trick is to wrap the foam in a garbage bag or even cling wrap - tape up the seams with packing tape. Cut a 1 inch slit on the side of plastic nearest to closure of fabric cover, and use a vacuum cleaner hose (in suck mode) to remove air from foam. It gets really small - quick, and you can just slide it right into cover. Cut plastic off and pull out. Works like a charm - but I have to admit it does look a little odd to casual spectators....
Old 03-26-2005, 09:39 PM   #6
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Gee, how about we try....
THAT manuver at the next rally! Who's gonna bring the vacume cleaner!
Sort of a "foam rodeo!" Fastest cushion stuffer wins!
Marc
Old 03-27-2005, 08:21 AM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thumbs up Toilet Lid
Is there a resource for replacement parts for the original toilets? I have a broken lid hinge.... Is it worth repair?
ID:	11214   Click image for larger version
www.balrgn.com
Old 03-27-2005, 08:34 AM   #8
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I don't know if you have a Thetford, I suspect that you do, I have in the past contacted the company and they were very helpful. Just had a problem, needed a seal, and could not get any help from the company. It looks like now you have to go through a dealer to get parts.
The fabric looks great! Thanks for the vacuum tip.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-04-2005, 11:06 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Angry Leak source
Found the source of my floor wetting problem. Looks like the factory either did not seal the seam or we very stingy with the sealant.
www.balrgn.com
Old 04-04-2005, 11:08 AM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thanks for the hint, I looked online, found one that looks like it will fit, just have to decide if I want to restore this one or get a new one that has the flush on the top back side.....
www.balrgn.com
Old 04-04-2005, 12:30 PM   #11
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Update
For what it's worth, I replaced my original toilet with the Brauva low profile, but I had to remove the door from the cabinet behind the toilet and still can't keep the toilet lid up without holding it up!!
Don
Gunnyusmc is offline   Reply With Quote
Old 04-04-2005, 12:53 PM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Broke lid
Don
Good to know, I'll steer clear of that one.
I was thinking of an Aqua Magic Low profile. The one on there now is a bit tall and I'm not partial to the foot flush, seems like you put unnecessary stress to the base....
www.balrgn.com
Old 04-04-2005, 01:16 PM   #13
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I rebuilt my toilet last year - wanted to stay original - got my parts from Marks RV - great folks to work with and good prices - www.marksrv.com I think is the web site - let me know if that doesn't work and I'll look further. I think all parts are available.
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 04-04-2005, 04:37 PM   #14
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 90
HI we replaced our toilet - the only model we found that would fit without cutting out the "hidden" campartment was a sealand traveler lite. It comes in 2 hieghts (ours was the lower height) and several colors - it's a big improvement. DO a forum search for argosy toilet replacement to find detailed info about toilet swaps.
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 34 02-06-2019 09:46 PM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 05:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 10:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 08:14 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-03-2002 12:21 AM
