Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 01-14-2008, 03:13 PM   #1
Red Rover
Profile:  austin , Texas
Smile Toyota Tacoma Tv?
Hello, this my first post and am a new member. I have a 99 Toyota Tacoma Prerunner, 3.4 V-6 190 Hp-220 Ft-LB torque. Auto-Trans- TRD- 5000lb tow pac. class III hitch. Wheelbase 121.9 I am looking to get an Argosy Minuet 20 or 22ft trailer. 2450-2725-lb weight if my info is correct? Would shure like to get feedback on what I might exp using this truck as a TV. Anyone know weight diff with the Argosy non "Minuet" 20 and 22Ft. Thank You Very Much For Your Help! Red Rover^^^
Red Rover is offline   Reply With Quote
Old 01-14-2008, 03:32 PM   #2
waltero
Profile:  1973 25' Caravanner
waynesboro , Virginia
Hey Red, I have a 73 Land Yacht 25'. I tow with a 2000 Tacoma extra cab
4wd with the 3.4 Litre v6 and manual transmission. I use a Reese dual cam hitch and have done fine, including a trip this fall to Helen Ga...a real test to get in and out of Helen! I guess you could say I've been to Helen and back...good luck, I think you'll do fine with the right hitch set up!
waltero is offline   Reply With Quote
Old 01-14-2008, 04:04 PM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Waltero, what engine do you have? 3.4L V6 just seems small.
Red Rover, I know a member from the northwest has been talking about his Tacoma. It might have been one of these:
http://www.airforums.com/forums/f463...tml#post490799
Sure would LOVE LOVE LOVE some help.
It's not always a sure thing that those folks would look back in at the right time to see your thread.
Old 01-14-2008, 04:30 PM   #4
Igor68
Wagon Master
Profile:
toyota tv
Use to tow our '68 globetrotter with a 1993 Landcruiser 4.5L I-6 215hp. Little slow on a hill but what can you expect truck,trailer, 2 people, 1/8th+/- tank fresh water 2 dogs, and all the other junk needed for 3 months weighed out a 9700# at govt. scale. truck alone was 4600#. On the flat 70mph no problem. and an 8.5-9 mpg. Didn't think that was to bad especially when another truck f250 with canopy 27' trailer and 7.3L PS diesel was only getting 11mpg. NOw tow with a 1999 Toyota Landcruiser 4.7L V8 same as the Tundra V8 and tows the same but a little quicker on hills and take-off. Your v6 is a great engine and the Gearing in the Toyota trans. is alittle different giving more torque at the wheels. 1st gear is really low. I only tow with a Toyota now!!
Igor
Igor68 is offline   Reply With Quote
Old 01-14-2008, 05:06 PM   #5
Stella
Upgrading piece by piece
Stella's Avatar
Profile:  1967 22' Safari
Jackson , Wyoming
I tow with a 2006 Tacoma TRD. It's rated to tow 6,500 pounds. When I bought it, I specifically got it to tow my older 22-foot Safari, weight about 3,450. I was originally looking at a Tundra, but once I saw the big tow capacity of the Tacoma I decided on it right away. "I don't need more truck than I need, right?" I asked the salesman. He didn't have a clue. I still worry about whether it's too much tongue weight, because the Tacoma does groan a bit under the load, but I tow less than 5k a year so I figure it's OK.
With the 238-hp V6, my truck gets 22-23 mpg on the highway, and about 15-16 while towing. The giddyup is adequate even in the mountains, IMHO, and once you're cruising along, it's so smooth I forget it's back there. For about 60 seconds. Then I remember and frantically look back for any spare compartment doors flying off. :-o
“You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose.” -- Dr. Seuss
Life's an adventure! http://www.lovenewsjh.blogspot.com
Stella is offline   Reply With Quote
Old 01-14-2008, 05:59 PM   #6
waltero
Hey Red, waltero again, yes you read correctly, I tow the 25' with a 2000 tacoma with the 3.4 Litre V6....manual transmission....I often go through the appalachain mountains, in West Virginia on I 64 (Sandstone Mt) has a long 7 degree stretch, east of Beckley WV...other than the rockies it is as good a test as you'll find....I do it at 65 mph...or here in Virginia Afton Mt, again I run it at 65 when I have the space to keep my rpms up....
Old 01-14-2008, 08:15 PM   #7
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
I tow our 5300 lb Bigfoot 25' with our '02 Access Cab Tundra 3.4l V6 4WD auto. The tow rating on the truck is 4800 lbs, but the truck has the same frame, suspension, and rear end as the V8 version that is rated at 6800 lbs towing, so I'm not concerned that any of the body/frame/running gear will fail. I've concluded that the lowered tow rating is primarily a result of horsepower (the 4.7l V8 develops about 50hp more than the 3.4l V6). The 5300 lb trailer tows nicely behind the Tundra, but is a little sluggish up hills compared to towing with the V10 Excursion (imagine that...)
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 01-14-2008, 09:44 PM   #8
Argonaut20
Profile:  1978 Argosy Minuet 6.0 Metre
Las Cruces , New Mexico
I towed a 6 meter Minuet with a '98 Tacoma outfitted the same as yours except it was a 4X4. We went from southern New Mexico through Flagstaff, Barstow, and the gold fields of California. We were careful not to carry a lot of weight in the trailer by buying food often and leaving the water tank half full. Serious mountains (on the Arizona - California border, for example) had us down to 40 - 45 mph, otherwise no real problem for the truck. No overheating when going through the mountains. Mileage ranged from 11 to 13.5 mpg. Flat roads had us keep about 60 - 65 mph. We did not try to go everywhere at 75 mph but kept about 65 as the upper limit. We did not use an equalizer hitch but had air lifts on the Tacoma that we could level the truck and trailer with. The equalizer hitch would be better I have since decided. In short, the Tacoma and the Minuet made a nice combination.
1978 Argosy 6 Metre Minuet
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 01-14-2008, 11:05 PM   #9
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
For what it's worth, we tow a 2006 19' Bambi with a 2007 Tacoma TRD Off Road Double Cab...towing rate is 6500 lbs and the Bambi dry is 3500 lb and 4500 loaded. We have been happy with its performance. We will not win any up-hill races, but then we are not trying to win races...just get there happily an din one piece. We tow at 65 mph max. And even up hill we are usually able to go the speed limit.
TB
TB & Greg...Cockers Annie & Sadie...and Homer the Desert Tortoise
WBCCI Four Corners Unit #3954
AirForums #21900
Please Visit Our...
Décor Site: AZBambi Décors
Old 01-15-2008, 12:38 AM   #10
pauly g
pauly g's Avatar
Profile:  1960 22' Safari
Oceanside , California
I towed my 1960 22' safari with a 2000 tacoma V6 4wD a few times. It was OK, but I really thought the truck was at its limit. I traded the Tacoma for a Tundra that is 3 years newer, and it didn't cost me much more. I feel safer towing with the Tundra. I think the weight numbers that Red Rover gives are too low for trailers of those lengths.
Stella, I wish I got that kind of fuel economy! Maybe I should save for a new Tacoma. It has nearly the horsepower of my Tundra.
pauly g is offline   Reply With Quote
Old 01-15-2008, 07:43 AM   #11
Argonaut20
It looks like weights Red Rover is using are dryweights. The 6 m Minuet weighs about 3500 pounds fully loaded. It can be kept below that by loading lightly. He has an advantage over my '98 Tacoma in that he isn't hauling the 4X4 apparatus around giving him a better power to weight ratio. I have to admit that the 2006 Tacoma is a better TV with more ponies. It is a larger truck as well. The '98 did very well with the Minuet 6 m, however.
2006 Toyota Tacoma
Old 01-16-2008, 05:00 PM   #12
Red Rover
Smile Toyota Tacoma TV
Hello again, I would like to thank Everyone who has given me imput on this matter! And welcome any other opinions, specially with exp with simular TV.I also realize that I will be pushing the envelope towing the "minuet" 20 or22ft trailer. I believe the Argosy 20 will have a simular weight as the Minuet 22? I have a few specific questions from some of you kind responders. Thanks Again! Red Rover^^^
Old 01-17-2008, 08:59 AM   #13
Red Rover
Waltero hello, thanks for the imput! What does your trailer weigh empty and loaded? Whats your gas milage- flats- mountain. How many miles on your toyota, any mods on TV? What are your rear shocks? I have just put on H-D KYB monomax shocks and new Yokohama Geolander HT/S 10.5x31 tires. Have put only about 5000 miles on them and believe they are a great combo!And thank you very much for your feedback. Red Rover^^^
Old 01-17-2008, 09:41 AM   #14
waltero
Red, my 73 is listed at 4200 lbs dry, although I have done some changes, bathroom, converter etc and it came in closer to 4000 on a local scale,so I'm probably running 45-4600 loaded...Gas mileage towing, 15.8 last trip partly mountains, partly Interstates, My Tacoma has 149,000, with Bilstein rear shocks
Best Old Trailer for 2006 Tacoma V6 Truck? barbara4rb Member Introductions 3 06-03-2007 09:25 AM
changed from Liberty to Tacoma.. safari05-25 Tow Vehicles 10 07-18-2006 10:56 PM
Towing 19' Bambi with 2005 Tacoma hiker Tow Vehicles 18 10-05-2005 09:03 PM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 07:10 PM
test
