Old 11-27-2008, 10:03 AM   #1
campman's Avatar
1979 Argosy Minuet 6.0 Metre
JACKSON , Mississippi
Send a message via Skype™ to campman
Underbelly and insulation
My unit came missing the underbelly under the tanks. I knew this. Now I am ready to replace it. I am going to use .06 aluminum (or 1/16in) or stronger. I noticed an access cap on top of the black tank. 1. wonder what this is used for (it seems pretty inaccessable) 2. should I add any extra (perhaps one, narrow steel) support dead center front to back? and 3. I may want to do something to keep things warm there in cold weather use...and read in some other thread about a guy who installed a sheet of styrofoam under the aluminum and in that inserted a heat tape which he could plug in when needed. Is that a good idea or are there others? It does seem that if the heat tape were in any way next to any metal, it could rub and then short out and maybe cause problems we don't want. Any ideas others have will be welcome. Thanks, Dan
Dan in Mississippi, formerly of Ohio, New Hampshire, Alaska, New York and New Guinea...among others.....
From Paul Theroux: ..the difference between a traveler and a tourist is.."travelers don't know where they're going, and tourists don't know where they've been"
campman is offline   Reply With Quote
Old 11-27-2008, 10:30 AM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
wow .06 sounds very thin to me - I just replaced my whole belly with .32 - minimum you should use is .25
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-27-2008, 10:40 AM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Heat tape doesn't last for a long time. People who have used it to keep pipes from freezing in unheated crawl spaces learn that lesson. I did. Also, never wrap heat tape over itself—further shortens the life and could cause the insulation to melt.
Since you would be using it in a place that is difficult to access, you probably would not know when it was losing it's ability to heat the water tank. Also, a pipe has a lot less water than a water tank and you'd need a lot of heat tape. I don't know how you would wrap a tank and keep the tape in place—this stuff is made to wrap around pipes.
So, I think heat tape is not a solution.
Gene
Old 11-27-2008, 10:46 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I will leave comments as to the material for the belly pan to others.
I will say that you do not want to mix steel and aluminum, as per your comment of a strip down the center. This leads to electrolysis.
As for foam insulation that is a waste of time and money unless you are prepared to SEAL every nook and cranny. Insulation is only as good as to the completeness of the insulation, any gap, void, or open end is the same as leaving the front door open in a heated house.
Now I will say a sprayed on foam has several advantages. Completeness, lack of moisture absorption, and ease of installation. Foam will not have the same coefficient of heat transfer as some of the insulations that claim a higher coefficient but the completeness of installation will more than make up for that.
2004 Excursion 4x4
Old 11-27-2008, 10:55 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Ken J.
Ken, you missed the zero before the six, .06 is just under a 1/16th which is .0625 or commonly known as .063 which is a standard sheet aluminum thickness. Your other numbers should read .032 and .025. .32 is slightly over 5/16's and .25 is 1/4".
.06 is a little overkill for a belly pan. I believe that the stock thickness is as Ken stated above. I however used .040 5052 H34 because I got a screaming deal on it. The choice is yours however and if you use .063 it will be bulletproof.
Old 11-27-2008, 10:56 AM   #6
ronstory's Avatar
1975 23' Safari
Portland , Oregon
As for the thinkness, we are off a decimal place. Campman said he was going to use .06 which is 0.060.", pretty darn think. Ken refered back to .32 which is really 0.032". Just off a order of magnitude amoung friends.
Ron
ronstory is offline   Reply With Quote
Old 11-27-2008, 10:56 AM   #7
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Lol... Aerowood beat me to it.
Ron
Old 11-27-2008, 10:57 AM   #8
Ken J's Avatar
Durango , Colorado
Images: 14
Never mind....
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 11-27-2008, 05:14 PM   #9
campman's Avatar
Thanks for all that input. The price of the 0.063 here is quoted to me as $3.05/sq ft. So, if it is bullet proof as you say, it should be good. It weighs 0.90/lb per sq.ft and for the 22 sq ft I need that increases the weight onlhy by a little over 20 lb. Is that a bad price??
Now I will say a sprayed on foam has several advantages. So, HowieE...what do you recommend in terms of the TYPE of spray on? I would think you'd have to be careful in terms of future repairs and replacement of parts.
Attachment of underbelly to a new frame soldiermedic Belly Pans & Banana Wraps 11 04-04-2007 08:26 AM
Removing Underbelly Skin, Insullation kneal Belly Pans & Banana Wraps 1 12-04-2006 05:02 AM
Underbelly Skin Replacement Morning Dew Belly Pans & Banana Wraps 5 08-21-2003 09:12 AM
Aluminum underbelly missing Joe C 2002 - 2005 International 10 11-10-2002 09:41 PM
Underbelly Blues hex Belly Pans & Banana Wraps 3 10-24-2002 08:47 PM
