Old 08-13-2004, 01:13 AM   #15
blrpix's Avatar
Question Same here...
Mine is a 20ft 65' Globe Trotter...I know the tank idea will work...BUT my shower is in the back, near the toilet...drains the same, bypasses the black water but comes out the same outlet. My concern is the run from the low shower drain to the new GW tank...does it need slope? I need to take measurements, but I could conceive that it could run flat, but with much slope it will lose tank capacity..correct? Thoughts?
Originally Posted by chuck
my black tank already sits in the same spot as is pictured...only up a little higher. it sits ON the floor. (there's a cover over it, and then the toilet and vanity/sink sit on top of the tank cover). its only 13 gallons...but seems to be plenty for a weekend. and really, this is a "weekender" trailer, anyway.
I have no plans on changing that. I just want to add a grey, like in the picture. this drawing looks very much like my trailer, as far as I can tell...I havent taken the belly pan off yet and taken exact measurements, but I have poked around under there, surveying the rivet lines, and so forth. there's a 22" wide space right behind the axle, just like is pictured. then the next 'gap' is narrower than that...just like in the picture...then the furthest aft cavity is wide. again, just like the picture. which is why this rendering really caught my eye, and got me thinking.
I took a peek at the underside of a 1974 unit at a rally, to see if I could get an idea of how they put the grey tanks in those. it looks like what I described before...the tank appears to be supported the same way the fresh water tanks are supported. the support system sort of hangs down an inch or so beneath the level of the belly pan. its held up to the frame with steel angle-iron all around, which would add support to the frame.
I don't believe frame separation was ever an issue in this size trailer...there isn't that much overhang behind the rear axle. Plus, I don't plan on driving any distance w/ full tanks....perhaps from a dry-camping rally situation to the nearest dump station...that would be it.
(btw: what are you doing at Jaque Chirac's house, anyway?? )
blrpix is offline   Reply With Quote
Old 08-13-2004, 07:52 AM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
slope would be optimal...so would having the drain line enter the tank from above...but in this kind of confined space, it isn't really practical. fact of the matter is that water will seek its own level. the shower drain is on the floor of the trailer; the highest point of an under-floor grey tank is going to be lower than that, if only 3/4 of an inch. therefore, the water will drain from the shower pan to the tank...no matter how high or low on the side of the tank the drain is attached. (as long as there the tank is vented from the top..that's "key"). it'll just drain slowly when the water level in the tank rises to the level of the drain pipe. you wouldn't want to do this in your house, where you might run the shower constantly for prolonged periods...but since RV showers are always "GI" type, due to the low hot-water capacity of the camper, the slow drain is not a big problem. really, no different than using a 3/4 hose from the sewer cap to an external "blue-boy". (I had a little standing water in the bottom of the shower this past weekend when I took a shower under these conditions....it drained, eventually.).
Last year, I experimented with mounting my huge blue-boy to the underside of the trailer, in the spare tire carrier. the belly pan is cut away in that area, opening the cavity formed by the frame just aft of the a-frame, to make room for a tire to fit up in there. I dont' have a spare, and I really wanted to go dry camping with a group, at a place where grey dumping was verbotten. so I rigged this up w/ a long piece of pex tubing, connected to the 3/4 fitting on the sewer outlet, and mounted the blue-boy on the spare tire carrier. ran the pex up over the axles, and to the front of the trailer. had garden-hose fittings on either end of the pex pipe. I attached the pipe to the blue-boy via a short piece of garden hose to another sewer cap fitting on the blue boy. (this blue boy is a 4-wheeler, so it has a dump valve, just like a camper's, mounted in the lowest spot; it would be too heavy to lift and dump otherwise.). so this drain dropped down from the trailer's sewer outlet, curved back uphill to where it was secured w/ hose clamps to the pan, snaked its way all the way to the front of the camper, then sloped down and under the blue-boy, and back up the other side, and then filled the blue-boy from the BOTTOM. and it worked. We took showers that weekend, and everything worked just fine.
I did find that it was a PITA to mount the blue-boy on the spare bracket, because its big, bulky, heavy, and just barely fits. but it did work in a pinch. It also hung down pretty low, too, which sort of made me a little nervous...but people w/ newer trailers have plumbing that has just as little ground clearance, so...
I posted a diagram here somewhere...I'll see if I can find it.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
« used parts | Top | 26 foot »
