Old 03-17-2013, 08:22 PM   #1
1973 Argosy 22
Shepherdsville , Kentucky
TV Antennae
Well I'm back with another question. It's a good thing an old fart like me has a place like this to ask my questions. I have been looking at broadcast antennas and have been drawn to two different ones, the Winegard roadstar 3000 and the Jack digital. If you have any experience with either I'd like to hear about it, pros and cons. Tom
Tom S is offline   Reply With Quote
Old 03-17-2013, 08:34 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Old antennas still work pretty well
While waiting for someone to weigh in on new antennas, wanted to comment that we still have original crank-up and rotating aluminum rod folding antenna, and it works well at picking up UHF signals for our figital TV if we are anywhere near a transmitter antenna... The newer highly directional models bring stations in from greater distance if you know about where transmitter is located, but within 20 or 30 miles most antennas work OK...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 03-17-2013, 08:41 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I put a Jack digital in my Bambi II. Works great from my house....lots of stations. But I haven't had it out of the city, so don't know what will happen out in the boonies! Here's a picture so you can see the size relative to a 17' trailer:
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-17-2013, 08:42 PM   #4
1986 31' Sovereign
Miami , Florida
Your standard issue Winegard bat wing crank up antenna (as noted above) will work just fine. When the USA went digital, a lot of stations moved from VHF to UHF but both signals are line of sight so taller is better.
The only significant difference to the consumer is that it was possible to receive a crappy but watchable signal on analog (the old standard) while a digital signal will either work or it won't there is no medium...
Mike
Old 03-17-2013, 09:08 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The original folding rod, rotating antenna on our '65 Caravel picks up broadcast digital HD just fine, just like it did with the old analog signal. Replacing it has never crossed my mind.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-17-2013, 09:43 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
My Braund Skyliner works great too.
Replacing a working antenna to get HD is the greatest bunch of hokum since buying a special antenna to get color.
If your old antenna is broken or has missing pieces that can't be located, fine, replace it. Otherwise it will work great.
Vaughan
vswingfield is online now   Reply With Quote
Old 03-18-2013, 10:11 AM   #7
1973 Argosy 22
Using my original antenna isn't an option since it is gone. Becky, it doesn't look bad on your Bambi.
Old 03-18-2013, 12:17 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Too bad.
I agree about Becky's. If I were shopping for a new antenna, I think that's what I would get.
Vaughan
Old 03-18-2013, 01:04 PM   #9
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Newbie following intently. I have tried my TV to no avail. I cranked up the antenna, made sure the green light (booster) was on, turned TV on, and went thru chennel setup. What am i doing wrong? Does the antenna move around? sbb
Sbb is offline   Reply With Quote
Old 03-18-2013, 01:18 PM   #10
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Is your television set for the right input? Some TVs have different settings for cable vs. over-the-air signals, some have multiple coax inputs (for antenna and cable or satellite, e.g.)
There's also the possibility that there's an issue with the connection to the antenna or with the coax cable running from there to the wall plate near the TV.
Finally, considering the age of your trailer, there's a small possibility that you have a set that's not digital-capable without a converter.
David
Sirius/XM radio install. Howard L. Audio, Video & TV 8 04-25-2017 04:31 PM
Help finding Satellite dish jpeabody Land Yacht/Legacy Motorhomes 85 08-08-2013 06:43 AM
Tire pressure monitoring jetjocky Tires 15 09-03-2012 12:43 PM
