Old 04-04-2005, 09:10 PM   #15
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Originally Posted by Gunnyusmc
For what it's worth, I replaced my original toilet with the Brauva low profile, but I had to remove the door from the cabinet behind the toilet and still can't keep the toilet lid up without holding it up!!
Don
Yep that's the problem. The lid pivot point is too far back on most of the newer toilets. The Sealand is in the right position, forward of the back of the toilet.
It's a tight fit but I did it so can you.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-04-2005, 09:34 PM   #16
moogie32's Avatar
1967 22' Safari
Branford , Connecticut
Images: 11
Sealand 910 parts! Yippee!
Originally Posted by Ken J
I rebuilt my toilet last year - wanted to stay original - got my parts from Marks RV - great folks to work with and good prices - www.marksrv.com I think is the web site - let me know if that doesn't work and I'll look further. I think all parts are available.
Ken J.
Checked them out and now I know I can put my original Sealand back in without it leaking - they'll have everything I need. Thanks for the tip! Diane
moogie32 is offline   Reply With Quote
Old 04-04-2005, 09:41 PM   #17
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
When we installed the traveller in Vintage Thunder we left the anti siphon cover off the water inlet and cut the underside of the cabinet for it to fit inside of. It can be done, but as Gary said it is a tight fit. I must have set the toilet on the flange at least a dozen times to get it "just right".
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-15-2005, 03:04 PM   #18
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Talking Power
Out with the old, in with the new. No more noisy Univolt!
ID:	11550   Click image for larger version
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-15-2005, 03:32 PM   #19
Originally Posted by Janet
HI we replaced our toilet - the only model we found that would fit without cutting out the "hidden" campartment was a sealand traveler lite. It comes in 2 hieghts (ours was the lower height) and several colors - it's a big improvement. DO a forum search for argosy toilet replacement to find detailed info about toilet swaps.
I thought that maybe the Aqua Magic V would fit?
balgrn is getting my brand new Aqua Magic IV because it will fit in the standard Argosy but not the Minuet.
I looked at the dimensions of the Aqua Magic V and the set-up for the lid and it looked like it would fit.
How well did the Sealand Traveler Lite fit? Compared to the Aqua Magic III?
Anon is offline   Reply With Quote
Old 04-15-2005, 06:42 PM   #20
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Still waiting for delivery. Have to check to see if It will go in the Trade Wind or the Argosy now....... This is getting confusing working 2 at the same time!
www.balrgn.com
Old 04-15-2005, 10:43 PM   #21
I sent it out via FedEx.
You should have it by Monday from what I understand.
I would give you the tracking number but I think I left it out in the car!
Don't worry, you will have your toilet soon!
Old 04-15-2005, 10:45 PM   #22
It works fine too!
I tried it out for you to make sure!
Lift the lid S-L-O-W-L-Y!
Old 04-16-2005, 01:24 AM   #23
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
balrgn,
I'd say you're making the right decision in replacing the original. From what I've been told, a broken hinge is darn near impossible to repair on these products.
My goof...
About three years ago, the valve that is an intergrate part of the hinge on mine broke and, I just by-passed the valve rather than go to all the trouble of replacing the entire toilet unit. (I suspect it still had some water left in it before winter set in.) *#*% happens..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-16-2005, 05:08 AM   #24
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Not a problem, We're in an Outage at work, so I'm working 7 12's for now. I did sneak out yesterday when we had a lull. So what do I do, go home and play with the campers!!! Felt good too!
www.balrgn.com
Old 04-26-2005, 03:52 PM   #25
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Talking Polishing
I know I still have a ton of work on the inside, but my polishing supplies have been coming in. I wanted to get a bit of practice before I start on the Trade Wind. I've washed the White Pearl several times and have found no good cleaner or way to get the grime off. So I tried out the new Cyclo with some fine automotive compound. It works pretty nice! Smother to the touch and the color is consistent now. Tis the season to polish!
www.balrgn.com
Old 04-26-2005, 05:55 PM   #26
1964 26' Overlander
1977 25' Tradewind
Lou
We replaced the toilet in our Minuet and found the Sealand Traveler (Low rise)
Fit perfectly. No alterations requires and the lid and seat opened all the way.
It is a little tight getting it in, but well worth the trouble.
Works great, easy to clean, and the valves can be replaced.
Peace
Gary
Old 04-26-2005, 06:57 PM   #27
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Nice looking Argosy Balrgn.
juel is offline   Reply With Quote
Old 05-21-2006, 03:10 PM   #28
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
It's been a while since I posted to this thread.
Here is an update
http://www.balrgn.com/Argosy/Pearl/Pearl.htm
www.balrgn.com
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
