Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 11-12-2004, 05:34 PM   #1
kemosabe's Avatar
Branford , Florida
Thetford Toilet replacement
Can someone tell me which brand and model new low profile toilet replaces the original Thetford in my 1978 24' Argosy. Thanks.
kemosabe is offline   Reply With Quote
Old 11-12-2004, 06:08 PM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Not sure you are aware, but all the rebuild parts are avaliable is you would desire to rebuild
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-12-2004, 06:31 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings kemosabe!
Welcome to the Forums!
There are at least two different models that have been used by owner's of '77-'79 Argosys recently. My dealer recommended the Thetford Bravura Low Profile for my '78 Minuet. I am satisfied with the match - - it is marginally taller and has a slightly larger footprint than the original. Installation required slight modification to the box that encloses the black water tank, and its slight additional height means that the door on cupboard behind the toilet doesn't open completely. Janet mentions in the Too Many Thrones Thread that the Dometic SeaLand Light porcelain toilet fits without modification. The SeaLand is available in a greater color selection than the Thetford, and should be easier to clean since the bowl is porcelain which is less sensitive to cleaning compounds utilized.
Good luck with your research!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 11-13-2004, 06:04 AM   #4
kemosabe's Avatar
Branford , Florida
Ken
I was told parts were no longer available for this model????
Old 11-13-2004, 07:04 AM   #5
Ken J's Avatar
Durango , Colorado
Images: 14
I just rebuilt my last winter - the toilet is not available, but the parts are. Check with (I think this is the web site - if not let me know) Marksrv.com. Bit of warning the parts will cost about as much as a new toilet, but to me it was worth it to keep the original toilet because as Allen mentions above, I would have had to make modifications. I was not against a new one, just did not want to have to do surgery to replace.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 11-13-2004, 01:47 PM   #6
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Ok, Kemosabe what is your situation?
1 No Toilet?
2 Leaking Toilet
3 Busted Toilet... broken and/or missing this and that.
Mine leaked in my 78 Excella. It is a Thetford Aquamagic and I was able to find the replacement valve and correct the problem. I suspect yours is the same model. It is a dickens to get out and back into the bathroom because of the cramped space. If you need more help on removal and installation I can send more info.
Vic
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
https://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 11-13-2004, 01:53 PM   #7
Ken J's Avatar
Durango , Colorado
Images: 14
To get it out you just need to be a little "flexable"
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 11-13-2004, 10:03 PM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
The Sealand traveler lite model is the only one we found that would fit in our minuet without interfereing with the "secret compartment" behind the tiolet. It comes in 2 heights and a bunch of colors. It is a tight fit - but when properly installed - it will fit. It's procelin and ours is holding up well. Oh yeah..... it comes with a crumby seat - but takes a standard size seat so we swapped it out for a nice wooden one.
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 11:05 AM
Toilet Valve Replacement girardblvd Sinks, Showers & Toilets 2 06-24-2004 08:59 AM
Toilet replacement Globestream Sinks, Showers & Toilets 2 09-23-2003 11:52 AM
Toilet Replacement for 66 Landyacht SterlingM Sinks, Showers & Toilets 0 02-03-2003 12:35 PM
