Greetings The Bohners!
Welcome to the Forums and the world of Vintage Argosy ownership!
Originally Posted by The Bohners
We just Purchased a 77 24 foot Argosy. No Manuals. The Electric Brake (tekonsha 90185) we installed on The Chevy keps blowing the 40 amp fuse once the trailer is hooked up. All of the lights, brake and turn signals work without the electric control, but again once the electric control is pluged in and the trailer is hooked to the truck the fuse under the chevy's hood pops. I'm wondering if the breakaway has something to do with it shorting out? Any help would be wonderful.
What you are experiencing is a common experience among the new owners of Vintage Airstream products. The cause is the fact that Airstream and Argosy utilized an umbilical cord wiring diagram that doesn't correspond to that used by our modern tow vehicles. It is rather easy to remedy - - you may be able to simply rewire the trailer end that you have, but it may be best to have a new trailer end available as there is often corrossion inside the connector. The color codes for your Argosy wiring (pay particular attention to the function of each wire color--some are different than in the current standard) can be found in the following:
Airstream and Argosy Bargman Connector Wiring Schematic
Your modern tow vehicle will likely have the industry standard Bargman connector wiring that can be found at:
Modern Standard Bargman Connector Wiring Schematic
The problem that you are having is far from unusual. What is likely causing your problem is that the charge line on your tow vehicle is connecting to the brake terminal on the trailer. Rewiring the trailer end IS NOT difficult - - I avoid do-it-yourself projects as much as is possible, but this is one that I have handled on both of my coaches - - a 12-volt garden tractor battery with a set of alligator clips can help in verifying the function of each of the wires in your trailer connector as you connect them (based on their function--not their color) to the marked teminals of your new connector.
Good luck with your coach!
Kevin
